Volkswagen Golf 3, 1999, Immobilizer
F B
Post09-08-2016, 8:04    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
Hi.
Just a quick question.
How does the immobilizer system manifest itself in the above-mentioned vehicle when the wrong key is used or the signal is not recognized?
No spark when starting.
or
Starts and shuts off after 1 second?
Best regards, Frank.
Post09-08-2016, 9:00    Subject: Subject: Golf 3, 1999, Immobilizer Quote
F B wrote:
Starts and turns off after 1 second?
That's exactly what it is.
Furthermore, one could potentially see an interfering WFS (Working Function Specification) through the diagnosis of the corresponding TCU (Telecommunication Control Unit). icon_wink.gif
F B
Post09-08-2016, 15:07    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
Thank you.
Then it's not the immobilizer that's causing the problem with this car.
It's working again now, after a few failed attempts, as if nothing happened.
The error log is otherwise empty.
I therefore suspect the Hall sensor in the distributor.
He had announced his presence at another polo match in the same way...
Would an error appear in the VCDS log for that?
Post09-08-2016, 15:18    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
F B wrote:
Would an error appear in the Vcds log file in that case?
If the engine control unit detects the defective sensor: Yes. icon_idea.gif
dieselschrauber likes this.
Post09-08-2016, 15:32    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
"Hall sensor no signal" is generally logged as an error in older MSTG (Motor Steuergerät - Engine Control Unit) systems. This occurs when the ignition is on, but the engine is not running, because the Hall sensor cannot provide a signal in that state. The error can be cleared while the engine is running, but it will reappear after the next start.
"In newer engine control units (ECUs), this 'weakness' has been addressed. Consequently, errors are less likely to occur, even if there is a defect. This is because the ECU, lacking a second sensor, can struggle to distinguish between a situation where the engine is simply off and a situation where the Hall sensor is faulty, as both would result in a lack of signal." Here, manual troubleshooting is required; the error memory is not very helpful. icon_wink.gif
F B
Post10-08-2016, 2:31    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
Yes, thank you, that's enough for my enlightenment.
Wonderful explanation.
Okay, let's just order a distributor, even if we're not entirely sure we need it.
Karma: +647 / -0   Thank you, like it!
Post10-08-2016, 10:09    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
"Another thing to check would be the ignition coil. We recently had a Passat 35i with an ABS engine that was having this problem – sometimes it would start, sometimes it wouldn't. We replaced the ignition coil, and everything was fine."
Back in the days when I used to drive gasoline cars, I always kept a can of gasoline in the trunk as a reserve.
F B
Post15-08-2016, 6:28    Subject: Solved Quote
It was the distributor, or rather, its Hall sensor.
It cost 25 euros at Schrotti's, and the thing is running again.
Thank you.
Post15-08-2016, 8:11    Subject: Volkswagen Golf 3, 1999, Immobilizer Quote
No new posts Golf, Bora combination instrument panel, 1998 to 04.1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Window Scratches: Repair Guide (8L '99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production date up to 10/1999, dents on t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Window Regulator Coding VW Golf IV (1999) On-Board Diagnostics (OBD)
No new posts Immobilizer for VW Golf 3 TDI 1Z On-Board Diagnostics (OBD)
No new posts VW Golf 3 Immobilizer Wiring Diagram - 1994 Diesel Engine Technology
No new posts Fuel Injector Pump for Audi A3 1.9 TDI (ALH) Manual Diesel Engine Technology
