jarobaldu Profi-Schrauber
08-10-2015, 8:27 Subject: Cylinder head cover leak AMF |
I'm having trouble with an oil leak on the valve cover.
I replaced the gasket (Elring), installed it dry, but it still leaked.
Then I applied sealant (Dirko Gray), but it's still leaking near the screws on the back.
Does anyone have a tip for me? Not enough packing material?
The hood itself has already been replaced with a used one.
Adrian.
| Description: |
| Undichte Zylinderkopfhaube (Spiegelbild) |
| File size: |
165.58 KB |
| Viewed: |
1913 times |
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
08-10-2015, 10:30 Subject: Cylinder head cover leak AMF |
Either the hood or the VDD is also defective, or there were errors during installation.
Normally, the sealant is only applied to the joints of the NW bearings.
Possibly, the leak is actually located somewhere else, and the oil then flows like a stream to the lowest point, where it drips off.
So... Remove the lid and take a look.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
14-10-2015, 8:55 Subject: Cylinder head cover leak AMF |
A few questions:
-Does anyone know why VW removed the gasket from the parts catalog?
- Is the sealant only needed in the corners?
- Put the dough into the bowl?
- Make the ZK (zinc anode) grease-free and do not apply any sealant there.
I've now ordered new gaskets with screws, for a new...
Adrian.
dieselschrauber likes this. |
14-10-2015, 10:06 Subject: Cylinder head cover leak AMF |
Carefully examine the sealing groove of the hood to check if there is any crack or damage.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2400 Karma: +437 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
14-10-2015, 10:18 Subject: Cylinder head cover leak AMF |
jarobaldu wrote: | | Does anyone know why VW removed the gasket from the parts catalog individually? |
I'm experiencing a similar problem with my wife's 1.9 PD-TDI. The head gasket has already been replaced individually (as a separate part), but it is still leaking.
According to my mechanic, the plastic cover sometimes develops leaks because it can warp or crack. According to his statement, that's also the reason why VW generally replaces the entire hood instead of just the seal.
No idea if that's true. Due to a lack of time, I will now have everything completely replaced.
Greetings.
Guste.
Profile PM Garage |
29-10-2015, 21:31 Subject: Cylinder head cover leak AMF |
That was already the second attempt with two used hoods, so I went to  and bought new ones. I hope this will be leak-proof now.
But there's a new problem: the bleeder fitting has a different angle, and the bleeder hose could only be mounted under tension. Is it possible to rotate the fitting? I don't want to force it or try to make it work by any means necessary, otherwise those 122 euros will be gone very quickly...
old ZK hood: 045 103 469 C
New 045 103 469 G
Adrian.
P.S. The winnings arrived today  Thank you!
| Description: |
| Zylinderkopfhaube AMF TDI |
| File size: |
1.72 MB |
| Viewed: |
844 times |
29-10-2015, 21:47 Subject: Cylinder head cover leak AMF |
Quote: | | Can the sock be turned inside out? |
I don't think so.
christo Blaumann
Joined: 04/30/2004 Posts: 11 Karma: +6 / -0 Location: 35305 GrĂŒnberg
29-10-2015, 23:00 Subject: Cylinder head cover leak AMF |
jarobaldu wrote: | | Can the sock be turned inside out? |
Certainly not.
Skoda Octavia III Combi (5E5), EZ: 6/2016, 2.0 TDI 110 kW (MKB: CRMB), 6-Gang-Schaltgetriebe (GKB: PGT)
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
29-10-2015, 23:02 Subject: Cylinder head cover leak AMF |
Alternatively, carefully heat the rigid plastic tube with a hot air gun; it will naturally take on a more relaxed shape.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
09-02-2016, 16:27 Subject: Cylinder head cover leak AMF |
I'd like to provide some feedback: The ZK hood was returned because the ventilation was incorrectly glued/welded.
After checking, I received a new one  .
The new cooker hood design has different screws, the seal is thicker, and it is, above all, leak-proof  .
Adrian.
Joined: 04/12/2002 Posts: 18063 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
09-02-2016, 16:31 Subject: Cylinder head cover leak AMF |
Thank you for your feedback! Do you happen to have the part number for the new cylinder head cover?
Profile PM WWW Garage |
10-02-2016, 15:07 Subject: Cylinder head cover leak AMF |
Here is the number: 045 103 469 G.
Adrian.
10-02-2016, 15:22 Subject: Cylinder head cover leak AMF |
Thank you!
