Hello everyone
I am now the proud owner of a new Seat Alhambra 7N, which I've had for the past week.
I was really excited to perform some coding operations using my new Micro-Can diagnostic interface (latest version from the shop). However, unfortunately, I have a small problem.
For some individual devices, I was able to implement the desired adjustments, but for most, the message "Vehicle/Model not supported" appears.
For example, accessing STG42 and STG52 functions correctly. The field 'Encoding – 07' appears, and adjustments can be encoded and saved. When accessing STG08, 09, 17, etc., the aforementioned error message always appears, and besides the fields 'Error codes – 02', 'Extended ID – 1A', and 'Individual measurement value – 09', nothing else can be selected.
I have also tried all the USB ports – the same effect every time. The LED is lit green and the car scan is working perfectly.
Does anyone have any ideas what it could be? Am I making a typical beginner's mistake?
Thank you in advance for your help.
Many greetings from Lake Zurich
Urs
Autoscan:
VCDS Version: RKS 15.7.4 runs on Windows 10 x64
Data Status: 20160602
Wednesday, 27, July, 2016, 17:16:33:38306
Vehicle Type: 7N (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 3C 42 44 46 4C 4F
52 53 55 5F 61 62 6C 6D 72 A5 BE BF
Vehicle Identification Number: VSSZZZ7NZHV702210
01-Engine Electronics -- Status: OK. 0000
02-Transmission -- Status: OK. 0000
03-Brake Electronics -- Status: OK 0000
04-Steering Angle Sensor -- Status: OK 0000
05-Access/Start Report -- Status: OK 0000
08-Climate/Heating System -- Status: OK 0000
09-Main Electrical System -- Status: OK 0000
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel electronics -- Status: OK 0000
17-Switch Panel Insert -- Status: OK 0000
18-Stand Heater -- Status: OK 0000
19-Diagnosis Interface -- Status: OK 0000
25-Way Ignition Switch -- Status: OK 0000
2B-Steering Column Lock -- Status: OK 0000
3C Lane Change -- Status: OK 0000
42-door electric Driver -- Status: OK 0000
44-Steering Aid -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4C Tire Pressure II -- Status: OK 0000
4F-Central Electrical II -- Status: OK 0000
52-door electric Passenger. -- Status: OK. 0000
53-Parking Brake -- Status: OK 0000
55-Light fixture regulator -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
61-Battery Control -- Status: OK 0000
62-door electric, right-hand drive -- Status: OK 0000
6C-Rear View Camera -- Status: OK 0000
6D Rear door -- Status: OK 0000
72-door electric high roof -- Status: OK 0000
A5 Front/Vorfeld Camera -- Status: OK 0000
BE-Rear left sliding door -- Status: OK 0000
Rear right BF sliding door -- Status: OK 0000
Address 01: Engine Electronics (J623-DFMA) Label file: None
Part Number SW: 04L 906 016 HK HW: 04L 907 309 K
Part Number: R4 2.0L EDC H20 1629
Revision: 8AH20---
Encoding: 011D003A042401083000
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016HK 001003
ROD: n.v.
VCID: 79D6B4EBF84CF0F639-802C
Vehicle/Model not supported.
No ASAM data available: "EV_ECM20TDI01104L906016HK" ()
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\02E-927-770.lbl
Part Number SW: 02E 300 063 C HW: 02E 927 770 AL
Part Number: GSG DSG AG6 540 4906
Revision: 06354004 Serial Number: 00001605150458
Encoding: 0000020
Operating Number: WSC 00020 790 00000
VCID: 160C9F5721123F8EB4-8042
Address 03: Brake Electronics (J104) Label file: DRV\5N0-614-109-V1.clb
Part Number SW: 5N0 614 109 CF HW: 5N0 614 109 CF
Part Number: ESC-EBC460iV1 H10 0013
Serial Number: A017CPR
Encoding: 12F0449A0920C26E0879480122C3904310391700F00B4995
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: n.v.
