pit.dahl
22-10-2017, 19:32 Subject: VCDS Log: Strange Entries on HEX-V2 |
I've now created my first HEX-V2 scan, and interestingly, my Golf started showing some errors after only 915 km. Since I'm new to this topic, my question is:
Can I delete the errors first to have a "clean" state, before I start making any changes?
Perhaps someone could take a look at the uploaded scan, thank you.
Pit
Log-Golf 7 Sound-915km.txt
| Description: |
| Mein erster Scan vom Golf |
 Download |
| File name: |
Log-Golf 7 Sound-915km.txt |
| File size: |
21.65 KB |
| Downloaded: |
1069 times |
Translated on 31-08-2026, 4:33.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
22-10-2017, 19:57 Subject: VCDS Log: Strange Entries on HEX-V2 |
Hi  . The error entries seem to indicate a transport issue and a dead battery. I would first delete all of them.
The easiest way is to use the "Round Message" function via the button on the Autoscan screen.
Translated on 31-08-2026, 4:34.
Profile PM WWW Garage |
pit.dahl
24-10-2017, 10:36 Subject: First Scan: Initial Assessment and Results |
dieselschrauber wrote: | Hi . The error entries seem to indicate a transport issue and a dead battery. I would first delete all of them.
It's easiest to do it via the round message using the button on the Autoscan screen. |
Hello Rainer,
I was almost thinking the same thing; it's probably related to the transport process. I'll try to delete it to ensure a clean state. It's also sad that VW doesn't even remove these errors during delivery.
Thank you and best regards.
Pit.
Translated on 31-08-2026, 4:35.
pit.dahl
06-11-2017, 9:29 Subject: Error Message: Troubleshooting and Solutions |
dieselschrauber wrote: | The error entries indicate issues related to transport and a dead battery; I would start by deleting them all.
Hello Rainer,
I have now reset all the errors, and it worked perfectly. While browsing the software, I wanted to take a look at the service reset indicator and received the following error: Code: |
Fßr dieses Steuergerät liegen keine Informationen zum
automatisierten RĂźcksetzen der Wartungsintervallanzeige vor.
Labeldatei:,âDRV\5G0-920-XXX-17clb.
Bitte stellen Sie sicher das die aktuelle Version von VCDS
nutzen
und senden Sie Steuergeräteabbilder des Schalttafeleinsatzes
(Adresse 17) an Ross-Tech oder Ihren Vertriebspartner. Vielen
Dank.
Um die Wartungsintervallanzeige manuell zurĂźckzusetzen,
nutzen Sie bitte die Funktion Anpassung (Funktion 10) des
Schalttafeleinsatzes (Adresse 17)
Ist das Steuergeräteabbild in der Logdatei enthalten? Mir ist auch aufgefallen, dass ich unter Adresse 9 nichts ändern kann, da der Code auch kpl. aus Nullen besteht. SSee attachment.
What do I need to do (I once wanted to disable the headlight cleaning system)?
Best regards and thank you.
Pit.
| Description: |
 Download |
| File name: |
Log-Golf 7 Sound-1873km.txt |
| File size: |
16.21 KB |
| Downloaded: |
999 times |
Golf 7 TDI 2.0 110 KW Sound
Translated on 31-08-2026, 4:37.
06-11-2017, 10:16 Subject: VCDS Log: Strange Entries on HEX-V2 |
No, the control unit image is an extra feature. Please install the current VCDS release first; version 17.8.0 has been updated with more recent data (20171026).
Translated on 31-08-2026, 4:38.
pit.dahl
06-11-2017, 20:16 Subject: VCDS Log: Strange Entries on HEX-V2 |
dieselschrauber wrote: | Hi,
Best regards, Rainer |
Hello Rainer,
I've now installed the new version, but nothing has changed. The error message still appears, and under control unit 9, the code still shows zeros. When I go to coding 07, it says that the control unit does not support that function.
"When unlocking a control unit image, you need a deactivation code. What else can I do?"
Best regards.
Pit.
| Description: |
 Download |
| File name: |
Log-Golf 7 Sound-1954km.txt |
| File size: |
16.44 KB |
| Downloaded: |
308 times |
Translated on 31-08-2026, 4:39.
06-11-2017, 20:29 Subject: VCDS Log: Strange Entries on HEX-V2 |
No, a login code is possible, but not mandatory. Please enter control unit address 9, check the boxes for "measured values" and "adjustment," then start the process and email the results.
Translated on 31-08-2026, 4:40.
