Air conditioner not cooling - Year of manufacture 2000, compressor seems to be running(?)
Uwe46
Post08-07-2018, 14:11    Subject: Air conditioner not cooling - Year of manufacture 2000, compressor seems to be running(?) Quote
Hi!
perhaps you could help me a little more:
It concerns my Octi 1U5 with a 1.9 TDI 110PS engine and Climatronic from 2000. The air conditioning system has not been cooling for a few weeks. From this moment on.
What I've checked:
- Both fans are running.
- The battery fuse was replaced.
- The compressor also seems to be working:
-- Injection volume without air conditioning: 6.0mg/hour
-- Injection amount with air conditioning: 6.8mg/H
-- Generator load without air conditioning: 47.6%
-- Generator load with climate: 54%
This could simply indicate that the generator's magnetic coupling is engaging. Or does that mean: Is the compressor running?
Last summer, I replaced the climate condenser, and since then, the system has been running perfectly.
The Climatronic is not experiencing any errors (unlike last year when the system was empty due to a hole in the capacitor).
Unfortunately, the pressure reading on my model, which was manufactured in the 2000s, seems to be unreadable.
I've checked all the pipes: None of the air conditioning system's pipes in the engine compartment are getting cold.
Do you have any more ideas?
Karma: +647 / -0   Thank you, like it!
Post08-07-2018, 16:49    Subject: Air conditioner not cooling - Year of manufacture 2000, compressor seems to be running(?) Quote
Connect the manometer and check if there is any pressure in the system.
No new posts A3 Climate Control Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Compressor Not Getting Power? Troubleshooting. Diesel Engine Technology
No new posts AC Not Cooling? Troubleshooting & Repair Tips. Transmission, Chassis, Body & Interior
No new posts Touran AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling during speed fluctuations Transmission, Chassis, Body & Interior
