Timing belt replacement interval for AHF-TDI engines
sgrund
Post10-10-2017, 21:18    Subject: Timing belt replacement interval for AHF-TDI engines Quote
"I have an Octavia EZ from 12/98 with 110 hp, and the timing belt needs to be replaced soon, as the scheduled interval of 90,000 km is approaching. My question is whether I can use the longer interval of the ASV engine, which I believe is 120,000 km, for this engine. After all, the timing belt kit used for the AHF engine is the same as the one used for the ASV engine, starting from engine number 006xxx. And mine has engine number 181055." It would be pointless to spend several hundred euros on such an old vehicle.
Karma: +643 / -0   Thank you, like it!
dieselschrauber, Bertil and Wiesel likes this.
Post11-10-2017, 6:04    Subject: Timing belt replacement interval for AHF-TDI engines Quote
Hi.
A timing belt kit, for example from Contitech, doesn't cost less than 100 euros, and if someone doesn't think their car, or its maintenance, is worth that amount, they should consider whether a bicycle might be a better and more affordable alternative.
Replacing a used engine with a new one, including installation, will certainly cost four digits, and so will buying a newer car. Therefore, this is not a question for people who are financially savvy.
Best regards, Rüdi.
Bergamount
Post17-01-2018, 8:41    Subject: Timing belt replacement interval for AHF-TDI engines Quote
I would replace all 90,000 miles' worth. Okay. Could you ask the manufacturer? I did the same thing with my Audi, and I received a response from Audi after one day. Please provide the vehicle identification number (VIN) when making the request.
dieselschrauber likes this.
Post17-01-2018, 10:46    Subject: Re: Timing belt replacement interval for AHF-TDI engines Quote
sgrund wrote:
... My question is whether one can base the maintenance intervals on the longer intervals of the ASV engine, which I believe is 120,000 km?
Believing does not mean knowing, and therefore you are also wrong!
The ASV typically has a maintenance interval of 90,000 km.
The motor block was not redesigned and the position of the idler pulleys was not modified until 2002. With this modification, the motors received a 120,000 km service interval. Whether the specific ASV was affected or is affected can only be determined precisely by checking the engine number.
In any case, that doesn't apply to your AHF!
Post17-01-2018, 11:45    Subject: Timing belt replacement interval for AHF-TDI engines Quote
My car's owner's manual, from the middle/end of 1998, specified a maintenance interval of 90,000 km and then 60,000 km for the timing belt replacement. Without any guarantee, there was a different belt at some point, and then it had 90,000 km on it again.
Are there any other topics related to this? icon_idea.gif 120,000 km would likely be the mileage for a total loss claim under warranty.
dieselschrauber and DieselBär30x likes this.
Post17-01-2018, 12:18    Subject: Timing belt replacement interval for AHF-TDI engines Quote
dieselschrauber wrote:
My AHF from mid/late 1998 had an initial mileage of 90,000 km and then a 60,000 km interval for the timing belt replacement. Without any guarantee, there was a different belt at some point, and then it had 90,000 km on it again.
Was that the AHF with the foggy CT946?
Then, the attached PDF icon_wink.gif applies.
He drove 90,000 kilometers with the CT1044.
The warranty likely covers a total loss up to 120,000 km.
CT946K2-CT1044K1 (DE).PDF
 File name:  CT946K2-CT1044K1 (DE).PDF
 File size:  100.37 KB
 Downloaded:  258 times
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Doku Fehler beim Zahnriemenwechsel, AGP,AGR,AHF,ALH u.a Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Zahnriemenwechsel beim A6? Diesel Engine Technology
No new posts Timing Belt Replacement for AEL Engines Diesel Engine Technology
No new posts Zahnriemenwechsel beim AJM Motor Diesel Engine Technology
No new posts Timing Belt Replacement: 1Z Model Questions Diesel Engine Technology
