Golf 7 Service: Get yours now!
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post28-02-2017, 19:42    Subject: Golf 7 Service: Get yours now! Quote
Hello everyone,
"Service now" is displayed on the dashboard of this Golf VII. How can I reset the service interval?
I tried resetting the "WIV" by adjusting it in the car's settings. The mileage and the time seem to have been reset, but the message still appears.
Is there a reliable guide?
Tuesday, February 28, 2017, 18:19:25:31703
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number: WVWZZZAUZDW11XXXX
License plate: XXXXXXX
Mileage: 23976 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 69 A5
Vehicle Identification Number: WVWZZZAUZDW116508
Mileage: 23976 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
69 followers -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
Address 01: Engine Control Module (J623-CHPA)
Label file: DRV\04E-907-309-V1.clb
Part number SW: 04E 906 016 G, HW: 04E 907 309 A.
Component: 1.4L R4 TSI, part number H08 5538.
Revision: WAH08---
Encoding: 01250032247405082000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM14TFS01104E906016G 002007
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 264655D1599CDA71B9-8072
No error codes found.
Readiness: 0000 0000
Address 02: Transmission (J743)
Label file: DRV\0CW-927-769.clb
Part number SW: 0CW 300 045, HW: 0AM 927 769 G.
Part number: GSG DQ200-MQB H43 5243.
Revision: 00043014 Serial number: CU501302265217
Encoding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 76E64591C9BCEAF1C9-8022
Address 03: Brake Electronics (J104)
Label file: DRV\5Q0-907-379.clb
Part number SW: 5Q0 907 379 AD, HW: 5Q0 907 379 E.
Component: ESC H75 0537
Revision: 00000000 Serial number:
Encoding: 01FA6AA120211272037C060001CB2980560448C0608094F3F82A502AC1
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7EF65DB1E18CA2B191-802A
Address 08: Climate Control/Heating Unit (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 R, HW: 5G0 907 044 R.
Component: Climatronic. Part number: H02 0503.
Revision: 00001K06
Encoding: 00020004200100011105004000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002.rod
VCID: 36668591893CAAF109-8062
Control unit for the fresh air blower (front).
Refrigerant pressure and refrigerant temperature sensors:
Air quality sensor:
"One error found:"
263426 - Air quality sensor.
B10AF 31 [008] - No signal.
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 3
Error frequency: 1.
Lost Count: 61
Mileage: 23738 km
Date: 2017.02.07
Time: 11:05:39
Voltage at terminal 30: 14.0 V.
Outside temperature: 2.5 °C.
System runtime: 21 seconds.
System runtime, terminal 15: 22 seconds.
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 084 Q. Hardware number: 5Q0 937 084 Q.
Component: BCM MQBAB H, H14 0106.
Serial number: 00011306400884
Encoding: 00021E46C24122FB0FA44080B11C0708100A00000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 4686F551F9DC3A7199-8012
Wiper motor control unit:
Subsystem 1 - Part number SW: 5G1 955 119 A, HW: 5G1 955 119 A, Label file: DRV\5QX-955-119-V1.CLB.
Component: WWS 130213 042 0551
Serial number: 130225132625
Encoding: 0E4DD5
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 HW: 5Q0 955 547 Label file: DRV\5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M03D06H20M34S27S4.
Encoding: 00A8DD
Sensor for anti-theft system:
Subsystem 3 - Part number SW: 5Q0 951 172, HW: 5Q0 951 172.
Component: Sensor, part number DWA 005 0313.
Serial number: 000000000ZY130350JGR
Alarm horn:
Subsystem 4 - Part number SW: 5Q0 951 605, HW: 5Q0 951 605.
Component: Siren, DWA 004 0311.
Serial number: 00000000000056120265
Address 10: Parking Assist 2 (J791)
Label file: 5Q0-919-298.clb
Part number SW: 5Q0 919 298 A, HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial Number: 61131305803510
Encoding: 0031061151
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 3D749ABDAC0A79A9C8-8068
Address 13: Distance Control (J428)
Label file: 5Q0-907-567.clb
Part number SW: 5Q0 907 567 G. Hardware number: 5Q0 907 567 G.
Component: ACC3 H08 0390
Serial number: 01031303030740
Encoding: 001E1D00FE0309
ASAM Dataset: EV_ACCBoschMQB 001021
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 3F88E0B5A6066BB9DA-806A
"One error found:"
1043 - Adaptive Cruise Control.
B10E7 F0 [040] - disconnected.
Error priority: 6
Error frequency: 1.
