blackblizzard Blaumann
01-08-2016, 21:04 Subject: Remove Rust from Rear Axle |
Evening.
I would like to remove the rust from the rear axle of my VW Tiguan 4Motion.
Does anyone have a suggestion on how to do this in a semi-professional way? I've read a lot online, but I'm still confused.
Can you recommend any good products (perhaps with processing instructions)?
Translated on 11-10-2026, 0:07.
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2560 Karma: +595 / -0 Location: bei Zwickau
01-08-2016, 21:24 Subject: Remove Rust from Rear Axle |
Hello!
What is the current situation, and what is the goal?
I've always just roughly cleaned them and properly preserved them for my cars so far.
And then, every 1-2 years, make some adjustments as needed. Grüße, Steffen!
Translated on 11-10-2026, 0:08.
01-08-2016, 22:04 Subject: Remove Rust from Rear Axle |
Unlike everything else, the HA looks wild (4motion problem?).
My goal is to slow down the rust corrosion with minimal effort. Since everything is already quite rusty, a simple preservation treatment alone won't be enough.
I don't want to take everything apart and meticulously paint each piece.
I'm looking for a "healthy" compromise. Making small improvements each year isn't a problem, as long as I don't have to scrape everything off and reapply it all again.
pax Profi-Schrauber
2000 Volkswagen Passat Support
Profile PM Garage |
jarobaldu Profi-Schrauber
dieselschrauber likes this. |
03-08-2016, 9:50 Subject: Remove Rust from Rear Axle |
My recommendation is Liqui Moly rope grease.
Available as a liquid for brushing or as a spray.
Adrian. Renault Espace 16V Bj. 2000 mit LPG
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 11-10-2026, 0:10.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
06-08-2016, 11:04 Subject: Remove Rust from Rear Axle |
The problem with this axle design is that it rusts from the top, and you can't fix it without removing it.
"I'm experiencing the same problem with my A4 Quattro. I bought a complete rear axle in usable condition for 70 euros (including brake calipers, driveshaft, and axles). I'm going to overhaul it, addressing any rust issues, applying a protective coating, and completely reconditioning it. Then, I'll replace it if necessary." Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
vag-driver Profi-Schrauber
08-08-2016, 12:39 Subject: Remove Rust from Rear Axle |
Rüdi wrote: | | The problem with this axle construction is that it rusts from the top, and you can't fix it without taking it apart. |
Not even with a spray nozzle?
Back to the topic:
For the spindle, I recommend "KLine Permanent Wax". Viele Grüße
Andreas
Translated on 11-10-2026, 0:11.
hti
Joined: 07/21/2016 Posts: 3 Karma: +0 / -0 Location: Hambühren
09-08-2016, 1:14 Subject: Remove Rust from Rear Axle |
Astra G, X20DTL, 250.000 km
Golf II, 1.3, NZ, 500.000 km
Translated on 11-10-2026, 0:12.
10-08-2016, 10:06 Subject: Remove Rust from Rear Axle |
vag-driver wrote: | The problem with this axle construction is that it rusts from the top, and you can't fix it without removing it. Rüdi wrote: |
I highly doubt that this will remove rust, and what's the point of preserving rust? Either you do it properly, or you don't do it at all. And to do it properly, you need to remove the axle. | Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 11-10-2026, 0:13.
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
10-08-2016, 10:17 Subject: Remove Rust from Rear Axle |
Remove loose rust mechanically, degrease, and apply Nigrin Rust-Stop permanently! This product can also be sprayed on. It takes time to develop its effect - better a day longer than rushing and applying it for too short a time. After the chemical reaction is complete, it forms a black to black-purple shimmering layer that already provides a non-sandable base coat on which a classic paint application could begin. If that's not possible or doesn't make sense, you could at least now apply a preservative grease and fight the rust. However, don't forget that surfaces preserved with grease are exposed to environmental influences such as water, sandblasting, etc., and require occasional attention. The grease film should definitely be maintained completely in those areas. Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
Translated on 11-10-2026, 0:14.
10-08-2016, 11:08 Subject: Remove Rust from Rear Axle |
Rüdi wrote: | vag-driver wrote: | Rüdi wrote: | | The problem with this axle construction is that it rusts from the top, and you can't fix it without removing it. |
I highly doubt that this will remove rust, and what's the point of preserving rust? Either you do it properly, or you don't do it at all. And to do it properly, you only need to remove the axle. |
I have to disagree with you. Of course, it's better to remove the rust from the scales with a brush. However, it can also be done with Owatrol. Treat the affected areas more frequently until the rust is completely saturated. Then, for example, apply a sealant like K-Line. Believe me, this treatment will lead to a good result without having to remove the axle. Viele Grüße
Andreas
Translated on 11-10-2026, 0:16.