VCID: 71C68CCBA03CB8B681-8024
No ASAM data available: "EV_Brake1ESCEPBTRW" ()
Address 05: Access/Start Report (J518) Label file: DRV\5K0-959-434.clb
Part Number SW: 5K0 959 434 G HW: 5K0 959 434
Part Number: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial Number: 0406560436
Encoding: 03300C
Operating number: WSC 00020 999 39850
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: n.v.
VCID: 395674EBB8CC30F679-806C
No ASAM data available: "EV_KESSYPQ35G" ()
Address 08: Climate/Heating Control (J255) Label file: DRV\5K0-907-044.clb
Part Number SW: 7N0 907 044 AQ HW: 7N0 907 044 AQ
Part: Clima-Sharan H03 0606
Revision: 00001K05
Encoding: 021010C549
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: n.v.
VCID: 7F225AF3E668DEC607-802A
Subsystem 1 - Part Number SW: 7N0 907 049 C HW: 7N0 907 049 C
Part Number: KBT-H 004 0103
Serial Number: 20160603000000060879
No ASAM data available: "EV_ClimatronicSharan" ()
Address 09: Central Electrical (J519) Label file: DRV\1K0-937-08x-09.clb
Part Number SW: 5K0 937 086 T HW: 5K0 937 086 T
Part Number: BCM PQ35 M 122 0183
Revision: BC122001
Encoding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
Operating Number: WSC 00020 790 12345
VCID: 45AE081BCC3444160D-8010
Subsystem 1 - Part Number SW: 7N1 955 119 B HW: 7N1 955 119 B Label file: DRV\1KX-955-119.CLB
Part Number: WWS428 030516 024 0644
Encoding: 004DBD
Subsystem 2 - Part Number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Part Number: RLHS 042 0105
Encoding: 0228BB
Address 10: Parking Assist 2 (J791) Label file: DRV\1Q0-919-475.clb
Part Number SW: 7N0 919 475 E HW: 5Q0 919 298 C
Part Number: PLA 3.0 12KH08 0005
Serial Number: 000305183616159
Encoding: 0071167051
ASAM Dataset: EV_EPHVA3CVW428GP00 001005
ROD: n.v.
VCID: 3D5E60FBACE40CD655-8068
No ASAM data available: "EV_EPHVA3CVW428GP00" ()
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part Number SW: 7N0 959 655 D HW: 7N0 959 655 D
Part Number: VW10Airbag10X H15 0016
Serial Number: 003PWPB97DXT
Encoding: 003058
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: n.v.
VCID: 40A0190FDB16613E3E-8014
Subsystem 1 - Part Number SW: --- HW: ---
Part: S.Sens.Fahr.V --- ---
Serial Number: 3493ETS60D186A21C9D%
Encoding: 000000
Subsystem 2 - Part Number SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial Number: 3503ETS606F0FA21CDD3
Encoding: 000000
Subsystem 3 - Part Number SW: --- HW: ---
Part: S.Sens.Fahr.H --- ---
Serial Number: 3513ETS60B793A21CDD+
Encoding: 000000
Subsystem 4 - Part Number SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial Number: 3523ETS600D21A71C9DT
Encoding: 000000
Subsystem 5 - Part Number SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial Number: 35540TS60B836A81CDD-
Encoding: 000000
No ASAM data available: "EV_AirbaVW10TS6VW428" ()
Address 16: Steering Electronics (J527) Label file: DRV\5K0-953-569.clb
Part Number SW: 5K0 953 501 DQ HW: 5K0 953 569 AP
Part: STEERING MODULE 016 0180
Revision: FF010042 Serial Number: 20160607200898
Encoding: 3112240000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: n.v.