Lost Count: 43
Mileage: 23,536 km
Date: 2017.01.19
Time: 14:57:47
Control unit temperature: 14 °C
Voltage at terminal 15: 12.3 V.
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 15: Airbag (J234)
Label file: DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 C. Hardware: 5Q0 959 655 C.
Component: Airbag VW20, Part Number: 011 0361.
Serial number: 003F5R03AVS-
Encoding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 408AE349DBF81441A3-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 002 202 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000267182C0N
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 480 002 202 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000006AAC03C0$
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 480 402 502 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502B90F76B14A1AL
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 402 502 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502A50F8ABF0D16V
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 480 401 602 13
Component: FrontSensor_D 001 6149
Serial number: 3556502B90F7B8E2202L
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 AG, HW: 5Q0 953 549 A.
Bauteil: Lenks. Module 007 0070.
Revision: -------- Serial Number: 27021308490310
Encoding: 0D00
Operating number: WSC 40195 333 37120
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BF054A5F29EB799B6-802E
Address 17: Control panel module (J285)
Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 5G0 920 870 Hardware: 5G0 920 870
Component: COMBINATION UNIT 335 0555
Encoding: 07A401086F90000800886A03040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 66C615D1991C1A7179-8032
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 F. Hardware: 5Q0 907 530 F.
Component: GW MQB High, Part Number: 125 1109.
Revision: -------- Serial Number: 0000385435
Encoding: 030100342B086400EF00065A1C0F000100010000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 3462BF999F40B8E137-8060
Generator:
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 5G0 959 442 K, HW: 5G0 959 442 K, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005231170010291
Encoding: 2D0000
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 C, HW: 5Q0 915 181 C.
Component: J367-BDM, Hella, H03 8042.
Serial number: 4408120103
Address 42: Door Electric Driver (J386)
Label file: 5QX-959-X93-42.clb
Part number SW: 5Q0 959 593 A, HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 23021304080254
Encoding: 003B0220D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Rear door control module, driver's side.
Subsystem 1 - Part number SW: 5Q4 959 811 A, HW: 5Q4 959 811 A.
Component: Rear panel FHSG DRV 007 0002.
Serial number: 00000000000000876196
Encoding: 010000
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-144.clb
Part number SW: 5Q0 909 144 L, HW: 5Q0 909 144 L.
Part number: EPS_MQB_ZFLS 119 1021.
Encoding: 13
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
Address 52: Power door lock, front passenger side (J387)
Label file: 5QX-959-X92-52.clb
Part number SW: 5Q0 959 592 A, HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 16021301100287
Encoding: 003B0020DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E769DB1A10C62B1D1-806A
Door control module, rear passenger side:
Subsystem 1 - Part number SW: 5Q4 959 812 A, HW: 5Q4 959 812 A.
Component: Rear panel FHSG PSG 007 0002.
Serial number: 00000000000000871453
Encoding: 090000
Address 55: Headlight range control (J745) Label file: DRV\7P6-907-357.clb
Part number SW: 7P6 907 357 A, Hardware: 7P6 907 357 A.
Component: AFS-ECU H07 0080
Revision: -------- Serial Number: --------------
Encoding: 029A00104F000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Headlight module, left side:
Subsystem 1 - Part number SW: 3D0 941 329 A, HW: 3D0 941 329 A, Label file: 3D0-941-329.CLB.
Part: LeiMo left side, H05 0012.
Coding: 900000
Headlight module, right side:
Subsystem 2 - Part number SW: 3D0 941 329 A, HW: 3D0 941 329 A, Label file: 3D0-941-329.CLB.
Component: Right-hand LeiMo, part number H05 0012.
Coding: 900000
Address 5F: Information selection. I (J794)
Label file: 5G0-035-MIB-STD1.clb
Part number SW: 5G0 035 846, HW: 5G0 035 846.
Component: MU-S-N-ER 039 0170
Serial number: V1F00403130042
Encoding: 02730001FF00000011110001000800001F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002036
ROD: EV_MUStd4CPASE_VW37.rod
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5G0 919 605 D, HW: 5G0 919 605 D.
Component: ABT_Std_Nav H44 0020
Serial number: VWZ8Z9M34018Z7
Storage devices:
Subsystem 2 - Part number SW: 5G0 919 866 AE HW: -----------
Component: ECE 2017 --- 0064
Serial number: --------------------
Address 69: Trailer (J345) Label file: DRV\5Q0-907-383.clb
Part number SW: 5Q0 907 383 A, Hardware: 5Q0 907 383 A.
