BLS Train Noise: Sudden Roar / Pendulum Support?
Post21-03-2011, 9:41    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
Hi.
Our Golf suddenly makes a loud noise under load at engine speeds below 1400 rpm.
It is silent when unloaded.
My initial suspicion was the torque arm, but it seems to be fine based on the first photos I saw.
At least nothing is broken – but maybe she's not allowed to push forward, because the one from the 3C is bent even further back.
 File size:  47.33 KB
 Viewed:  5437 times
 File size:  132.95 KB
 Viewed:  8067 times
Translated on 15-08-2026, 3:36.
Post22-03-2011, 9:54    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
Can someone describe the expected behavior of this storage system?
So, for example, it shouldn't bump into anything directly; the rubber protrusions are just emergency stops, like the buffer pads on shock absorbers... ?
Snake.
Translated on 15-08-2026, 3:37.
Post24-03-2011, 9:45    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
Okay,
"Diaper" and "pendulum support" checked.
Could it be that it is supposed to be normally positioned in the front?
I have a small gap there that could be constantly opening and closing due to vibrations from the load, which would allow for a "hammering" sound.
 File size:  204.08 KB
 Viewed:  5895 times
 File size:  239.12 KB
 Viewed:  5141 times
Translated on 15-08-2026, 3:38.
Post26-11-2012, 8:24    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
New finding:
Does anyone know the background of this change in MJ 08?
http://reichhard-motorsport.com/catalog/images/ebay/PFF85-704a.jpg
The larger gap in the "rotation direction" (on the right side according to Reichhard) probably indicates that it should be softer and not reach its limit ("stop") as quickly... which is what I would prefer.
Translated on 15-08-2026, 3:39.
Sieders
Post26-11-2012, 18:05    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
Very interesting. Are you planning an upgrade?
"I will definitely do that during the next service. The buzzing sound on my 2007 1K with BLS and the 6-speed transmission is also getting louder. I think that my extremely fuel-efficient driving style might be causing this part to wear out faster."
If anyone has switched to the new version, please report your experience here.
Translated on 15-08-2026, 3:40.
Post26-11-2012, 20:30    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
The problem is, where am I going to get the 2 kN of force needed to press the bearing halves in? icon_eek.gif
And whether I can get the generator carrier removed from the driveway...
The twice €25 for the storage would be ridiculously low.
First, I'm going to inspect a 2009 Touran with the BlueMotion Techno BLS engine, which should have the new bearing installed... and it's much quieter!
Translated on 15-08-2026, 3:41.
dieselschrauber likes this.
Post10-06-2017, 13:16    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
After years...
I think I've found the reason for the loud rumbling noise:
A blade of the forced ventilation system had come loose and was just lying around.
This allows the air inside the car to resonate nicely, which is similar to how a bass reflex port works.
Sure, the BLS isn't exactly quiet because of that, but it's noticeably better now that I've reinstalled this fin correctly.
Greetings.
Translated on 15-08-2026, 3:43.
Post10-06-2017, 14:15    Subject: BLS Train Noise: Sudden Roar / Pendulum Support? Quote
Thank you for your solution!
No new posts Passat Engine Noise: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Golf 3 Engine Idling High: Fix It Now! Diesel Engine Technology
No new posts Golf 4 Noises After Control Arm Replacement Transmission, Chassis, Body & Interior
No new posts VW Bora: Engine Noise Front - Diagnosis & Repair Transmission, Chassis, Body & Interior
