06-09-2015, 14:23 Subject: Hardware Suggestion: Small & Useful |
Hello Rainer,
The LED on the VCDS interface is a great idea for estimating the area where the problem lies in case of communication issues.
When connected to a Polo 9N, it always blinks towards the driver. However, with the Ibiza 6L (which has a horizontally oriented OBD socket behind the small compartment), it points downwards. And while the Polo 6R has the OBD socket mounted diagonally downwards again, it's in the opposite direction, meaning the LED blinks at the driver's foot.
In the Rapid, the LED is mounted lengthwise, meaning it blinks to the right or left (I don't remember exactly which way).
Whether or not the LED is visible is therefore likely a matter of chance, depending on the orientation of the OBD sockets in the specific vehicle model.
My suggestion:
Incorporate more blinking LEDs into the interface so that the data dialogue is recognizable from all directions. Alternatively, distribute the light from the dual LED using transparent plastic parts/light guides to achieve a similar all-around visibility.
GruĂ Ulf
Translated on 16-10-2026, 13:12.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
06-09-2015, 15:28 Subject: Hardware Suggestion: Small & Useful |
Thank you for the information. However, I still believe the likelihood of it happening is quite low.
Translated on 16-10-2026, 13:14.
Profile PM WWW Garage |
07-09-2015, 6:50 Subject: Hardware Suggestion: Small & Useful |
Yes, it seems that the VCDS tools are selling well enough as they are.
But it would be a way to further increase acceptance of competing products. Skoda uses the advertising slogan "Simply clever"  for such small things.
GruĂ Ulf
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
07-09-2015, 7:23 Subject: Hardware Suggestion: Small & Useful |
If you don't want to change anything else about the layout, then a completely transparent enclosure might already achieve the desired effect.
Translated on 16-10-2026, 13:15.
dieselschrauber likes this. |
07-09-2015, 7:28 Subject: Hardware Suggestion: Small & Useful |
I suspect that 80% of users don't understand the meaning of LED at all, 18% are not interested, and 2% would be happy about it.
The idea is nice, but it's actually not necessary at all. You don't necessarily have to constantly monitor the LED. Either the diagnosis works, in which case no one will look at it, or it doesn't work, in which case you can also just glance briefly under the dashboard.
Translated on 16-10-2026, 13:16.
Profile PM Garage |
07-09-2015, 8:31 Subject: Hardware Suggestion: Small & Useful |
TDI-GTI-4-Motion wrote: | Either the diagnosis is correct, in which case no one will look at it, or it's incorrect, in which case you might as well hang your foot in the footwell for a moment.  | If you ever do that during a test drive, I'd like to see a video of it.
GruĂ Ulf
Profile PM Garage |
07-09-2015, 8:50 Subject: Hardware Suggestion: Small & Useful |
During a log transfer, you certainly don't need to do that, because if a log transfer even occurs, it seems that the connection has probably been established!
Translated on 16-10-2026, 13:17.
Profile PM Garage |
07-09-2015, 8:54 Subject: Hardware Suggestion: Small & Useful |
Then the connection was established successfully up to the beginning of the log. However, this doesn't guarantee that a connection will never be dropped â I've already experienced this with the Polo and the MED9.1 system, although it hasn't been reproducible so far.
GruĂ Ulf
Profile PM Garage |
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
dieselschrauber and TDI-GTI-4-Motion likes this. |
09-09-2015, 9:12 Subject: Hardware Suggestion: Small & Useful |
Then, the LEDs will also indicate that the communication has stopped.
Advantage: You could immediately pull over to the right and restart.
Disadvantage: The device is still located near the left knee, which forces you to...
to avert one's gaze from the traffic.
Compromise suggestion: build an extension that allows you to position the interface so that THE LED is within your field of vision  .
Translated on 16-10-2026, 13:18.
09-09-2015, 16:17 Subject: Hardware Suggestion: Small & Useful |
Or, we could make it even simpler, without even touching the hardware, and simply embed the "LED" in the software and display it somewhere on the screen.
Translated on 16-10-2026, 13:19.
Profile PM Garage |
09-09-2015, 19:25 Subject: Hardware Suggestion: Small & Useful |
TDI-GTI-4-Motion wrote: | Simply implant the "LED" into the software and display it somewhere on the screen. However, this would eliminate control of the on-board voltage supply. The real LED already lights up when you plug the interface into the OBD socket (even without the VCDS.exe running). |
GruĂ Ulf
Translated on 16-10-2026, 13:20.
Profile PM Garage |
mullemaus Guest
10-09-2015, 9:53 Subject: Hardware Suggestion: Small & Useful |
Or simply add an extension to it, then you can design the interface however you want  .
10-09-2015, 10:56 Subject: Hardware Suggestion: Small & Useful |
Such an extension would be something for the diagnostics shop  .
GruĂ Ulf
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂźnchen & Passau
10-09-2015, 11:45 Subject: Hardware Suggestion: Small & Useful |
Hello everyone!
...so that I can finally say something again...
We all know how often these would be sold.
Best regards from Munich!
PS: A pink Hello Kitty-themed interface would probably sell better  .
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
Translated on 16-10-2026, 13:21.
10-09-2015, 14:00 Subject: Hardware Suggestion: Small & Useful |
DieselBär30x wrote: | P.S.: A pink Hello Kitty-designed interface would probably sell better.  | Yes, I would buy it immediately!
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
10-09-2015, 15:11 Subject: Hardware Suggestion: Small & Useful |
Quote: | | A pink Hello Kitty-themed interface would probably sell better | .
Faggot
.....or a TTS engine that says the words "the connection is interrupted"  .
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 16-10-2026, 13:22.