Component: Trailer H11 0030
Revision: 6B001003 Serial number: 00000192818184
Encoding: 0100000200000000
ASAM Dataset: EV_TrailFunctPivotHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 3564829D943AA1E900-8060
Address A5: Front/Forefield camera (R242)
Label file: DRV\5Q0-980-653.clb
Part number SW: 5Q0 980 653 E, HW: 5Q0 980 653
Component: MQB_MFK H05 0050
Serial number: 00000036307
Encoding: 0100020001020304000400000100000101
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3A7E91A1BD244E91ED-806E
End----------------------------(Duration: 04:31)-----------------------------
Translated on 03-09-2026, 8:11.
Karma: +805 / -0   Thank you, like it!
Post28-02-2017, 19:47    Subject: Golf 7 Service: Get yours now! Quote
Instructions:
/viewtopic.php?t=28677
DieselBär30x
Avatar-DieselBär30x
Post28-02-2017, 20:45    Subject: Golf 7 Service: Get yours now! Quote
Hello everyone!
It's important to know in this context that some AI systems may not start displaying the correct WIV reset information until after a few hours of operation or a few kilometers of driving.
Whether the service interval reset was successful or not can be determined by checking the newly read diagnostic trouble codes (DTCs) after turning the ignition off and then on.
Best regards from Munich!
Translated on 03-09-2026, 8:12.
Post28-02-2017, 21:18    Subject: Golf 7 Service: Get yours now! Quote
Translated on 03-09-2026, 8:13.
brezelmann01
Post28-02-2017, 22:15    Subject: Golf 7 Service: Get yours now! Quote
Great, thanks! I will check it and provide feedback.
Greetings, pretzelman.
brezelmann01
Post01-03-2017, 20:12    Subject: Golf 7 Service: Get yours now! Quote
Okay, here's the feedback you asked for:
First, I updated VCDS to version 17.1.3 and tried the automatic function. However, it still doesn't work with that version.
Then, following the instructions from Rainer's link:
The solution is simple:
1. Reset (IDE00342) or directly via the control panel.
2. Change the oil quality to "good" (IDE00492). Of course, only if "good" VW 507.00 oil has been filled. (icon_surprised.gif)
The values will then be automatically generated.
IDE00512-WIV: Minimum mileage for maintenance/inspection = 15,000 km.
IDE00513-WIV: Maximum mileage for maintenance interval/inspection = 30,000 km.
IDE00514-WIV: Maximum value for the time between inspections = 744d.
active/editable
Despite the ignition change and the bus being idle, the "Service Now" message remained on the dashboard. Consequently, I read out all the adaptation channels.
SW:5G0-920-870 HW:5G0-920-870 --- Mounting panel insert
Part: KOMBI 335 0555
Wednesday.
VCDS Version: RKS 17.1.3 Data version: 20170224 DS267.4
VCID: 66C615D1991C1A7173-8032
IDE00295 - Display for oil temperature: on.
IDE00301 - Distance: 23979 km
IDE00342-WIV: Resetting the WIV. Reset.
IDE00343-Language variant: German.
IDE00345-MAS00234-MFA3-Reset-MFA Button RESET / OK Manual reset: not possible.
IDE00345-MAS05463-MFA3-Reset - Fuel level sensor (gasoline/diesel) - MFA3 reset.
IDE00345-MAS05464-MFA3-Reset-Gas refill detection MFA3-Reset
IDE00345-ENG17917-MFA3-Reset-MFA3-Reset_automatic_electric: No automatic reset.
IDE00499 - Display correction for consumption and range: 100%.
IDE00500 - Duration: 18 hours.
IDE00501 - 26 minutes.
IDE00502 - Year: 2017
IDE00503-Month 3 months
IDE00504-Tag 1 day
IDE00510-WIV: Distance to travel after inspection: 0 km.
IDE00511-WIV: Time elapsed since inspection: 0 days.
IDE00512-WIV: Minimum mileage for service/inspection: 15,000 km.
IDE00513-WIV: Maximum mileage for maintenance/inspection: 30000 km.
IDE00514-WIV: Maximum value for the time interval between inspections: 744 days.
IDE00515-WIV: Oil quality - Good oil quality.
IDE00517-WIV: Entry for "Ruß" (soot) - 0 km.
IDE00518-WIV: Thermal stress, 0 km.
IDE00711 - Tachograph (speed limiter/distance recorder) not installed.
IDE00819 - Daily counter: 1448.
IDE00820 - Enable/Disable all development messages: Not active.
IDE00827-WIV: Minimum value for the time interval between inspections: 365 days.
