Opel Z17DTJ Diesel: Valve Clearance Adjustment
ctrlaltdel
Post18-05-2016, 22:16    Subject: Opel Z17DTJ Diesel: Valve Clearance Adjustment Quote
Hello everyone,
This is my first post. If I violate any forum rules or netiquette, please let me know. I couldn't find anything relevant in the search or in the articles.
Subject:
I checked the valve clearances on my Astra H (manufactured in 2009, engine type: Z17DTJ 81kW) during the 150,000 km service. According to the documentation, the standard range is 0.4mm +/- 0.05mm. However, the first intake valve has a clearance of 0.3mm (a 0.35mm feeler gauge definitely doesn't fit), while all other valve clearances are within the standard range.
The game is stopped by the valve lifters. To replace them, the injectors and camshafts must be removed.
Two mechanic friends have recommended that I leave the valve clearance as the measured value (specifically for an intake valve), as they believe this value is acceptable. I am inclined to follow their recommendations because I am hesitant to proceed with the work.
What is your opinion on this? I understand that, according to the technical documentation, the game needs to be modified, but I'm interested in the personal opinions of the people present.
Translated on 22-10-2026, 1:51.
ctrlaltdel likes this.
Post18-05-2016, 22:32    Subject: Opel Z17DTJ Diesel: Valve Clearance Adjustment Quote
As you mentioned, from a technical perspective, something should happen, but I would also consider it sufficient to stop there, given the amount of work involved.
5/100 are definitely still acceptable. icon_wink.gif
Translated on 22-10-2026, 1:53.
ctrlaltdel
Post18-05-2016, 22:38    Subject: Opel Z17DTJ Diesel: Valve Clearance Adjustment Quote
That was fast. Thank you!
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Diesel Particulate Filter Problems Opel Vectra 2006 Diesel Engine Technology
No new posts Opel LMM vs. VW: Vergleich & Unterschiede Diesel Engine Technology
No new posts VAG-COM for Opel? On-Board Diagnostics (OBD)
No new posts Opel: DTI 2.0 Diesel Engine Technology