VCID: 7CD8ADFFF77EC5DE22-8028
Subsystem 1 - Part Number SW: 7N5 919 719 HW: 7N5 919 719 Label file: DRV\3C8-959-537.CLB
Part Number: E221__MFL-PR6 H04 0130
Serial Number: 000000000B1431180516
Encoding: 011000
No ASAM data available: "EV_VW360SteerWheelUDS" ()
Address 17: Relay Module (J285) Label file: DRV\5K0-920-xxx-17.clb
Part Number SW: 7N5 920 880 D HW: 7N5 920 880 D
Component: KOMBI H04 1104
Serial Number: 00000000000000
Encoding: 110F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: n.v.
No ASAM data available: "EV_Kombi_UDS_VDD_RM09" ()
Address 18: Auxiliary Heater Label file: DRV\1K0-815-007.clb
Part Number: 7N0 963 272 E
Part: Stand Heater 044 4941
Revision: 00044000 Serial Number: 09028239000000
Encoding: 0031142
VCID: 375272D346D826868F-8062
Address 19: Diagnostic Interface (J533) Label file: None
Part Number SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Part Number: J533 Gateway H56 1682
Revision: H56 Seriennummer: 030616F1000604
Encoding: 468232
VCID: 7BDAAEE3FA70C2E62B-802E
Address 25: Immobilizer (J334) Label file: DRV\5K0-920-xxx-25.clb
Part Number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 1104
Serial Number:
Encoding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: n.v.
VCID: 6AF49BA78DEA4B6EC0-803E
No ASAM data available: "EV_Immo_UDS_VDD_RM09" ()
Address 2B: Steering Column Lock (J764) Label file: DRV\5K0-905-861.clb
Part Number SW: 5K0 905 861 D HW: 5K0 905 861 D
Part Number: ELV-PQ35 H22 0240
Revision: 00000000 Serial Number: 16000053405002
Encoding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: n.v.
VCID: 31464CCB60BCF8B6C1-8064
No ASAM data available: "EV_ELVMarquMPVW36X" ()
Address 3C: Lane Change (J1086) Label file: None
Part Number SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Part: HRE_Master H12 0071
Serial Number: 0405596751
Encoding: 02011102
ASAM Dataset: EV_HREntryHella 001028
ROD: n.v.
VCID: 3C586DFFB7FE05DE62-8068
No ASAM data available: "EV_HREntryHella" ()
Address 42: Electrical Door Driver (J386) Label file: 7N0-959-793.clb
Part Number SW: 7N0 959 793 J HW: 7N0 959 793 G
Part Number: TSG FA H05 0561
Revision: Series Number: 0000201343157
Encoding: 01112F20D000411011
VCID: 49B6042BE02CA076E9-801C
Address 44: Steering Aid Label file: DRV\5N1-909-144.clb
Part Number SW: 5N1 909 144 S HW: 5N1 909 148 K
Part: J500__APA-BS CL.325 1501
Revision: 1BH04740 Serial Number: 00161380191901
Encoding: 0000258
VCID: 42A413071D1A732E28-8016
Address 4C: Tire Pressure II
unavailable
Address 4F: Central Electrical II (J520) Label file: DRV\1K0-907-532.clb
Part Number SW: 7N0 907 532 HW: 7N0 907 530 AN
Part: EZE_2 H56 1682
Encoding: 050A0100
VCID: 6FC28AB3BE08AE4697-803A
Subsystem 1 - Part Number SW: 7N0 959 591 B HW: 7N0 959 591 B
Part Number: J245EE04SKB03 H04 0090
Subsystem 2 - Part Number SW: 7N0 959 591 B HW: 7N0 959 591 B
Part Number: J394EE04SKB03 H04 0090
Address 52: Electrical Door Passenger. (J387) Label file: 7N0-959-792.clb
Part Number SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H05 0561
Revision: Seriennummer: 0000202298200
Encoding: 01112D20DE00411011
VCID: 48B0012FFB26597EF6-801C
Address 55: Light intensity control (J745) Label file: DRV\5M0-907-357-V3.clb
Part Number SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Revision: -------- Serial Number: --------------
Encoding: 068200000B000000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: n.v.
