Stabilizer Rod VW Golf 3: Questions & Answers
bindpe
Karma: +5 / -2   Thank you, like it!
Post25-06-2016, 20:03    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Hello.
I'm currently in the process of replacing the stabilizer links on my VW Golf 3.
"I recently purchased new clay tools from Lehmförderer, but unfortunately, I only realized after unpacking them that they are not split into two pieces and are open on one side."
Is this intentional or a manufacturing defect? Can these be cut like the originals?
Thank you for your help.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 01-08-2026, 16:18.
vag-driver
Post25-06-2016, 21:45    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Are you sure that's the correct part? I wouldn't cut it. Otherwise, your only option is to detach the stabilizer bar from the control arm and slide the closed end through.
Andreas
Translated on 01-08-2026, 16:19.
bindpe
Post26-06-2016, 7:49    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Thank you for the response.
Yes, that is the correct part number.
I don't think I can postpone this; the shaft is very securely held in place up to where the bearing sits. Also, the original bearings are split into two pieces.
Spritmonitor.de
Translated on 01-08-2026, 16:20.
Post26-06-2016, 12:30    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
"These are the correct parts, and they can be installed. You need to use some force and it's a bit fiddly, but it's doable. I recently did this on a 1998 Volkswagen Golf 3 Variant."
bindpe
Post26-06-2016, 17:02    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Hello Ruedi,
Thank you for the information.
"How exactly did you do it then? The stabilizer is quite angled, and mine is covered in rust."
Did you push the rubber first and then the metal sheet?
Thank you.
Spritmonitor.de
Translated on 01-08-2026, 16:21.
vag-driver
dieselschrauber likes this.
Post27-06-2016, 6:36    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
First, remove any loose flakes and lightly sand the relevant areas. Then, lubricate with grease, silicone spray, or whatever is available and provides good lubrication, and position the bearing in the desired location.
If you have Mike Sanders grease, you can use it to treat the stabilizer and protect it from rust.
Andreas
Translated on 01-08-2026, 16:22.
bindpe
Post28-06-2016, 6:54    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Hello.
Could it be that you are referring to the tie rods?
I mean these parts:
There's no way to postpone this or to get it back in place between the engine mount and the underbody.
Spritmonitor.de
Translated on 01-08-2026, 16:23.
Post28-06-2016, 9:27    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
bindpe wrote:
Hello.
I mean these parts:
No chance to postpone it or to somehow get it back in there between the engine mount and the underbody.
Posting an image with the logo or copyright of another website is already rude.
bindpe
Post28-06-2016, 10:01    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Sorry.
I didn't even look at it.
I'm sorry.
Spritmonitor.de
Translated on 01-08-2026, 16:24.
vag-driver
Post28-06-2016, 15:05    Subject: Stabilizer Rod VW Golf 3: Questions & Answers Quote
Then take a picture of the electronic component you want to install and upload it.
Andreas
Translated on 01-08-2026, 16:25.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Frage vom Neuling: AAZ Lader auf 1,6l TD ( Golf 2) Diesel Engine Technology
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
No new posts MWB 11: Questions and Answers On-Board Diagnostics (OBD)
No new posts Question about the AGR system in the ACV/T4 (Sorry) Diesel Engine Technology
