thommen Blaumann
17-07-2016, 9:52 Subject: ESP Wiring Harness for AFN TDI Engine |
Unfortunately, I'm having a problem where the engine (AFN TDI) of my beloved convertible won't start after I replaced the ESP (Electronic Stability Program).
We've already tried quite a few things, but nothing seems to work. The suspicion now is that the problem might be with the wiring harness (possibly a broken cable or something, as the individual cables are really in bad condition).
"Can anyone tell me if this wiring harness is available separately, or if there's a repair kit for it? Specifically, it's the wiring harness that runs from the 3-pin connector on the ESP."
Can it be replaced individually, or are there any bigger issues involved?
I would be grateful for any help, best regards.
Translated on 18-09-2026, 5:40.
thommen Blaumann
17-07-2016, 10:42 Subject: ESP Wiring Harness for AFN TDI Engine |
"Does anyone perhaps have the part number for the engine wiring harness where the ESP connectors are attached? I would simply replace the entire harness."
Translated on 18-09-2026, 5:41.
Herbert Profi-Schrauber
17-07-2016, 12:45 Subject: ESP Wiring Harness for AFN TDI Engine |
Starting to address the problem with the wiring harness without proper visibility is not necessarily the most effective approach.
You would have to replace the entire engine wiring harness, and those are probably no longer available new. I don't even want to talk about the amount of labor involved.
First, I would measure the input/output contacts on the ESP connectors.
Is RLF available for the injection system?
Selbstverständlich gehört auch ein Auslesen des MSG und der relevanten Meßwertblöcke dazu. VCDIs S available?
Translated on 18-09-2026, 5:42.
Uli S. Schrauber
Joined: 07/02/2003 Posts: 338 Karma: +7 / -0 Location: Äußerster Südwesten
19-07-2016, 11:18 Subject: TDI ESP Wiring Harness: AFN Model |
thommen wrote: | | Unfortunately, I'm having a problem where the engine (AFN TDI) of my beloved convertible won't start after replacing the ESP. |
ja, sowas kommt vor. Habt Ihr die Einspritzleitungen entlüftet? Fördert die Pumpe Kraftstoff? SDoes ELAB handle that?
Quote: | | We have already tried quite a few things, but nothing seems to work. |
What exactly?
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 18-09-2026, 5:43.
