AlexanderRichert
20-03-2016, 0:17 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Good evening, dear car enthusiasts,
Here is my last chance. My friend arrived from abroad with a "Passat B5 Diesel" vehicle and his family, but unfortunately, the engine broke down during the trip. We bought a diesel engine block and helped our friends assemble it together. Normally, everything has always worked well, as these friends are knowledgeable.
This time, I've put everything together, connected it, but the engine won't start. I bought software VCDS with friends a few years ago and always liked helping others (as much as I could). This time, however, the engine won't start at all. Software doesn't have errors.
The only thing that surprises me is that the magnet valve status shows 2.0, but briefly goes to 6.0 and then 8.0 when starting. I have researched online and found that the magnet valve control cable could be defective. We have replaced it, but it is not working. The mechanic cannot help us. ADAC conducted an investigation and the result is: Either the plus or minus connection is missing on the cable, unfortunately, he was unable to measure it.
The family does not have the money to replace the motor again. Please advise on how I can measure the engine cables. I have a multimeter. Is there a fuse? Also, one of my neighbors came over and sprayed brake cleaner into the air intake opening, and then the engine started, but only for as long as he was spraying.
Please, I need some advice. Thank you in advance!
DieselBĂ€r30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂŒnchen & Passau
20-03-2016, 1:39 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Servus Alex!
Bitte, wie immer und ĂŒberall hier so ĂŒblich und auch stĂ€ndig bemĂ€ngelt, Autoscan machen und hochladen!
Weiter: An was ist denn GENAU das vorig Motor bei Fahr kaputt gegangen??
Danke.
Viele GrĂŒĂe aus MĂŒnchen!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger! |
AlexanderRichert
20-03-2016, 10:08 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Guten Morgen,
Danke fĂŒr die Hinweis. Ich fahre um 12 Uhr zum Kollegen und mache Autoscan. Was genau auf der Fahrt passiert ist ist mir unbekannt, muss ich nachfragen. Es gab eine zeitlang schwarzen Rauch und dann ist der Motorblock mechanisch defekt geworden.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
20-03-2016, 16:01 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Hi,
bitte keine Experimente mit Bremsenreiniger mehr.
Bitte erstmal die Kraftstoffzufuhr prĂŒfen, auch Druck der Tandempumpe. Steuerzeiten sind ok? PD-Elemente wurden richtig eingestellt?
Viele GrĂŒĂe, Rainer
Profile PM WWW Garage |
AlexanderRichert
20-03-2016, 16:43 Subject: Car scan completed |
I have performed an auto-scan. I will add it shortly. Regarding the steering cable, there is 0.5V between the brown wire and the negative terminal. Connection from SteuergerÀt (Connector) to Motor (Connector) - 5-Pole - OK (measured).
| Description: |
 Download |
| File name: |
Log-P1320093-WVWZZZ3BZ2E262071-548870km-xxx.txt |
| File size: |
4.68 KB |
| Downloaded: |
799 times |
AlexanderRichert
20-03-2016, 16:58 Subject: Log file with solenoid status |
I have a log file that stores the status of valve magnets. Can we get anything out of that?
| Description: |
 Download |
| File name: |
LOG-01-013-015-018.CSV |
| File size: |
2.55 KB |
| Downloaded: |
443 times |
AlexanderRichert
20-03-2016, 17:41 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Aus dem Kraftstofffilter spritzt Diesel raus. Da ist der Schlauch zur Hochdruckpumpe. Nach der Pumpe kann ich nicht messen. Ist es möglich, das durch die Software rauslesen? Motor wurde mit der Pumpe gekauft, alter Besitzer meinte es war alles in Ordnung.
Ich gehe davon aus, dass er richtig eingestellt war. Kann man das mit der Software sehen? Gibt es Mittel mit denen man prĂŒfen kann? Leider bin ich kein Mechaniker. Ich möchte sehr diesen Leuten helfen. Ich warte jede Sekunde auf euren Rat.
| Description: |
| MotorsteuergerÀt TDI AVB |
| File size: |
1.27 MB |
| Viewed: |
1835 times |
| Description: |
| File size: |
1.81 MB |
| Viewed: |
4419 times |
AlexanderRichert
20-03-2016, 18:16 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Ich habe am SteuergerĂ€t Stecker ausgemessen. Zwischen braun mit grĂŒnem Strich und jedem Draht die zu EinspritzdĂŒsen gehen 0,2 Ohm. Ist das in Ordnung?
AlexanderRichert
20-03-2016, 19:39 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] ZĂŒndzeit
| Description: |
| File size: |
182.64 KB |
| Viewed: |
2080 times |
| Description: |
| File size: |
151.34 KB |
| Viewed: |
1580 times |
AlexanderRichert
20-03-2016, 19:55 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Kann jemand damit etwas anfangen?
20-03-2016, 20:24 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Quote: | | Da ist der Schlauch zur Hochdruckpumpe. Nach der Pumpe kann ich nicht messen. Ist es möglich, das durch die Software rauslesen? |
Leider nicht. Der OBD-2 ZĂŒndzeitpunkt ist leider ohne Aussage.
Du kannst im MotorsteuergerĂ€t schauen, welche KĂŒhlmitteltemperatur ( Messwertblock 7 ) angezeigt wird, diese sollte stimmen. Achtung, bei zu hohen vom MotorsteuergerĂ€t gemessenen KĂŒhlmitteltemperaturen reichen die im Screenshot angezeigten rund 190rpm NICHT fĂŒr eine Startfreigabe.
