I wanted to reset the electric parking brake on a Touareg this weekend.
Unfortunately, there was no such function available in VCDS within the basic settings, and it was not possible to select or adjust it.
In addition, the error log indicated "Basic settings not performed," but unfortunately, I was unable to complete that process either.
Did I make a mistake, or why wasn't this possible?
Here's the car scan:
VCDS Version: RKS 12.12.0
Data as of: 20131116.
Sunday, December 15, 2013, 4:06:18:58542 PM.
Vehicle type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
69 72
Vehicle Identification Number: WVGZZZ7PZCD0XXXXX
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
34-Level regulation -- Status: OK.
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: Error 0010.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control Module (J623-CRCA)
Label file: None.
Part number SW: 7P0 907 401 F, HW: 4G0 907 401.
Component: 3.0TDI EDC17 H37 0002.
Revision: 53H37---
Encoding: 292A4012233E01020000
Operating number: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
ROD: EV_ECM30TDI_VW52.rod
VCID: 326D2CE065CBCF8E527-8067
3 error codes found:
5604 - Signal for starter inhibitor (part number).
P0850 00 [032] - Short circuit to positive / Open circuit.
Sporadic - unconfirmed - checked since last deletion.
Freeze Frame:
Error status: 00100000
Error priority: 0
Error frequency: 57.
Lost Count: 32
Mileage: 9124 km
Date: 2000.00.00
Time: 00:00:00
14690 - Loading mode active.
P169A 00 [032] - -
Freeze Frame:
Error priority: 0
Lost Count: 32
Mileage: 9124 km
Date: 2000.00.00
Time: 00:00:00
9124 - Throttle control unit.
P2111 00 [032] - stuck open.
Freeze Frame:
Error priority: 0
Lost Count: 32
Mileage: 9124 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 0
Address 02: Transmission (J217)
Label file: 0C8-927-750.clb
Part number SW: 0C8 927 750 AG, Hardware: 0C8 927 750 AG.
Part: AL1000 AISIN 001 2083
Serial number:
Encoding: 001568
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031.rod
VCID: 71EFE3ECA04DB4966BD-8024
No error codes found.
Address 03: Brake Electronics (J104)
Label file: 7P0-907-379.clb
Part number SW: 7P0 907 379 J, HW: 7P0 907 379 A.
Component: MK25A H36 0433
Revision: -------- Serial Number: 406020010EC815
Encoding: 5B6B13C30B28255CDAFDC893D0D3A450F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 44817A38CF7F713EF0B-8011
Address 05: Access/Start Authorization (J393)
Label file: RKS\8K0-907-064-05.clb
Part number SW: 4H0 907 064 BL, Part number HW: 4H0 907 064 BL.
Component: BCM2 2.0, H31 0333.
Revision: 00002001
Encoding: 01A60000000000000000
VCID: 74E1EAF8D75F81BE80B-8021
Subsystem 1 - Part number SW: 7P6 959 754 AA, HW: 7P6 959 754 AA.
Component: FBSTOUAREGIDG H05 0051
Subsystem 2 - Part number SW: 4H0 905 852 B, HW: 4H0 905 852 B.
Component: J764 ELV MLB H40 0046
Address 08: Climate Control/Heating Unit (J255)
Label file: RKS\7P6-907-040.clb
Part number SW: 7P6 907 040 BK
Part number HW: 7P6 907 040 BK
Component: Climate control, 2 zones, H20 1305.
Encoding: B606000890
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 7EF5C8D0E113DBEEE6F-802B
"One error found:"
15360256 - Component protection active.
U1101 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Freeze Frame:
Error status: 00000001
Error priority: 1.
Error frequency: 25
Lost Count: 35
Mileage: 22,844 km
Date: 2013.04.16
Time: 18:06:09
Address 09: Central Electronics (J519)
Label file: 4H0-907-063.clb
Part number SW: 4H0 907 063 BL
Part number HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001419998
Encoding: 26001011D1345D010021000300005D0C431C670806010241000000020000
VCID: 73E3E9E4D2518686991-8026
Subsystem 1 - Part number SW: 7P0 955 119 HW: 7P0 955 119 Label file: RKS\1KX-955-119.CLB
Component: WWS 120130 31 0020
Encoding: 004DBD
Subsystem 2 - Part number SW: 7P0 955 559 D, HW: 7P0 955 559 D, Label file: RKS\8K0-955-559.CLB.
