7-Speed S-Tronic Problems & Solutions
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Alex710
Post10-06-2017, 0:44    Subject: 7-Speed S-Tronic Problems & Solutions Quote
First of all, hello everyone.
My name is Alex, and I'm new here.
I hope you can help me with my problem.
Okay, it's about an A4 B8, model year 2014, with a 2.0 TDI engine and a 7-speed S-Tronic transmission. Initially, everything was perfect. In January, I had the emissions update done. Since then, my transmission has been shifting up much later than before. This wouldn't bother me too much, but especially at 100 km/h, it constantly shifts back and forth between 6th and 7th gear. When I use the cruise control, it shifts up much earlier and stays in 7th gear, just like it did before the update. The shift recommendations when manually shifting are also exactly the same as before the update. It only shifts erratically when I accelerate myself. The specialist workshop just said, "We didn't do anything to the transmission."
Does anyone have any idea what might be causing this?
Sure, here's the translation:
"Thank you in advance."
Translated on 25-08-2026, 16:25.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post11-06-2017, 20:23    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Hey,
I've encountered this problem before.
An adaptation process from the transmission has resolved the issue.
Translated on 25-08-2026, 16:27.
Alex710
Post12-06-2017, 12:43    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Sorry, I'm afraid I don't know much about this subject. Do you perhaps have a link to an instruction manual on how the adaptation drive needs to be done? And thank you for the tip. icon_smile_thumb_up.gif
klahaui
Avatar-klahaui
Post12-06-2017, 22:23    Subject: 7-Speed S-Tronic Problems & Solutions Quote
First, you purchase VCDS here in the shop, and then we can explain it icon_smile_thumb_up.gif.
Translated on 25-08-2026, 16:28.
Alex710
Post14-06-2017, 10:35    Subject: 7-Speed S-Tronic Problems & Solutions Quote
I have VCDS. So, please help me. This car is driving me crazy icon_sad.gif.
vag-driver
Post14-06-2017, 10:46    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Alex710 wrote:
I have Vcds. So, please help me.
Did you also purchase it from Rainer? Because only then will you receive support.
Andreas
Alex710
Post14-06-2017, 20:07    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Okay, so should I get a second one so that someone can help me with it?
Translated on 25-08-2026, 16:29.
klahaui
Avatar-klahaui
Post14-06-2017, 20:51    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Evening.
That's how the forum rules are here.
The operator relies on this for their livelihood, and therefore, there is no support provided for third-party products.
Please contact your seller.
*closed*
Post14-06-2017, 22:03    Subject: 7-Speed S-Tronic Problems & Solutions Quote
Alex710 wrote:
Okay, so should I buy a second one now, so that someone can help me with it?
No, don't ignore those seemingly endless instructions during the registration process.
What exactly do you not understand about the following text/link?
/profile.php?mode=register
For everything that has nothing to do with diesel engine technology and diagnostics, you can simply post anything.
Otherwise, you either need to own a diagnostics system from us, have a support key, or collect "Dieselschrauber" points. Actually quite simple, right?
Translated on 25-08-2026, 16:30.
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Probleme bei Vollgas im 1. Gang Diesel Engine Technology
No new posts 7-Gang DSG Probleme nach Grundeinstellung On-Board Diagnostics (OBD)
No new posts 5-Speed Gearbox: Sharan/Alhambra/Galaxy (AFN) Change? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