IDE01153-SIA: Maximum distance to service: 15,000 km.
IDE01154-SIA: Maximum value for time until service: 365 days.
IDE02489 - Display representation, variant 1.
IDE02818-IDE02689-Offset value for tank calibration (full calibration): -12.8 l
IDE02818-MAS02376-Offset value for tank calibration (calibration) - Sensor 1: -12.8 l
IDE02818-MAS02377- Offset value for tank calibration (sensor 2): 12.7 l
IDE02818-MAS02378- Offset value for tank calibration (sensor 3): 12.7 l.
IDE02818-MAS02379- Offset value for tank calibration (calibration) - Sensor 4: 12.7 l.
IDE03329 - Driving profile for remaining range: 6.4 l/100km.
IDE03346-IDE00301-Predefined distance unit: Kilometer.
IDE03346-MAS01230-Date of unit setup: dd_mm_jj
IDE03346-MAS01456-Set Unit Speed: Kilometers per hour.
IDE03346-MAS02201-Set unit temperature: Degrees Celsius.
IDE03346-MAS02957- Set Units - Time: 24h
IDE03346-MAS03032-Set Units-Volume: Liters.
IDE03346-MAS03034-Preset unit pressure: bar.
IDE03346-MAS05637-Consumption of units: CNG (compressed natural gas) - kg per 100 km.
IDE03346-MAS05638-Set units-Consumption Gasoline / Diesel / LPG (liquid/autogas) Liters per 100 km
IDE03346-MAS05875-Average energy consumption of electric drive per unit - kWh per 100 km.
IDE03348-MAS01456-Speed Warning-Speed: 210.
IDE03348-MAS01561-Speed Warning Unit: Kilometers per hour.
IDE03348-IDE03348-Speed Warning - Active.
IDE03349-Fix: Maximum distance until the next inspection based on mileage: 30000 km.
IDE03350-FIX: Maximum time until the next time-based inspection: 365 days.
IDE03351-FIX: Distance traveled since the last inspection based on mileage: 6200 km.
IDE03352-FIX: Time since last time-dependent inspection: 372 days.
IDE03372 - Time synchronization source: internal clock.
IDE03568-ENG119828-Service Key Settings-p_deactivate_SK_Function enable/disable.
IDE03568-ENG99943-Service Key Settings-p_forcewrite_qual_time: 10 s
IDE03568-ENG119827-Service Key Settings-p_main_switch_Basic: on.
IDE03568-ENG102414-Service-Key Settings-p_main_switch_keyless: on.
IDE03568-ENG102611-Service-Key Settings-p_write_delay_speed 20 km/h
Why is IDE00342 still showing as "Reset"?
After changing IDE03351 and IDE03352 to 0, the message finally disappeared. Was the vehicle previously programmed with a "FIX" code? The last inspection was performed at a VW dealership.
pretzel man
Translated on 03-09-2026, 8:23.
Post01-03-2017, 20:31    Subject: Golf 7 Service: Get yours now! Quote
I have no idea; those two points were new to me. Thanks for the feedback! icon_smile_thumb_up.gif
Translated on 03-09-2026, 8:34.
bloesch
dieselschrauber likes this.
Post02-03-2017, 4:20    Subject: Golf 7 Service: Get yours now! Quote
After changing IDE03351 and IDE03352 to 0, the message ultimately disappeared. Was or is the vehicle programmed with FIX? The last inspection was at VW...
It's perfectly normal. That's just the way it is. The inspection is no longer flexible, but the oil change still is.
brezelmann01
Post02-03-2017, 17:06    Subject: SEO-Optimized Title Translation: **"Best [Produkt/Dienstleistung]: Top Auswahl & Preise"** Quote
Okay, so is everything correct now?
Theoretically, the inspection is due every 2 years or a maximum of 30,000 kilometers, right?
Translated on 03-09-2026, 8:35.
Post02-03-2017, 17:17    Subject: SEO-Optimized Title Translation: "Is it correct now?" Quote
brezelmann01 wrote:
Okay. So, is everything correct now?
Theoretically, the inspection is every 2 years or a maximum of 30,000 kilometers, right?
Translated on 03-09-2026, 8:36.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pierburg MAF Sensor: Now Officially for TDI Engines Diesel Engine Technology
No new posts Brakes: Get Yours Now! Transmission, Chassis, Body & Interior
No new posts Hooray, it's working now! Diesel Engine Technology
No new posts VAG-Com heisst jetzt VCDS ?! On-Board Diagnostics (OBD)