Component: RLFS H09 0011.
Encoding: 025223
Subsystem 3 - Part number SW: 7P6 941 431 HW: 7P6 941 431
Component: E1 - LDS H04 0031
Address 10: Parking Assist 2 (J446)
Label file: 7P6-919-475.clb
Part number SW: 7P6 919 475 B, HW: 7N0 919 475.
Part: PARKING ASSIST 8K H05 0021
Revision: -------- Serial Number: 28261205100806
Encoding: 118501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 428D7C20D56B7F0EC27-8017
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 7P0 959 655 C. Hardware: 7P0 959 655 C.
Part number: VW10Airbag001 H05 0025
Revision: -------- Serial Number: 003L0001YKA3
Encoding: 000000000000000000000000000000003031
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 418F732CD06D6416DBD-8014
Crash sensor for driver-side side airbag:
Serial number: 3575LRB404V150GSEHB
Crash sensor for side airbag, passenger side.
Serial number: 3585LRB404T150GS982E.
Rear side airbag crash sensor (driver's side).
Serial number: 3515RRB406714TPK6PSJ
Crash sensor for rear side airbag, passenger side.
Serial number: 3525RRB406914TPKAO85.
Crash sensor for front airbag, driver's side:
Serial number: 3555NRB404R0VIFMD086
Crash sensor for front airbag, passenger side.
Serial number: 3565NRB40550VIFM412F.
Address 16: Steering wheel electronics (J527)
Label file: None.
Part number SW: 4H0 953 568 F, HW: 7P6 953 507 L.
Component: Steering module. Part number: H03 0005.
Revision: -------- Serial Number: 90815LBO0006H
Coding: 000015
VCID: 366510F081A3D3AE7EF-8063
Subsystem 1 - Part number SW: 7P6 959 542, HW: 7P6 959 542.
Component: E221__MFL-TAS H03 0027
Address 17: Control unit interface (J285)
Label file: 7P6-920-xxx-17.clb
Part number SW: 7P6 920 882 Hardware number: 7P6 920 882
Component: Combination unit H14 0253.
Revision: 12240067 Serial number: 658190212592062
Encoding: 132731003A000008000004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: FAFD44C07D3B77CE5A7-80AF
Address 19: Diagnostic interface (J533)
Label file: None.
Part number SW: 7P6 907 530 C, HW: 7P6 907 530 A.
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial Number: 00000000420685
Encoding: 000D077500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 38791EC883B725DE6C3-806D
Battery monitoring control unit:
Subsystem 1 - Part number SW: 7P0 915 181 A, HW: 518 1ÿÿ ÿb.
Component: Batt_Sensor H07 0140
Serial number: 00000000005650597270
Voltage stabilizer:
Address 34: Level Control (J197)
Label file: 7P0-907-553.clb
Part number SW: 7P0 907 553 K, Part number HW: 7P0 907 553 K.
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000120450343
Encoding: 14210000
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 3F8B75D4A69912E6AD9-806A
Address 42: Door Electric Driver (J386) Label file: None.
Part number SW: 4H0 959 793 N, HW: 4H0 959 793 F.
Component: TSG FA H07 0166
Revision: -------- Serial Number: 0000125198569
Encoding: 011D0620D000451005080000
VCID: 44817A38C77F713EF0B-8011
Address 46: Comfort System (J393)
Label file: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0171461875
Encoding: 0180162028B90094832006242000000000000000000000000000000000000000
Subsystem 1 - Part number SW: 7P0 959 591 B, HW: 7P0 959 591 B.
Component: J245 PS30.055 H01 0008.
Encoding: 191100
Subsystem 2 - Part number SW: 7P0 959 591 C, HW: 7P0 959 591 C.
Component: J394 PS30.055 H01 0008.
Encoding: 191100
Address 52: Door electronics, passenger side (J387) Label file: None.
Part number SW: 4H0 959 792 F. Part number HW: 4H0 959 792 F.
Component: TSG BF H07 0166
Revision: -------- Serial Number: 0000125034783
VCID: 3B7301C4BA810EC6811-806E
Address 53: Parking brake (J540-)
Label file: 7P0-907-801.clb
Part number SW: 7P0 907 801 F, HW: 7P0 907 801 F.
