Exhaust manifold leak, BKD engine
Stierkaempfer
Post20-12-2015, 10:20    Subject: Exhaust manifold leak, BKD engine Quote
Good morning.
Due to acceleration and idling issues, I have an appointment at the workshop to have the throttle body checked/replaced. During yesterday's inspection, I discovered a leak in the intake manifold.
I will have the clutch replaced as soon as possible and hope that this resolves the jerking problem.
In the log, cylinder 2 shows occasional misfires, and at idle, it has a fuel quantity reading of 2.99 mg/hour.
The intake manifold is covered in soot on the right side, near the two middle cylinders.
Is that the intake valve for cylinder number 2?
Thank you.
2.0 PD TDI 140PS BKD
Translated on 20-07-2026, 23:42.
Post20-12-2015, 12:57    Subject: Exhaust manifold leak, BKD engine Quote
No, that's cylinder number 3.
Edit: aside from that, you mean the one on the right side when looking at the engine from the front, and not the right side on the passenger's side. icon_wink.gif
Translated on 20-07-2026, 23:43.
Stierkaempfer
Post20-12-2015, 13:39    Subject: Exhaust manifold leak, BKD engine Quote
The engine is mounted transversely (or sideways).
Looking at the engine, I see the timing belt on the left side. Counting from left to right, it's the third cylinder.
Translated on 20-07-2026, 23:44.
Post20-12-2015, 15:30    Subject: Exhaust manifold leak, BKD engine Quote
Yes, then it is indeed the 3rd cylinder, because the counting starts from the side that delivers power.*
* Also, a quick note for the future: Not every manufacturer (like French ones, for example) handles it this way! icon_wink.gif
Stierkaempfer
Post20-12-2015, 17:39    Subject: Exhaust manifold leak, BKD engine Quote
Unfortunately, cylinder number 2 is clearly the problem.
Let's see what happens after the seal replacement.
Translated on 20-07-2026, 23:45.
vwSchrauber
Post21-12-2015, 7:59    Subject: Exhaust manifold leak, BKD engine Quote
Just a heads-up for the future: Not every manufacturer (like French ones, for example!) handles things this way! icon_wink.gif
There are also German companies that don't operate in that way, for example, Deutz.
Let's see what appears after the seal replacement.
Take a look inside the intake manifold once the blower is removed. You might be able to see the condition of the valves (and how dirty they are).
A value of +2.99mg is more likely to be attributed to issues with the pre-combustion chamber (PDC). Engines with an added intake manifold typically run smoothly in low load and low RPM ranges, as there is relatively ample time for filling the cylinders through the constricted cross-section.
Translated on 20-07-2026, 23:46.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts Defective candle Diesel Engine Technology
No new posts ABS/ESP Leak: Find the Source! Diesel Engine Technology
No new posts ESP Leak / Seals: Causes & Solutions Diesel Engine Technology
