Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
21-09-2019, 11:25 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
For an Audi A3 8P, the wheel bearing housing, including the wheel bearing, needs to be replaced.
Does anyone know if the shock absorber/strut assembly can be separated from the wheel bearing without special tools?
Translated on 27-10-2026, 18:08.
Profile PM WWW Garage |
Herbert Profi-Schrauber
dieselschrauber likes this. |
21-09-2019, 11:41 Subject: Best German Recipes: Authentic & Easy |
Is this the version where the shock absorber is attached to the wheel bearing housing with a pin at the top?
Remove the clamping screw, apply Caramba, and if necessary, carefully widen the gap (without bending).
Translated on 27-10-2026, 18:09.
21-09-2019, 12:31 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Hello Herbert,
Okay, I think so.
Thank you, Rainer.
| Description: |
| File size: |
1.68 MB |
| Viewed: |
1064 times |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-09-2019, 8:37 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
The wheel bearing housing needs to be spread open in the slot. You can buy a 1/2" socket specifically for VW Golf V and similar models for a reasonable price. It's best to remove the entire shock absorber assembly. It's easier to do in a vise, but it's very important to blow out the 3 threaded holes where the strut mount is attached with compressed air from underneath. Then, soak them repeatedly with rust remover, and carefully unscrew the bolts. Try to avoid loosening the nuts at the bottom; if they do come loose, you'll need to weld them back on. It's a good idea to have new strut mounts on hand just in case.
Translated on 27-10-2026, 18:10.
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
24-09-2019, 19:41 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Evening.
To create a wedge, I filed the threads of an M10 screw to make them oval. It works very well and costs almost nothing.
If you need to adjust the camber on the control arm, you can use a special adjustment bolt, but a regular bolt can also be used for the connection.
Spray some oil into the rear slot; it will then slide more easily  .
Thilo.
Translated on 27-10-2026, 18:11.
Profile PM Garage |
26-09-2019, 17:33 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
It's possible, but even using a spreader is often borderline, especially if there's no third hand available to hold things in place.
My next investment is a spreader that is clamped in place using a split collet.
Translated on 27-10-2026, 18:12.
Profile PM Garage |
29-09-2019, 10:18 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Looking for experiences with wheel bearing housings from original Audi versus Vaico or other suppliers...
Are the positions of the attachment points absolutely identical compared to the original part?
| Description: |
| Radlagergehäuse Audi A3 8P |
| File size: |
1.68 MB |
| Viewed: |
379 times |
| Description: |
| File size: |
2.31 MB |
| Viewed: |
428 times |
Translated on 27-10-2026, 18:13.
vag-driver Profi-Schrauber
02-10-2019, 6:07 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
dieselschrauber wrote: | | Are the positions of the attachment points / mounting points absolutely identical compared to the original part? |
That's how it should be. Fortunately, I've never had any problems with premium providers in the aftermarket.
Andreas
02-10-2019, 16:56 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
vag-driver wrote: | Are the positions of the attachment points/mounting points absolutely identical compared to the original part? dieselschrauber wrote: |
That should be the case. Fortunately, I have never had any problems with premium providers in the aftermarket. |
Very well, because the price difference is a factor of 4, and furthermore, I don't want to buy spare parts from a place where they were too reluctant to do a repair. |
Translated on 27-10-2026, 18:14.
04-10-2019, 9:00 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
"Premium" is Lemförder, and then there's a long gap until anything else comes close.
Translated on 27-10-2026, 18:15.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
05-10-2019, 13:25 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Quote: | | Premium is Lemförder, and then there's a long gap......... |
Unfortunately, that's the case. TRW is also being discontinued and is partially original equipment.
You just don't know about the other providers.
As I mentioned before... I prefer to buy the original product when in doubt. It gives me peace of mind.
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
dieselschrauber and kiter likes this. |
08-10-2019, 14:32 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Hello.
I've been using almost exclusively TRW parts for the past while (about 1.5 years).
Axle parts, rubber bushings, control arms, tie rods, brake calipers, rotors/pads, and brake cables. The quality, workmanship, and fit were always identical to the original equipment (OE) part. With axle parts, the deviation after measurement was actually hardly measurable, or there was no need to correct it.
Mpire
Translated on 27-10-2026, 18:16.
Profile PM Garage |
kiter likes this. |
09-10-2019, 21:23 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Hello.
Assembly without calibration, the steering wheel is misaligned by 1-1.5 finger widths on the country road.  The steering gear is okay, but ABS/ESP errors disappear after driving a few hundred meters. }
Okay, I need to get the car aligned first, and then I'll see. Tomorrow, I'll try driving on a really straight road. It can't be that bad; the steering wheel on my A6 was even more off, completely crooked.
Thank you to all who provided suggestions!
Translated on 27-10-2026, 18:17.
13-10-2019, 17:51 Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber |
Thank you again to all the helpers, everything is okay now.
The steering was adjusted using a very simple string method, which worked perfectly.
Translated on 27-10-2026, 18:18.
