Roof antenna cable routing: VW Golf 3
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
bindpe
Karma: +5 / -2   Thank you, like it!
jens406 likes this.
Post16-11-2017, 18:36    Subject: Roof antenna cable routing: VW Golf 3 Quote
Hello.
Can anyone tell me where the cable from the original roof antenna runs in a Golf 3? I need to replace it because my original antenna is broken, and the replacement antenna has a different connector.
Furthermore, the replacement antenna does not have phantom power, so I need to run a 12V cable directly to the radio.
Thank you for your help.
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Peter.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 02-09-2026, 3:40.
vag-driver
dieselschrauber likes this.
Post23-11-2017, 10:56    Subject: Roof antenna cable routing: VW Golf 3 Quote
I'm guessing it's the C-pillar. However, you should be able to see if there are any cables running there by looking behind the trunk lining.
Andreas
Translated on 02-09-2026, 3:41.
No new posts Document A3 8L from 18/2000 onwards, whistling sounds fro... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Eilig !! Brauche original Einbaumaß Dachantenne, Golf 3 ... Transmission, Chassis, Body & Interior
No new posts Golf Roof Antenna: Drill & Installation Dimensions Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. OBD2 Adapter Cable for VW Golf 4 Diesel Engine Technology
No new posts CAN-Interface RKS+CAN und SUB-D9 CAN Kabel On-Board Diagnostics (OBD)
