VW Golf VI 1.6 TDI: Larger Injectors
maxm3
Post30-07-2017, 21:18    Subject: VW Golf VI 1.6 TDI: Larger Injectors Quote
Perhaps someone here can help me.
My injectors will eventually fail, and when they do, I'd like to upgrade to larger injectors. Does anyone know of a company that offers refurbished or larger injectors?
Is this a 1.6 TDI CR engine with 105 horsepower, identified by the engine code CAYC, and equipped with Siemens injectors?
Thank you very much!
Markus
Translated on 14-10-2026, 2:46.
vwSchrauber
Post01-08-2017, 13:54    Subject: VW Golf VI 1.6 TDI: Larger Injectors Quote
Without wanting to stifle your creativity: if you're modifying other components, you'll inevitably need a software adjustment. However, if you simply want more power, a software modification can push the engine to its limits.
Install the parts that are included in the series, and have a (skilled) tuner give you a little more power, and if that's not enough, then upgrade to a 2.0. Everything else, in my opinion, is pointless tinkering icon_wink.gif.
Translated on 14-10-2026, 2:47.
maxm3
Post01-08-2017, 16:37    Subject: VW Golf VI 1.6 TDI: Larger Injectors Quote
My car has been tuned on a dynamometer. The final result was 143 horsepower and 370 Nm of torque.
I want to upgrade to a larger turbocharger. The problem with that is the injectors. Their flow rate is already at its limit. Because of the long injection time, the exhaust gas temperature becomes very high. Therefore, a larger turbocharger won't provide any benefit without larger injectors.
Please don't mention the 2.0 TDI. I want to increase the power of the 1.6 engine.
Darkside Development offers nozzles with 50% more flow rate. However, unfortunately, they cost 1500 pounds excluding VAT. That's why I'm looking for a more affordable alternative.
Translated on 14-10-2026, 2:48.
Post01-08-2017, 17:57    Subject: VW Golf VI 1.6 TDI: Larger Injectors Quote
Yes, you're right. Discussing the meaning or purpose seems pointless. If you have contact with a tuner who has good equipment, there's surely some experience to be gained there. After all, he would have to adjust the injectors, and possibly even help with the necessary calibration. This isn't a VP engine anymore.
Translated on 14-10-2026, 2:49.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PDE: Bigger is Better? Diesel Engine Technology
No new posts Fuel Injectors: Larger Size & Timing Adjustment Diesel Engine Technology
No new posts Fuel injection pumps and tuning (larger displacement plun... Diesel Engine Technology
No new posts Replacing the battery - larger size possible? Diesel Engine Technology
