How to reset DSG from Golf 7R, Audi S3 8V to factory settings?
kukkie
Post12-12-2015, 18:19    Subject: How to reset DSG from Golf 7R, Audi S3 8V to factory settings? Quote
Does anyone know how to reset the DSG transmission to its default settings using VCDS on an Audi S3 8V or a Golf 7R?
Post13-12-2015, 10:08    Subject: How to reset DSG from Golf 7R, Audi S3 8V to factory settings? Quote
Hey, have you checked that already?
For more information, please see http://www.obd-info.de.
kukkie
Post13-12-2015, 10:47    Subject: How to reset DSG from Golf 7R, Audi S3 8V to factory settings? Quote
Yes, I've already read that.
That's no longer the case with the Golf 7R and Audi S3.
You can no longer access the standard measurement blocks in this way; you can only access the extended measurement blocks.
Post13-12-2015, 11:07    Subject: How to reset DSG from Golf 7R, Audi S3 8V to factory settings? Quote
You shouldn't be "adjusting the measurement blocks," but rather the basic settings.
kukkie
Post13-12-2015, 11:16    Subject: How to reset DSG from Golf 7R, Audi S3 8V to factory settings? Quote
Have you ever seen what the new control units look like?
The entire control unit is structured differently.
There are even functions that you can select through customization, such as the default setting.
Deleting driving profiles.
Learning.
However, you must enter a number with 1 to 3 digits and then execute it.
That's why I'm looking for a detailed guide, because there are many other options you can choose from. But above all, you need the correct number, which, according to the program, should have 1-3 digits.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A8 air suspension basic settings Transmission, Chassis, Body & Interior
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
No new posts Audi S3 8V: Steering Angle Sensor Calibration On-Board Diagnostics (OBD)
No new posts DSG Basic Settings Audi DL501 vs. VW DQ500 On-Board Diagnostics (OBD)
