Audi A4 B7: Install Injectors (BRD) - 170 HP TDI
B.C.
Post30-11-2016, 20:54    Subject: Audi A4 B7: Install Injectors (BRD) - 170 HP TDI Quote
Hello everyone,
I need to clean the PD elements. I have all the necessary tools for disassembly according to the ELSA instructions.
My question is: Is there a slightly "simpler" installation method?
Or is the mounting device 2036 with fastening plates 2036/1 absolutely necessary?
Can valve levers 541/1A be used in conjunction with pressure plates 541/5?
Is there a cheaper alternative for getting the PDs (presumably referring to something like pressure distribution sensors) into the seat?
I don't have any experience in that area and would appreciate some help.
Thank you very much!
Translated on 20-08-2026, 11:48.
Post30-11-2016, 22:33    Subject: Audi A4 B7: Install Injectors (BRD) - 170 HP TDI Quote
Within the last two years, I have changed three PPDE (precision pressure dielectric elastomers) at the BRD (likely a company or organization). Besides the dial gauge holder, I have never had or used any other specialized tools.
Simply push it in as far as possible by hand, using the force you can apply, and then carefully pull the rest into place with the screws, always alternating half a turn on each screw. icon_wink.gif
Translated on 20-08-2026, 11:49.
B.C.
Post01-12-2016, 19:27    Subject: Audi A4 B7: Install Injectors (BRD) - 170 HP TDI Quote
Hello Michael,
Thank you for sharing your experiences with me!
That helps me a lot already.
Can you tell me approximately how many millimeters you still needed to tighten the screws?
Is there a risk of incorrectly inserting the PPDE manually?
Or is there a reference point for that? For example, the tabs of the PPDE (Power Plant Direct Equipment) that align with the mounting surface?
Sorry, I haven't disassembled the engine yet, I'm just preparing for it. That's why I have these questions.
"VG" translates to "Very Good" in English.
Björn.
Translated on 20-08-2026, 11:51.
Post02-12-2016, 23:21    Subject: Audi A4 B7: Install Injectors (BRD) - 170 HP TDI Quote
B.C. wrote:
Could you tell me approximately how many millimeters you had to tighten the screws further?
To be honest, I didn't really pay attention, but it was probably no more than 10mm.
B.C. wrote:
Is there a risk of incorrectly installing the PPDE manually?
No, when installed live on the engine, the process is quite self-explanatory. icon_wink.gif
Translated on 20-08-2026, 11:52.
B.C.
Post04-12-2016, 19:05    Subject: Audi A4 B7: Install Injectors (BRD) - 170 HP TDI Quote
Thank you, Michael!
Okay.
Björn.
Translated on 20-08-2026, 11:53.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts 2.0 TDI PD Injectors: VW Audi Performance Diesel Engine Technology
No new posts AFN Engine Swap Audi 80 B4 TDI 1Z Engine Diesel Engine Technology
No new posts Faulty ABS Module? Audi to Install New ESP System. Diesel Engine Technology
No new posts Install water pump, but how? Diesel Engine Technology