Component: EPB H51 1201
Revision: 00000000 Serial number: A12219001A0
Encoding: 00000000
ASAM Dataset: EV_ParkbA7 000006
FILE: EV_ParkbA7.rod
VCID: 366510F089A3D3AE7EF-8063
Slave 1:
Slave 3:
0025 - Initial setup not performed.
B2010 F0 [008] - Deviation is outside the expected range.
Freeze Frame:
Error priority: 1.
Error frequency: 30.
Lost Count: 0
Mileage: 1,045,248 km
Date: 2071.03.31
Time: 08:29:07
0024 - Initial setup not performed.
B2010 00 [009] - -
Freeze Frame:
Error priority: 1.
Lost Count: 0
Date: 2071.03.28
Time: 02:28:59
12652550 - Control unit incorrectly programmed.
U1014 00 [009] - -
Freeze Frame:
Error priority: 1.
Lost Count: 0
Date: 2071.03.28
Time: 02:28:59
Address 55: Headlight range adjustment (J745) Label file: RKS\7P6-907-357.clb
Part number SW: 7P6 907 357, HW: 7L6 907 357 C.
Component: AFS-ECU H04 0110
Revision: -------- Serial Number: --------------
Encoding: 01AA00000F000200
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: FCF142D8770F49FE48B-80A9
Left headlight power output stage:
Subsystem 1 - Part number SW: 8U0 941 329, HW: 8U0 941 329.
Part: LeiMo left side, H01 0002.
Encoding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part number SW: 8U0 941 329, HW: 8U0 941 329.
Component: Right-hand LeiMo, part number H01 0002.
Encoding: 130000
Address 56: Radio (R) Label file: RKS\4F0-035-0xx-56.clb
Part number SW: 4G0 035 061 E
Part number HW: 4G0 035 061 E
Component: Radio with DAB functionality. Part number: H60 0099.
Revision: AB001007
Serial number: 109BY0C7555066
Encoding: 010105020100000003
VCID: 1F4BD5540E5972E68D9-804A
Address 5F: Information Selection. I (J794)
Label file: RKS\4E0-035-6xx-5F.clb
Part number SW: 7P6 035 670 C, HW: 7P6 035 670.
Component: H-BNT-EU H46 0458
Revision: -------- Serial Number: 478B30C7573871
Encoding: 010100050040C1ED01002B0E00000003F0040101
VCID: 356717FC9CA5D8B6775-8060
Subsystem 1 - Part number: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part number SW: 7P6 919 603, HW: 7P6 919 603.
Component: DU8 SV Touch H26 0045.
Subsystem 3 - Part number SW: 7P6 919 603, HW: 7P6 919 603.
Subsystem 4 - Part number: 8R0 060 961.
Component: CD Database 1886.
2 error codes found:
00384 - Optical data bus.
011 - Interruption - Sporadic.
Freeze Frame:
Error status: 00101011
Error priority: 5.
Error frequency: 1.
Lost Count: 55
Mileage: 48089 km
Time: 0.
Date: 2013.12.05
Time: 19:48:06
Freeze Frame:
Voltage: 12.60 V
02259 - Control unit display and operating unit, front (J685)
008 - implausible signal - sporadic.
Freeze Frame:
Error status: 00101000
Error priority: 5.
Error frequency: 1.
Lost Count: 35
Mileage: 46410 km
Time: 0.
Date: 2013.11.18
Time: 11:21:24
Freeze Frame:
Voltage: 12.50 V
Address 62: Door electric strike, left/right (J388)
Label file: None
Part number SW: 4H0 959 795 B. Part number HW: 4H0 959 795 B.
Component: TSG HL H09 0167
Revision: -------- Serial Number: 0000124898176
Encoding: 011C04200000251005080000
VCID: 3A7D04C0B5BB37CE9A7-806F
Address 69: Trailer (J345) Label file: None.
Part number SW: 7P0 907 383 G, HW: 7P0 907 383 C.
Component: Trailer H09 0110
Revision: 5H001001 Serial Number: 00000170149300
Encoding: 0106040000000000
VCID: 3C7102D8BF8F09FE88B-8069
Address 72: Door electrical contact, high, right (J389)
Label file: None.
Component: TSG HR H09 0167
Revision: -------- Serial Number: 0000124898182
End. Kaum macht man es richtig, funktioniert es!
Translated on 24-09-2026, 22:44.
