hkss Blaumann
Joined: 12/17/2006 Posts: 171 Karma: +13 / -0 Location: Karlsruhe 2017 Skoda Yeti Premium Support
20-12-2011, 20:04 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Well, now it's time to tackle some well-known issues.
Today, while changing the tires, I needed the wheel lock and found an aquarium in the spare tire well – the water level was 4 cm high.
I know that my car will have the drain tubes of the panoramic sunroof replaced free of charge if there's a problem with them (TPI number 2023456/3 from April 7, 2011). I just thought I wouldn't have such a major issue and could wait until summer to get it done.
Despite everything, I want to be on the safe side and see where it's coming from, which direction it's originating from.
The water is running into the spare tire well (which must be on the left side).
Sometimes water takes mysterious paths...
I've now applied watercolor paint and drilled holes in the drain plugs.
There's still quite a while to go until the service appointment after Christmas.
| Description: |
| 2007 Volkswagen Golf, Reserveradmulde |
| File size: |
248.42 KB |
| Viewed: |
34968 times |
| Description: |
| 2007 Volkswagen Golf, Wasser in Reserveradmulde |
| File size: |
209 KB |
| Viewed: |
52474 times |
Translated on 21-08-2026, 12:51.
Profile PM Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
20-12-2011, 20:09 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Have you ever had a car accident from behind?
reflexsilber met.
Translated on 21-08-2026, 12:52.
Profile PM Garage |
hkss Blaumann
20-12-2011, 20:23 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
RedR32 wrote: | | Have you ever had a crash at the back? |
No - not that I know of.
The AHK (trailer hitch) was installed by the Volkswagen dealer after the car was originally purchased.
I'm pretty sure it's the drain hoses for the panoramic sunroof. I'll just have them fix it now; it doesn't cost anything, so we can see what happens next.
Translated on 21-08-2026, 12:53.
Profile PM Garage |
hkss Blaumann
24-12-2011, 1:12 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Hmm...
...I'm not exactly being particularly clever right now - which I had almost suspected already.
You can clearly see that the water is entering much more on the right side of the vehicle. Especially in the lower right corner, all the paint has been washed away. This isn't surprising, as the water tends to flow backward when starting.
The water also leaks from the groove at the top edge all around when turning.
which in turn made the entire experiment questionable.
The only thing that stands out from the attempt is that the water seems to be coming more from the right side of the vehicle.
But the rainwater drainage tubes and drain holes on the sunroof are located on the left side.
Hmm... well, all the plastic trim at the back would have to be completely removed, right down to the seat bench – everything needs to come out.
That thought gives me a real sense of dread.
| Description: |
| File size: |
242.59 KB |
| Viewed: |
29977 times |
Translated on 21-08-2026, 12:55.
Profile PM Garage |
hkss Blaumann
24-12-2011, 22:37 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
I just remembered that I had a new fuel tank lock mechanism installed about three weeks ago, and it was done free of charge.
Could it be related to that?
There's also a water drain hose located in the area around the fuel filler cap.
Does it go through the interior?
Translated on 21-08-2026, 12:56.
Profile PM Garage |
vagtuning Guest
25-12-2011, 2:01 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Actually, does it go down to the undercarriage?
Translated on 21-08-2026, 12:57.
hkss Blaumann
08-01-2012, 15:59 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
hkss wrote: |
I'm pretty sure it's the drain hoses of the panoramic sunroof. I'll just have it checked now - it doesn't cost anything - and then we can see what happens. |
I unfortunately have to correct myself – I absolutely didn't want to make a false statement here.
Contrary to the initial verbal confirmation from my customer service representative, I will not be receiving the replacement of the rainwater downpipes free of charge – despite having a warranty (TPI).
As we have heard sufficiently already, the TPI has nothing to do with any goodwill arrangements.
Yes, but I don't want to just let that be easily dismissed.
I have now contacted Volkswagen directly, as well as Autobild (through their reader complaints section). I had contact with Autobild...
I had extremely positive experiences years ago.
The technical product information (TPI) regarding the rainwater downspouts (procedure number 2023456/3) describes a manufacturing defect (poor workmanship).
If I have to pay for this myself, I don't think that's fair, and I will do everything I can to get a reasonable concession or refund.
Translated on 21-08-2026, 12:58.
Profile PM Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
09-01-2012, 1:35 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
I would try removing the rear paneling. The wiring for the trailer hitch and the taillights are also potential sources of problems. With that much water, it should be relatively easy to find the source using a hose.
3B5 AJM
Translated on 21-08-2026, 13:00.
hkss Blaumann
DieselBär30x likes this. |
Profile PM Garage |
BM Profi-Schrauber
11-01-2012, 13:35 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Thank you for the information  - and I learned something new again.
The problem with the rubber grommets (which protrude from the A-pillar between the hinges) is known to exist in the Golf3. Over time, these grommets become clogged, and then...
When frost forms, the sleeves slip off the hose.
It's quite incomprehensible why the hoses aren't routed all the way to the outside using a simple fitting and a one-piece design.
3B5 AJM
Translated on 21-08-2026, 13:03.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
11-01-2012, 18:31 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
I've experienced something similar; just like you, the green hose was kinked! I replaced it with a thick fuel hose from the sunroof to the bottom, and since then, there have been no problems.
"There's a lot of condensation in this car," I said. "My friend was surprised that the windows always fog up from the inside, even in cool weather, and without using the air conditioning."
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 21-08-2026, 13:04.
Profile PM Email Garage |
voodoo Guest
12-01-2012, 16:35 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Thank you for the many pictures!
I suppose I'll have to explore the trunk of our Octavia 1U soon before it's too late.
Luckily, the fuel hose is transparent, so you can immediately see if it's blocked anywhere.
Translated on 21-08-2026, 13:05.
Nils1212
20-03-2017, 15:37 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
"Does anyone have instructions on the best way to remove the trim panel in the trunk? I'm also having a problem with water collecting in the spare tire well of my Touran, and I don't want to break all the plastic clips when I take it apart."
Thank you in advance.
Nils.
Translated on 21-08-2026, 13:06.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
22-03-2017, 19:42 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Hello!
Here you'll find everything you need.
https://erwin.volkswagen.de
Nils1212
04-04-2017, 13:56 Subject: Sunroof Drain Hoses / Water in Spare Tire Well |
Thank you! I'll try to tackle that page.
Translated on 21-08-2026, 13:07.
