7-Speed DSG Golf Plus: Common Problems & Fixes
womisio
Post20-09-2016, 9:57    Subject: 7-Speed DSG Golf Plus: Common Problems & Fixes Quote
Hello everyone,
"I've been having the following problem with my Golf Plus since Friday."
It's a 1.6 TDI with 105 horsepower and a 7-speed DSG transmission.
So, without any noticeable hesitation or warning, the warning light on the dashboard (the key symbol) illuminated on Friday afternoon.
It's blinking on every display showing the walking distance!
"This isn't a service indicator; those are usually yellow!"
Here are the errors that were read out:
P189C: Function limitation - Insufficient pressure build-up.
P17BF Hydraulic pump, active clearance control.
P1895 Function restriction: Pressure drop.
Does anyone know what might be broken?
Sure, here's the translation:
"Thank you in advance."
"Womisio" is a Japanese word that means "what is this?". It is often used by children to ask about something they don't understand.
Translated on 13-10-2026, 11:56.
Post20-09-2016, 9:58    Subject: 7-Speed DSG Golf Plus: Common Problems & Fixes Quote
Posting a VCDS Autoscan would have been helpful, otherwise:
Translated on 13-10-2026, 11:58.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error 01435: Golf 1J MJ 2001 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf IV: ESP/ABS error On-Board Diagnostics (OBD)
No new posts ABS Error Golf 4 SDI: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Golf III TDI AHU: Common Problems & Fixes On-Board Diagnostics (OBD)
No new posts Golf IV 1.6 Problems / Issues On-Board Diagnostics (OBD)
