Golf 4 1.9 TDI Automatic R won't start.
Cr4sh
Registered VCDS User
Post28-02-2016, 12:06    Subject: Golf 4 1.9 TDI Automatic R won't start. Quote
Since this morning, the reverse gear on my Golf 4 1.9 TDI Tiptronic no longer works. You can briefly notice that it's a bit jerky, like when he's putting it in or something, but then it's just idling.
Through Google, I've seen that there could be issues with the solenoid valve, cold solder joint, or a completely failed component. The error memory is empty. What I notice is that whenever I read out the data blocks, errors keep appearing, and it says that the blocks are not available. If I click on "Start", they reappear briefly and then disappear again.
How can I best start the troubleshooting process without immediately contacting the transmission manufacturer?
He doesn't put the car in gear, and if I'm in "R", I can push the car around like it's in neutral.
Which metric blocks might provide you with some insights?
Post28-04-2016, 13:04    Subject: Golf 4 1.9 TDI Automatic R won't start. Quote
With a car scan, this question could have been answered, as it would then be known which gear shift control it is. icon_cool.gif
Post28-04-2016, 14:57    Subject: Golf 4 1.9 TDI Automatic R won't start. Quote
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Lupo 3.0 TDI automatic shuts off while driving. Diesel Engine Technology
No new posts Golf 6 horn not working Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
No new posts A6 4B Automatik Probleme, schaltet selbständig oder nicht On-Board Diagnostics (OBD)
