Coupling including. ZMS for Golf 3 AFN
Jaak
Post30-06-2016, 9:29    Subject: Coupling including. ZMS for Golf 3 AFN Quote
Good day,
Since I'm in the process of upgrading my 1997 Golf 3, I signed up here for all the information. icon_smile_thumb_up.gif
I have been dealing with the clutch since yesterday and am now confused by the variety of clutch options available. Either I find the 220mm coupling or the 228mm coupling.
Available options:
220mm Coupling (from factory)
228mm Coupling (as per) Spot trading (also auch suitable for)
Since I found an affordable Sachs 228mm clutch set ( including ZMS ), I wanted to know if it would fit without any problems. On the internet, you generally don't find very helpful posts, because they mostly focus on tuning rather than the clutch.
I don't want to install an EMS, or do anything else to significantly modify it.
Golf Data:
Golf 3 Cabrio, manufactured in 1997
AFN Motor / CYP Gearbox (5-speed)
Thank you for your help,
Jacques
Post30-06-2016, 12:05    Subject: Coupling including. ZMS for Golf 3 AFN Translating...
[Translating...]
Poste doch mal die Nummern von deinem Wunsch Set.
Jaak
Post30-06-2016, 12:39    Subject: Coupling including. ZMS for Golf 3 AFN Translating...
[Translating...]
hier habe ich mal eine Auswahl :
SACHS 3000 951 005
=> 220 mm => dafür finde ich nirgendwo (im Netz) ein ZMS
SACHS 3000 951 790
=> das wäre preislich am interessantesten ABER 228mm!
Ich habe zur Sicherheit heute morgen auch noch einmal bei VW angerufen, mein 3er hat laut AKTE eine 220mm Kupplung.
Natuerlich koennte ich das ZMS nun auch sein lassen, aber wenn sowieso alles offen ist.
Bei einem LUK Repsatz lassen sich nirgendwo die MM Angaben finden.
LuK Kupplungssatz 600 0006 00
MfG
MatzeHH
Post12-07-2016, 19:55    Subject: Coupling including. ZMS for Golf 3 AFN Translating...
[Translating...]Besteht die Möglichkeit auf ems umbauen
DieselBär30x
Avatar-DieselBär30x
Post12-07-2016, 20:16    Subject: Re: Clutch incl. ZMS for Golf 3 AFN Quote
Is this a question or a statement?
Do you use punctuation?
Jaak wrote:
I don't want to install an EMS, nor do I want to make any other major modifications. ...
As a matter of fact: Those who can read are usually at a clear advantage icon_smile_thumb_up.gif
Best regards from Munich!
PS: Pointlessly wasting time doesn't actually make you more popular *aside note*
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with clutch/starter motor, Golf 4 TDI Transmission, Chassis, Body & Interior
No new posts Golf TDI: Upgrade Clutch for More Power Diesel Engine Technology
No new posts Golf III TD Clutch: Durability & Reviews Diesel Engine Technology
No new posts Clutch Slipping Golf 4 TDI ALH - Fix It! Diesel Engine Technology
