Octavia Dashboard Not Working: No Display, Completely Dark
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
guido68
Post02-01-2017, 21:40    Subject: Octavia Dashboard Not Working: No Display, Completely Dark Quote
I'm having a problem with my Octavia 1U5 1.9 TDI 90hp, manufactured in 2005.
After a few days of inactivity, the entire instrument cluster is completely non-functional, displaying no information whatsoever: no clock, no odometer, no backlight, and no warning lights except for the charging indicator (battery).
The battery is full, and it starts briefly but then immediately shuts off; I think it might be due to the immobilizer.
I haven't experienced any problems so far.
I've checked the fuses, and they are working.
I've read about problems with the instrument cluster during my search, and I've already removed it.
Gibt es eine Möglichkeit es zu prüfen? Spannung drauf? Wyes, but where?
Does anyone have any ideas?
Thank you in advance.
Guido
Translated on 06-10-2026, 18:42.
Post04-01-2017, 14:27    Subject: Octavia Dashboard Not Working: No Display, Completely Dark Quote
Hello Guido,
Without a wiring diagram, you will hardly get very far: https://erwin.skoda-auto.cz
I would focus on checking for cold solder joints, defective electrolytic capacitors, and the power supply to the AI chip. If nothing obvious is apparent there:
Without much time or expertise, visiting a Skoda workshop will be the quickest solution in this case. Ask there if a used instrument cluster (WFS) can be adapted, which would be cheaper than a new one.
Translated on 06-10-2026, 18:44.
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resetting the service interval display on a Volkswagen Go... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA Indicator in Dashboard: Meaning & Troubleshooting Diesel Engine Technology
No new posts Skoda Octavia: No Radio Communication? On-Board Diagnostics (OBD)
No new posts Octavia 2.0 TDI: Intermittent Power Loss & Misfires Diesel Engine Technology
No new posts jetzt hat er gar keine Leistung mehr Diesel Engine Technology
