Remove Rust from Rear Axle
blackblizzard
Post01-08-2016, 22:04    Subject: Remove Rust from Rear Axle Quote
Evening.
I would like to remove the rust from the rear axle of my VW Tiguan 4Motion.
Does anyone have a suggestion on how to do this in a semi-professional way? I've read a lot online, but I'm still confused.
Can you recommend any good products (perhaps with processing instructions)?
Translated on 11-10-2026, 1:07.
Karma: +590 / -0   Thank you, like it!
Post01-08-2016, 22:24    Subject: Remove Rust from Rear Axle Quote
Hello!
What is the current situation, and what is the goal?
I've always just roughly cleaned them and properly preserved them for my cars so far.
And then, every 1-2 years, make some adjustments as needed.
Translated on 11-10-2026, 1:08.
blackblizzard
Post01-08-2016, 23:04    Subject: Remove Rust from Rear Axle Quote
Unlike everything else, the HA looks wild (4motion problem?).
My goal is to slow down the rust corrosion with minimal effort. Since everything is already quite rusty, a simple preservation treatment alone won't be enough.
I don't want to take everything apart and meticulously paint each piece.
I'm looking for a "healthy" compromise. Making small improvements each year isn't a problem, as long as I don't have to scrape everything off and reapply it all again.
pax
Avatar-pax
2000 Volkswagen Passat
Post02-08-2016, 21:39    Subject: Remove Rust from Rear Axle Quote
Just apply some Owatrol and it's good to go...
http://www.korrosionsschutz-depot.de/media/pdf/owatrol.pdf
Bye.
peace
Translated on 11-10-2026, 1:09.
jarobaldu
Karma: +40 / -0   Thank you, like it!
dieselschrauber likes this.
Post03-08-2016, 10:50    Subject: Remove Rust from Rear Axle Quote
My recommendation is Liqui Moly rope grease.
Available as a liquid for brushing or as a spray.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 11-10-2026, 1:10.
Post06-08-2016, 12:04    Subject: Remove Rust from Rear Axle Quote
The problem with this axle design is that it rusts from the top, and you can't fix it without removing it.
"I'm experiencing the same problem with my A4 Quattro. I bought a complete rear axle in usable condition for 70 euros (including brake calipers, driveshaft, and axles). I'm going to overhaul it, addressing any rust issues, applying a protective coating, and completely reconditioning it. Then, I'll replace it if necessary."
vag-driver
Post08-08-2016, 13:39    Subject: Remove Rust from Rear Axle Quote
Rüdi wrote:
The problem with this axle construction is that it rusts from the top, and you can't fix it without taking it apart.
Not even with a spray nozzle?
Back to the topic:
For the spindle, I recommend "KLine Permanent Wax".
Andreas
Translated on 11-10-2026, 1:11.
hti
Post09-08-2016, 2:14    Subject: Remove Rust from Rear Axle Quote
http://www.oldtimer-markt.de/sites/default/files/oldtimer_markt_rostschutz-test_teil_1.pdf
http://www.oldtimer-markt.de/sites/default/files/oldtimer_markt_rostschutz-test_teil_2_1.pdf
http://www.oldtimer-markt.de/sites/default/files/oldtimer_markt_rostschutz-test_teil_3.pdf
Many products in the ultimate test.
There's something for everyone.
I'm sorry, I can't translate that. It appears to be a string of random characters. Please provide a complete sentence or paragraph for me to translate.
Astra G, X20DTL, 250.000 km
Golf II, 1.3, NZ, 500.000 km
Translated on 11-10-2026, 1:12.
Post10-08-2016, 11:06    Subject: Remove Rust from Rear Axle Quote
vag-driver wrote:
The problem with this axle construction is that it rusts from the top, and you can't fix it without removing it.
I highly doubt that this will remove rust, and what's the point of preserving rust? Either you do it properly, or you don't do it at all. And to do it properly, you need to remove the axle.
Translated on 11-10-2026, 1:13.
Karma: +1099 / -0   Thank you, like it!
Post10-08-2016, 11:17    Subject: Remove Rust from Rear Axle Quote
Remove loose rust mechanically, degrease, and apply Nigrin Rust-Stop permanently! This product can also be sprayed on. It takes time to develop its effect - better a day longer than rushing and applying it for too short a time. After the chemical reaction is complete, it forms a black to black-purple shimmering layer that already provides a non-sandable base coat on which a classic paint application could begin. If that's not possible or doesn't make sense, you could at least now apply a preservative grease and fight the rust. However, don't forget that surfaces preserved with grease are exposed to environmental influences such as water, sandblasting, etc., and require occasional attention. The grease film should definitely be maintained completely in those areas.
Translated on 11-10-2026, 1:14.
vag-driver
Post10-08-2016, 12:08    Subject: Remove Rust from Rear Axle Quote
Rüdi wrote:
I highly doubt that this will remove rust, and what's the point of preserving rust? Either you do it properly, or you don't do it at all. And to do it properly, you only need to remove the axle.
I have to disagree with you. Of course, it's better to remove the rust from the scales with a brush. However, it can also be done with Owatrol. Treat the affected areas more frequently until the rust is completely saturated. Then, for example, apply a sealant like K-Line. Believe me, this treatment will lead to a good result without having to remove the axle.
Andreas
Translated on 11-10-2026, 1:16.
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K bis 03/98, Geräusche von der Hinterachse Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Rear-axle Beetle Transmission, Chassis, Body & Interior
No new posts Rear Axle Noise Audi A4 B5 Transmission, Chassis, Body & Interior
No new posts GTI Rear Axle: Golf 3 Disc Brakes Transmission, Chassis, Body & Interior
