Steffen W wrote: |
and if you only replace the radio container?
You can program it using VCDS, and you don't need a login for that. It's also much cheaper. And it's not exclusively available at the dealership.
Furthermore, if completely new keys are absolutely necessary, you could also remove the transponders from the old keys and transfer them to the new keys. |
This would eliminate the need for the WFS (Whole Key System) as well. }
Replacing radio modules in the 4E system isn't straightforward because everything is still on a circuit board, and even the transponders are soldered onto that board.
Before I buy new keys, which cost CHF 250 here in Switzerland, I've decided to solder transponders onto used 4E remote key fobs. I will report back on whether it works.
