Modified Engine Noise After Nozzle Replacement (Experience on AFN) (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Articles
ulf Post15-05-2003, 16:18
If the VP 37 engine sounds different after replacing the injectors (e.g., harsher, metallic ticking on cylinder 1 or multiple cylinders, etc.), a changed installation position of the injectors may be the cause.
Despite the relatively tight fit in the cylinder head and the clamping claw, the nozzles can each be rotated and tilted in all directions by a few degrees.
When tightening the retaining screws, they may be fixed at an uneven angle, which can noticeably change the engine noise.
If the nozzles are fixed as precisely as possible in the exact center of all the spaces, there is a good chance that the engine will run smoothly.
Ratings - Modified Engine Noise After Nozzle Replacement (Experience on AFN)
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 3 - View ratings
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 AHF, only 3 cylinders after turbocharger replacement Diesel Engine Technology
No new posts Jet Engine Noise: What to Expect After Replacement Diesel Engine Technology
No new posts Engine Noise: Causes and Solutions Diesel Engine Technology
No new posts AKN Motor Noise: Clicking, Tapping, or Knocking Diesel Engine Technology
