I'm also encountering the same problem here: I was trying to enable FIS and GRA for someone who had retrofitted those features.
Unfortunately, I am unable to access the "Coding II" function in the brake control unit, which is required according to my instructions.
"In addition to the error stored in the control unit for the braking electronics indicating that the basic setting for the steering angle (G85) is missing, performing this setting results in 'Steering Angle' being displayed in green in the Diagnostic Information System (DIS)."
Will this go away after a longer drive?
Here is the
Autoscan:
Sunday, February 4, 2018, 11:05:59:63257.
VCDS – A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS version: RKS 17.8.1.0
Data as of: 20180112 DS276.7
http://shop.dieselschrauber.org/en
Dealer/Workshop name: Florian320
Vehicle Identification Number (VIN): WAUZZZ8E27A128260
License plate: WI Z 2906
Mileage: 159,510 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 77 77
Vehicle Identification Number (VIN): WAUZZZ8E27A128260. Mileage: 159,510 km.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module
Label file: DRV\06B-906-018-AVJ.lbl
Part number SW: 8E0 909 518 AQ, Part number HW: 8E0 909 018 B.
Component: 1.8L R4/5VT 0010
Encoding: 0011501
Operating number: WSC 06335 000 00000
VCID: 7F0ABC4C2D0A65BEE8-5164
3 error codes found:
17700 - Thermostat for map-controlled engine cooling (F265).
P1292 - 004 - Interruption - Occasional/Sporadic.
17953 - Throttle control.
P1545 - 008 - Malfunction - Intermittent.
16825 - Tank ventilation system.
P0441 - 002 - Mass airflow control malfunction - Intermittent.
Readiness: 0000 0000
Address 03: Brake Electronics; Label file: DRV\8E0-910-517.clb.
Part number SW: 8E0 910 517 H, HW: 8E0 614 517 BF.
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial Number: 00000000000000
Encoding: 0004871
VCID: 2C50BB008FFC2E261D-8078
Two error codes found:
01826 - Steering angle sensor (G85); Power supply KL30.
000 - - - Sporadic
Environmental conditions:
Error status: 00100000
Error priority: 3
Error frequency: 6.
Lost Count: 8
Time: 0.
Hex Value: 0x00C0
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0180
Hex Value: 0x0001
00532 - Power supply voltage.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 3
Error frequency: 1.
Lost Count: 9
Time: 0.
Hex Value: 0x0600
Hex Value: 0x5322
Hex Value: 0x0003
Hex Value: 0x16A5
Hex Value: 0x0001
Address 08: Climate Control/Heating Unit. Label file: DRV\8E0-820-043.lbl
Part number: 8E0 820 043 BJ
Part: A4 Climate Control Unit 2833.
Encoding: 00000
Operating number: WSC 00000
VCID: 6ADC7D181688F0162F-5148
No error codes found.
Address 09: Central Electronics
Label file: DRV\8E0-907-279-8EC.lbl
Part number: 8E0 907 279 N
Component: Internal Load Module NDL 0907.
Encoding: 10012
VCID: 3D7686443786B7AEBA-4B26
Address 15: Airbag
Label file: DRV\8E0-959-655-94.lbl
Part number SW: 8E0 959 655 G, HW: 8E0 959 655 G.
Part number: Airbag 9.41 H12 3730.
Revision: 91H12373 Serial Number: 0036M0G49PCB
Encoding: 0030612
VCID: 3B72885C7A92B99E84-806E
Subsystem 1 - Serial number: 6332DRB404259519I.
Subsystem 2 - Serial number: 6342DRB4042408AAM
Subsystem 3 - Serial number: 6352ARB401BB7211G.
Subsystem 4 - Serial number: 6362ARB401BBE558.
Subsystem 5 - Serial number: 63729RB401BDB279.
Subsystem 6 - Serial number: 63829RB401BDB24D$
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 39
Time: 0.
Address 16: Steering wheel electronics
Label file: DRV\8E0-953-549.lbl
Part number: 8E0 953 549 S
Component: Steering column module 0911.
Encoding: 00002
VCID: 4382F0BC5162C15ECC-4B40
Address 17: Control panel module
Label file: DRV\8E0-920-9xx-8EC.lbl
Part number SW: 8E0 920 901 G, HW: 8E0 920 901 G.
Component: KOMBI+WFS 3 H14 0200
Revision: 0200 Serial Number: AUX6Z0F0080176
Encoding: 0006114
Operating number: WSC 06617 002 1048576
VCID: 295E4214830E3B0EE6-5164
Address 25: Immobilizer
Encoding: 0006114
Address 46: Comfort System; Label file: .DRV\8E0-959-433-MIN.clb
Part number: 8E0 959 433 CC
Component: Comfort Device T85 4135.
Encoding: 07008
VCID: 74E06360444C36E685-4B26
Subsystem 1 - Part number: 8E1959801H
Component: Törsteuer.FS BRM 0606
Subsystem 2 - Part number: 8E1959802H
Component: Törsteuer.BF BRM 0606
Address 76: Parking Assist
Label file: DRV\8E0-919-283-8EC.lbl
Part number SW: 8E0 919 283 E, Part number HW: 8E0 919 283 E.
Component: Parking assist system, 8 channels, part number H06 0010.
Revision: 00H06000 Serial Number: 00067802130629
Coding: 0000014
VCID: 326CA578AED878D657-5164
"One error found:"
00446 - Functionality limited due to undervoltage.
End----------------------------(Duration: 06:39)-----------------------------
