Golf 6 Serpentine Belt Tensioner Replacement
aussie123de
Post08-06-2017, 10:12    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
Hello everyone.
I drive a Golf 6 diesel with a 1.6-liter engine and 77 kW.
I'm having the following problem:
The function of the tensioner for the ribbed V-belt is to...
Sounds (the noise from the bearing).
Where can I find instructions on how to disassemble this part, or is there a guide on how to remove the tensioner? The mounting screw is really hidden.
How do you access it? What needs to be disassembled to get to it?
I would appreciate any tips you can offer.
Best regards from Hanover.
Translated on 29-08-2026, 13:46.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post08-06-2017, 16:14    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
What is the manufacturing year of the Golf, and what is the engine code?
Translated on 29-08-2026, 13:47.
aussie123de
Post08-06-2017, 16:26    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
Year of construction: 2013.
I can't say what the MKB is.
Translated on 29-08-2026, 13:48.
aussie123de
AndreasJ likes this.
Post08-06-2017, 18:08    Subject: SEO-Optimized: "Best German Recipes: Authentic & Easy" Quote
Type: 1KM
WVWZZZ1KZDM******
CAYC2198
3245348
I hope this helps.
EDIT: FIN encrypted.
klahaui
Avatar-klahaui
Post08-06-2017, 18:21    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
I'm going to leave the CAYC now.
The tensioner is bolted on from the rear, so you'll need to loosen a few coolant hoses at the back of the engine to access the tensioner bolt. Estimated labor time for an experienced mechanic is approximately 2.5 hours.
Translated on 29-08-2026, 13:49.
aussie123de
Post08-06-2017, 18:23    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
Thank you.
Okay, I'll let you know how it goes... It's really difficult to get there.
Post13-06-2017, 12:53    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
Okay... the 1.6 engine doesn't have a tensioner anymore. According to SSP 442, it uses a flexible belt, which is a stretch-type ribbed belt. So, it's just an idler pulley. It has a specific installation position and should not be confused with a tensioner pulley. Please refer to the repair manual.
Translated on 29-08-2026, 13:50.
aussie123de
Post13-06-2017, 13:07    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
That's not the case. It's clearly a tensioner that is secured with a pin when you want to replace the ribbed belt.
We were already working on that.
Translated on 29-08-2026, 13:51.
klahaui
Avatar-klahaui
Post13-06-2017, 16:11    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
In the repair manual, it is also described as a tensioner.
Post13-06-2017, 17:26    Subject: Golf 6 Serpentine Belt Tensioner Replacement Quote
You're right... surprisingly, the Repfaden manual mentions both procedures for belt installation and removal.
"V-ribbed belt with tensioner pulley."
"In the text, the deflector roller is described."
"V-ribbed belt with tensioning element."
In the text, the term "tensioning device" is mentioned.
It's a major operation. We need to remove the air intake duct with both fans. Take out the intercooler pipe and set the air conditioning compressor aside.
Translated on 29-08-2026, 13:52.
No new posts Passat B5: Tensioner Mounting Nut Workshop Deal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the starter motor on a Volkswagen Golf III TDI Diesel Engine Technology
No new posts Speed Sensor Replacement VW Golf IV 1.4 Transmission, Chassis, Body & Interior
No new posts Golf 4 Haldex Oil: Change Every 30,000km? Why? Transmission, Chassis, Body & Interior
No new posts Domlager wechseln am Golf 4 ohne Federbeinausbau? Transmission, Chassis, Body & Interior
