I have a Skoda Rapid with the 7-speed DSG transmission.
Shouldn't the engine speed jump to the new speed immediately when the transmission shifts?
"I've only seen this behavior on the DSG transmissions from our company. And in my car, it rarely drops suddenly; instead, in about 90% of gear changes, it slowly decreases (the indicator takes about one second)."
I'm going to add a video to make it easier to understand.
Thank you and best regards.
DSG DQ200: Performance and Driving Experience - 20170717_173353.mp4
"It looks normal to me; it's possible that the shift times may vary even with the same DSG (dual-clutch transmission), depending on the vehicle. A Skoda Rapid isn't a Ferrari, which shifts gears to save fractions of a second during the shifting process..."
A log of speed and engine RPM (click the "Turbo" button if available) from your car and a similar vehicle would be better for comparison.
"It looks normal to me; it's possible that the shift times may vary even with the same DSG (dual-clutch transmission), depending on the vehicle. A Skoda Rapid isn't a Ferrari, which shifts gears to save fractions of a second during the process..."
A log of speed and engine RPM (click the "turbo" button if available) from your car and a similar vehicle would be better for comparison.
Best regards, Rainer
It's difficult to write a log right now because I don't have my VCDS readily available.
The strange thing is that the DSG (dual-clutch transmission) can sometimes be very quick, and other times very slow. It's the same with manual shifting; sometimes it's fast, and sometimes it's slow. I have a feeling that the clutch might be slipping for too long.
Now I have 11,700 km on the odometer, and this is already the second clutch. And now the same problem is starting to appear as it did before the replacement.
Ich habe den Skoda mit 18km gekauft, nach ca. 1000km hab ich gemerkt dass die Drehzahl, anfangs nur bei kalten Motor, wo man beschleunigt hat "hochgesprungen" ist als ob die Kupplung rutscht.
Das hab ich bei meiner Werkstatt bemängelt und es wurden bei 6000km beide Kupplungen auf Garantie gewechselt Weil laut Skoda die Toleranz überschritten wurde.
Bei 6000km war dieses Rutschen auch bei warmen Motor was für das Autohaus den Ausschlag gab die Kupplungen zu wechseln.
Wenn dieses Rutschen bei kalten Motor ist, ist es noch "normal"? Soll angeblich stand der Technik sein? Das wurde mir damals noch gesagt.
Nun gut danach war das Rutschen weg und das DSG schaltete angenehmer. Nur jetzt seit ca 2000km (aktuell hab ich 11700km) fängt dieses Rutschen wieder an. Noch nicht so heftig das die Drehzahl gesprungen ist, sondern man merkt es am Auto, dass es unruhiger fährt.
Kann man deshalb das DSG so neu anlernen, dass der Anpressdruck der Kupplung besser passt? Oder liegt da eher ein Problem an der Mechatronik vor die vielleicht zu "schwache" Anpressdrücke weitergibt?
Kann man eventuell per VCDS sehen wie sehr die Kupplung jetzt im laufenden Betrieb von der Toleranz abweicht?
Ich meine hier etwas von Verschleiß an der Pumpe und zu niedrigem Pumpendruck gelesen zu haben...
Mich wundert es eben das ich ein Post um knapp nach 17 Uhr gemacht haben soll, um die Zeit saß ich auf dem Motorrad und war definitiv nicht am schreiben.
Ich werde mal mein Passwort ändern.
Bezüglich des logs, sobald ich mein Auto wieder habe wird das gemacht
Ich wollte eben einen Log erstellen, nur die Aufzeichnung will einfach nicht funktionieren.
Kann mir jemand erklären wie ich mein vcds richtig bediene, dass es Aufzeichnet?
Ich wollte es ja über vcds aufzeichnen, speichern und über KDataScope hier einstellen.
Ich war schon im Erw. Messwerteblock was den Druck angeht. Im Stand war auf ersten Teilgetriebe 16bar Soll- und Istwert. Auf dem Zweiten 14bar, ebenfalls Soll- und Istwert waren identisch.
Beim Schalten ist mir jedoch aufgefallen, dass der Istwert auf ca. 3 bar abfällt und ungefähr 2-3 Sekunden braucht um auf den Sollwert zu steigen.
Das war bei beiden Drücken zu beobachten.
Wir haben heute nochmal ein Video gemacht, wie das DSG mittlerweile im Tiptronicmodus, bei gleichbleibender Gaspedalstellung schaltet.
Die letzten beiden Schaltvorgänge sind in meinen Augen normal.
DSG DQ200: Performance and Driving Experience - 20170721_195153.mp4
File size:
86.02 MB
Viewed:
316 times
So nach langem hin und her hat es endlich geklappt. Ich hoffe ihr könnt mit den Logs was anfangen. Mir fällt nur auf, dass manchmal die beiden Werte sehr stark auseinander gehen.
Ich habe zwei Logs gemacht. Einmal mit Tiptronic und einmal mit gewöhnlichem "D"
Tipp: Meßwerte gruppieren oder Turbo-Modus erhöht die Abtastrate und damit die zeitliche Auflösung stark.
Noch ein Tipp: Nur das Loggen, was problematisch ist und nicht geht. Und nicht so ein Geschmarre wie morgens zum Semmelholen.
Ich habe mir jetzt viele Sekunden angesehen aber nicht alles. In Deinem Fall EIN Schaltvorgang, welcher Dir zu lange dauert. Eine grobe Abweichung der Istwerte vom Soll konnte ich nicht erkennen. In Deinem Video geht es am Schluß ja auch "normal schnell". Ich hoffe Du hast nicht so etwas geloggt.
Die Logs sind viel zu lang, was soll'n das? Soll ich mir jetzt in Log 2 den ersten oder zweiten Teil ansehen oder 294 Sekunden vom zweiten Teil des zweiten Logs?
Logge bitte nur das wo es nicht geht. 15s um einen problematischen Schaltvorgang hätten vollkommen gereicht.
