lw3989
02-05-2017, 9:04 Subject: Audi A4: Rear Left Door Won't Open? |
The rear left door cannot be opened with the central locking system. However, it can be opened from the inside. After that, it can also be opened again from the outside.
Attempting to reset the system by disconnecting the battery for 1 minute, simultaneously operating the lever from the outside and activating the central locking system, did not help.
Translated on 24-08-2026, 0:52.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
02-05-2017, 9:46 Subject: Audi A4: Rear Left Door Won't Open? |
"My wife's A3 had the same problem. Since we started using the door regularly again, and after lubricating the locking mechanism with spray lubricant and then cleaning it with brake cleaner, it works fine now."
Translated on 24-08-2026, 0:53.
Profile PM WWW Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
02-05-2017, 19:28 Subject: Audi A4: Rear Left Door Won't Open? |
Evening.
It could also be due to a microswitch in the lock mechanism. In this case, a replacement would be necessary.
Profile PM Garage |