VCID: 375272D38ED826868F-8062
Subsystem 1 - Part Number SW: 1T0 941 329 B HW: 1T0 941 329 B Label file: 3D0-941-329.CLB
Part: LeiMo left H06 0009
Encoding: 3B0000
Subsystem 2 - Part Number SW: 1T0 941 329 B HW: 1T0 941 329 B Label file: 3D0-941-329.CLB
Part: LeiMo right H06 0009
Encoding: 3B0000
No ASAM data available: "EV_HeadlRegulVWAFSPt" ()
Address 5F: Information Selection. I (J794) Label file: None
Part Number SW: 7N5 035 680 C HW: 7N5 035 680 C
Part Number: MU-S-ND-ER H30 0351
Serial Number: SEZAZ2S5008941
Encoding: 04240801FF00000011111101008808001F0106C40020010086
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: n.v.
VCID: 334A46C39AA0CAA6B3-8066
Subsystem 1 - Part Number SW: 6P0 919 866 H HW: -----------
Part Number: ECE1 2016/17 --- 0635
Serial Number: --------------------
No ASAM data available: "EV_MUStd4CTSAT" ()
Address 61: Battery Control (J840) Label file: DRV\1K0-907-534.clb
Part Number SW: 7N0 907 534 HW: 7N0 907 530 AN
Part: Battery control H56 1682
Serial Number: 030616F1000604
Encoding: 030F1873
VCID: 71C68CCBA83CB8B681-8024
Subsystem 1 - Part Number SW: 1K0 915 181 L HW: 1K0 915 181 L
Part Number: J367-BDM H07 0270
Address 62: Door electrical switch, left (J388) Label file: 7N0-959-794.clb
Part Number SW: 7N0 959 794 L HW: 7N0 959 794 H
Part: TSG HL H03 0561
Revision: Series Number: 0000196160828
Encoding: 01006D200000411001
VCID: 4CB83D3FEF5EB55ED2-8018
Address 6C: Reverse Camera (J772) Label file: 5Q0-907-441.clb
Part Number SW: 7N0 907 441 B HW: 7N0 907 441 B
Part Number: VW428 RVC Mid H04 0040
Encoding: 012408012201000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: n.v.
VCID: 304049CF6BB6F1BECE-8064
No ASAM data available: "EV_CamSysRearPANAVW428" ()
Address 6D: Rear Door (J605) Label file: DRV\7N0-959-107.clb
Part Number SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG Module H11 0250
Revision: 41011001 Serial Number: 134600817
Encoding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: n.v.
VCID: 3B5A6EE3B2F002E66B-806E
No ASAM data available: "EV_HDSGVW428" ()
Address 72: Door electrical switch, right (J389) Label file: 7N0-959-794.clb
Part: TSG HR H03 0561
Revision: Series Number: 0000201187412
Address A5: Front/Vorfeld Camera (R242) Label file: DRV\3Q0-980-654.clb
Part Number SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H04 0220
Serial Number: 31051611K10840
Encoding: 030402080000040100261302C080400090000E100020
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: n.v.
VCID: 3A546BE7BDCA3BEE70-806E
No ASAM data available: "EV_MFKBoschMQBB" ()
Address BE: Rear left sliding door (J558) Label file: 7N0-959-244.clb
Part Number SW: 7N0 959 244 B HW: 7N0 959 244 B
Part: Sliding Door_l 005 2414
Serial Number: 16191309
ASAM Dataset: EV_AST A03704
ROD: n.v.
VCID: 385071EF83C629FE86-806C
No ASAM data available: "EV_AST" ()
Address BF: Rear right sliding door (J731) Label file: 7N0-959-244.clb
Part: Sliding Door_r 005 2414
Serial Number: 16191096
ROD: n.v.
Ende----------------------------(Duration: 03:43)-----------------------------
