Exhaust Smoke: Diagnose Engine Damage?
dokatoto
Post28-05-2003, 13:47    Subject: Exhaust Smoke: Diagnose Engine Damage? Quote
Can you distinguish between worn piston rings and faulty valve stem seals based on the type of smoke coming from the exhaust? I can rule out the turbocharger because I don't have significant oil consumption. However, especially in the first two gears, there's quite a bit of smoke coming out the back.
Or will I inevitably have to take the engine apart?
Thank you for your help.
Toto.
Translated on 05-09-2026, 9:55.
haehnlein
Post28-05-2003, 14:00    Subject: Exhaust Smoke: Diagnose for Engine Damage? Quote
dokatoto wrote:
I can rule out a turbocharger because I don't have any significant oil consumption.
Hi Toto,
Then you can also rule out the piston rings and crankshaft seals, as these are often associated with increased oil consumption.
dokatoto wrote:
But especially in the first two gears, it really smokes from the back.
Please use the search function and look for "VTG", "EGR (Exhaust Gas Recirculation)", and "fuel injectors". I assume a clean air filter and unimpeded, bubble-free airflow in the fuel system.
____________
Kein Auto mehr!
Translated on 05-09-2026, 9:57.
Gremlin
Post28-05-2003, 21:00    Subject: Exhaust Smoke: Diagnose Engine Damage? Quote
I can only speak from my own experience with gasoline prices.
Kadett-D 1.3S with a significant oil leak upon starting, and an oil consumption per 1000km that allows a Lupo TDI to travel 60km.
(The cloud was so incredible that a friend of mine drew a caricature of it.)
After replacing the valve stem seals, the white smoke at startup disappeared, but the oil consumption only improved slightly. The engine then failed at 220,000 km due to a problem with the 4th cylinder. Specifically, the valve spring for that cylinder broke, and I suspect that was the main cause of the failure (leading to secondary damage). The compression was still reasonably good.
but the structural integrity of the shell was completely compromised.
I decided not to proceed with the breakdown.
CU Gremlin.
Translated on 05-09-2026, 9:59.
diesel.gustav
Post29-05-2003, 22:14    Subject: Exhaust Smoke: Diagnose Engine Damage? Quote
Deleted upon request.
Translated on 05-09-2026, 10:00.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Frage zur AGR-Bewegung von Hand Diesel Engine Technology
No new posts Hydraulic Jack: Manual Operation & Use Diesel Engine Technology
No new posts (Hand) -Bremslampe für Bremsflüssigkeit erlischt nicht Diesel Engine Technology
No new posts Second (Hand) Gas Pedal Installation for TDI "DIY Project" On-Board Diagnostics (OBD)