FĂŒr weitere Versuche solltest Du fĂŒr maximale Startmenge den Stecker vom KĂŒhlmitteltemperaturgeber abgezogen lassen.
Zu den PD-Magnetventilen:
Quote: | 018,0,Magnetventilstatus
; 000 = Fehlerfreie Regelung
; 002 = Regelung wÀhrend Anlassvorgang
; 004 = Kleine Einspritzmenge oder Ventil AUS
; 008 = Energiegrenzen/maximaler Strom erreicht
; 014 = Spule des Einspritzventils: Kurzschluss nach Masse
; 016 = VentilschlieĂzeit (Begin of Injection Period = BIP) unplausibel (auĂerhalb Regelfenster)
; 032 = Zahl der Abtastungen zu klein
; 064 = Wandlungsfehler
; 128 = Keine SchlieĂzeitidentifikation (Begin of Injection Period = BIP) möglich (Motor AUS ODER elektr. Fehler) |
AlexanderRichert
dieselschrauber and Steffen W likes this. |
20-03-2016, 23:00 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Was wurde genau alles am Motor gewechselt? Nur der Block, oder auch der Kopf inkl. PDE?
Nicht, dass da am Ende die falschen PDE drinstecken!
Profile PM Garage |
AlexanderRichert
21-03-2016, 8:54 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Danke fĂŒr die Infos. TatsĂ€chlich wurden Motorblock mit Zylinderkopf und PDE ausgetauscht. MotorsteuergerĂ€t ist noch alt. Problem ist wie finde ich raus ob die DĂŒsen kompatibel sind zum SteuergerĂ€t? Gibt es eine Regel? Ich dachte auch warum gehen Magnetventile auf Zustand 8.0
Kann man das optisch erkennen?
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
21-03-2016, 9:07 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Moin,
den Kraftstoffdruck im Vorlauf kannst Du bei dem Motor nicht per OBD prĂŒfen.DafĂŒr brauchst Du ein Manometer mit passendem Anschluss.An der Tandempumpe ist hinten ein PrĂŒfanschluss.Du musst die Verschlussschraube entfernen und dann das Manometer anklemmen.DafĂŒr muss beim Passat 3BG das Ladeluftrohr raus.Allerdings sind nur Sollwerte bei bestimmten Motordrehzahlen bekannt.Der Motor muss also dafĂŒr laufen.Zuvor repariere aber die undichte Stelle am Filter von der Du geschrieben hast.
Ich habe mir mal erlaubt,ein Bild von dem Manometer anzuhÀngen damit Du eine ungefÀhre Vorstellung hast.Das Teil heisst VAS 5187.
Ferner kannst Du den Widerstand zwischen den den beiden Kontakten an den Pumpe DĂŒse Einheiten messen.Das Soll liegt bei 0,5 Ohm.Weiterhin sind am Kabelbaum im Zylinderkopf fĂŒr jeden Injektor jeweils ein braunes und ein buntes Kabel.Ziehe die Pumpe DĂŒse Stecker ab und miss die Spannung zwischen jeden braunem Kabel und Masse.(Zylinderkopf) bei eingeschalteter ZĂŒndung.Soll ist 0,1-0,4 Volt.Hinterher den Fehler wieder rauslöschen der dabei zwangslĂ€ufig gesetzt wird.
Dann kannst Du noch nach KabelbrĂŒchen von der PDE zum SteuergerĂ€t suchen.Das ist aber erfahrungsgemĂ€ss bei dem Modell unwahrscheinlich.
Wenn ihr das SteuergerÀt austauscht,wie lernt ihr das an?Hast Du den PIN der Wegfahrsperre?
Zahnriemen ist auch korrekt drauf?
Sehr wichtig aber finde ich das Posting vom Vorredner.Pumpe DĂŒse Einheiten der Generation 1.1 und 1.3 sehen identisch aus und passen problemlos untereinander.Aber die elektrische Komponente ist nicht kompatibel.Wenn man die in ein Auto baut,wo sie nicht hereingehören,dann gibt es Probleme.Das reicht von nicht anspringen bis unrundem Lauf.Das kann ich aber schnell checken wenn Du mir die Fahrgst Nr vom Auto und die Teilenummer der Injektoren schickst.Muss nur der Ventildeckel runter.Die steht auf dem Magnetventil.Siehe Bild.
| Description: |
| File size: |
15.17 KB |
| Viewed: |
1360 times |
| Description: |
| Manometer Tandempumpe 8Ventiler |
| File size: |
16.75 KB |
| Viewed: |
1758 times |
Passat Variant BGW 2005
21-03-2016, 10:13 Subject: Passat B5 Magnetventil status 2.0, then 6.0 and 8.0 |
Translating... |
[Translating...] Code: | | Wenn ihr das SteuergerÀt austauscht,wie lernt ihr das an?Hast Du den PIN der Wegfahrsperre? |
davon abgesehen fallen mir wenig GrĂŒnde fĂŒr einen plötzlichen Defekt des MotorsteuergerĂ€ts ein - der Motor wird ja kaum bei eingeschalteter ZĂŒndung gewechselt worden sein.
