Noise in BMW X3 when pressing the clutch
chli1976
Post30-06-2017, 12:06    Subject: Noise in BMW X3 when pressing the clutch Quote
I have a BMW X3 that makes a noise when I press the clutch pedal.
I only hear the noise for about 1/3 of the pedal travel, and at idle speed. As soon as I give it a little more gas, around 300 RPM or more, the noise disappears.
My guess is that it's the dual-mass flywheel, but I won't be able to see anything if I take it out. It sounds like the rattling noise you used to hear from the transmissions on older diesel engines when they were idling.
What do you think, and maybe someone recognizes the sound?
My concern is the rattling sound in the video.
Noise in BMW X3 when pressing the clutch - BMW-X3-rattert-beim-Kupplungtreten.mp4
 BMW X3 Geräusch beim Kupplung treten
 File size:  316.32 KB
 Viewed:  1112 times
VCDS
Translated on 09-07-2026, 8:32.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
X3Fahrer likes this.
Post30-06-2017, 14:06    Subject: Noise in BMW X3 when pressing the clutch Quote
It could also be the release bearing based on the sound.
Translated on 09-07-2026, 8:33.
chli1976
Post30-06-2017, 15:14    Subject: Noise in BMW X3 when pressing the clutch Quote
Yes, I had also considered that, but I'm bothered by the fact that it only makes a noise for 1/3 of the distance. On the other hand, the membrane spring will probably become easier to press after a certain distance.
VCDS
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Noise: Causes and Solutions Diesel Engine Technology
No new posts Clutch Noise After Cold Start: Causes & Fixes Diesel Engine Technology
No new posts Strange Noise from AXR - Troubleshooting Guide Diesel Engine Technology
No new posts Strange noise when starting? Diesel Engine Technology
