Re: Lederlenkrad nachrüsten trotz Airbag
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Markus H.
Post17-05-2003, 23:58    Subject: Quote
regarding the term 'retrofitting':
Is the speedometer, which goes up to 260 km/h, also an aftermarket addition, or is the AXR engine so good (when it's not at the workshop) that it needs something like that as standard equipment? icon_lol.gif
I just don't understand Volkswagen anymore.
My 1Z had a speedometer that went up to 200 km/h, which was sometimes, unfortunately not often enough.
Now they're definitely overdoing it a bit.
Translated on 23-07-2026, 14:31.
kenny
Post18-05-2003, 0:58    Subject: Quote
All new speedometers go up to 260 km/h, but it's likely that no TDI will exceed 220 km/h icon_wink.gif.
Translated on 23-07-2026, 14:33.
Avatar-Jan6K
Post18-05-2003, 10:56    Subject: Quote
I already found that annoying in my parents' 1.8T car... because even if the car could theoretically reach 240 km/h on the speedometer, what's the point of it? It only reduces the readability of the part of the scale that you actually use.
While it seems to me that the distances "below" are larger (which makes sense), still...
"I'm certainly glad that Seat didn't do that with the 6K model... it only goes up to 220 km/h, which probably wouldn't be achievable on extremely steep hills without a chip, because realistically, it would likely be closer to 210 km/h."
Do they really do that in *every* new Volkswagen? Even in a Lupo with 50 horsepower or the base-model Polo with 64 horsepower? That would be absolutely ridiculous...
Jan.
1Z5 CFHF / AHB H4D
Translated on 23-07-2026, 14:35.
Gremlin
Post18-05-2003, 11:46    Subject: Quote
Okay, so in my ALH automatic Octavia, it only goes up to 220 km/h. That's already quite high considering the registered speed is 180 km/h icon_wink.gif.
http://www.ralfhandel.de/tacho.jpg
CU Gremlin.
Translated on 23-07-2026, 14:37.
kenny
Post18-05-2003, 16:23    Subject: Quote
All the Golf and Passat TDI models I've seen that are from the year 2001 or later reach speeds up to 260 km/h. A Golf SDI reaches up to 220 km/h, like it used to. However, I'm not sure if that particular car is actually from the year 2000, and whether that makes a difference...
@Bertil: How does the leather feel? I have a Golf Highline with a leather steering wheel, but in the past, the leather was relatively hard and grainy. Today, the leather is much thicker and very soft. I like the feel of it much better...
Translated on 23-07-2026, 14:38.
Gremlin
Post18-05-2003, 17:15    Subject: Quote
All the Golf and Passat TDI models I've seen that are from MY2001 or later go up to 260 km/h. A Golf SDI goes up to 220 km/h, like before, but I'm not sure if that car is actually from MY2000, and whether that makes a difference...
I don't have a manual transmission available right now, but mine is from the year 2002 (model year 2003). I'll take a look when I get the chance icon_smile.gif.
Cu Gremlin (with leather multi-function lever).
Translated on 23-07-2026, 14:40.
Post18-05-2003, 18:47    Subject: Quote
Hi Kenny,
kenny wrote:
@BertilViewing profile: Bertil: How does the leather feel? I have a Golf Highline with a leather steering wheel, but in the past, the leather was relatively hard and grainy. Today, the leather is much thicker and very soft. I like the feel of it much better...
"The leather is beautifully soft, especially the cowhide. I particularly like the thickness of the steering wheel now. It's not that I think the standard steering wheel is too thin, but with the leather cover, it becomes much more grippy and comfortable. Also, the unpleasant burning sensation in your hands when it's sunny is gone. And in cold weather, the leather warms up faster."
I did the same thing with my first car, and now my father is using that steering wheel in his 3-series after 5 years.
The speedometer is standard equipment. My aftermarket speedometer also only goes up to 220 km/h.
By the way, since the last repair, everything has been quiet and there's no more smell (hopefully it stays that way!).
Translated on 23-07-2026, 14:42.
davidshoes
Karma: +6 / -2   Thank you, like it!
Post18-05-2003, 20:57    Subject: Quote
It's likely a standardized parts strategy. The same speedometer is used for almost all models, regardless of whether it's a 1.9 SDI or a 1.8T engine.
Translated on 23-07-2026, 14:44.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lederlenkrad durchgewetzt - Möglichkeiten der Restauration Transmission, Chassis, Body & Interior
No new posts Power loss in TDI engine despite maximum speed Diesel Engine Technology
No new posts Oil in LL circuit despite crankshaft bypass. Diesel Engine Technology
No new posts Error log entries despite normal function Electrical Systems, Vehicle Electronics, Multimedia
