A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600)
Insoric
Post26-01-2018, 22:51    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Quote
Hello. We are experiencing the following problem on an unmodified A6:
Brief Background. The A6 was running relatively well without a load. When running at full throttle, the error message "Low fuel system pressure" immediately appeared. The fuel filter was replaced, but the error message remained. The fuel injectors were inspected and it was observed that the 2nd cylinder was delivering significantly more than 2.0 mg/stroke. The 2nd cylinder injector was replaced, and the copper sealing ring was also burnt away. The injector in the MSG was reprogrammed, the FS was deleted, and the system was bled. A test drive of 15 km had no problems, but then the error message related to the power supply appeared. This error could not be cleared in this state, and the engine was running very poorly. It felt like it was running on three cylinders. When the throttle was opened, it would stall. The colder it got, the better it ran. When the temperature dropped below 30 degrees, it ran perfectly and the error message could be cleared. The engine was running smoothly. What could be the cause?
Sorry, that I'm posting the Gutmann photos here, I unfortunately didn't bring the VCDS with me to the office.
Thank you.
 Wenn der Fehler kommt alles Nullwerte
 File size:  97.8 KB
 Viewed:  7100 times
 File size:  87.98 KB
 Viewed:  7174 times
 File size:  80.84 KB
 Viewed:  9167 times
 File size:  87.48 KB
 Viewed:  7238 times
Mike Hanke
Post26-01-2018, 23:23    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
blöd, daß die Fehlercodes keine VAG-Fehlercodes sind...
Autoscan wäre doch hilfreich.
Wenn der Kraftstoffdruck zu gering ist, wird halt entweder wo Kraftstoff verloren gehen oder die Hochdruckpumpe baut nicht genügend Druck auf oder das Druckregelventilist defekt.
Ein Log vom Kraftstoffdruck-Soll/Ist mit KDataScope wäre ebenfalls hilfreich.
Rücklaufmengen aller Injektoren gemessen und verglichen? Sind diese dicht zum ZK?
Insoric
Post27-01-2018, 9:23    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Guten Morgen Rainer, vielen Dank für Deine Antwort.
Ich werde heute gegen Mittag mal Autoscan machen und Logs fahren. Ich habe dazu nur ein kurzes Zeitfenster verfügbar, wo ich dann mal Kraftstoffdruck-Soll/Ist loggen werde. Bei ca. 70°C steigt der Motor im wahrsten Sinne des Wortes aus und ich muss abschleppen da nicht mehr fahrbar. Also komplett digital und temperaturabhängig. Kann somit irgendwie nicht Hardware sein?! Bis später.
VG
Mike
Mike Hanke
Post27-01-2018, 10:14    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Bei "normalen" Düsenhalterkombinationen hatten Kunden schon ähnliche Effekte, die Düsen wurden durch nicht fachgerechten Einbau (Verbrennungsgase gingen durch den Sitz am ZK) zu heiß und verklemmten intern. Du schriebst aber nichts, daß bei Deinem Motor an allen Düsen herumgebaut wurde.
Auch Diesel wird mit steigender Temperatur noch dünnflüssiger, ein nicht richtig schliessendes Druckregelventil könnte dann überfordert sein.
Insoric
Post27-01-2018, 10:51    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Düse wurde nur 2. Zylinder erneuert, da war auch der Kupferdichtring weggebrannt. Düse im MSG neu codiert, FS gelöscht und System entlüftet.
Mike Hanke
Post27-01-2018, 10:56    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Warum? Dann kann sie ja nicht richtig fest gewesen sein...
Karma: +1333 / -0   Thank you, like it!
Post27-01-2018, 11:04    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Es ist mit Sicherheit Hardware. Der Code P0087 zeigt in die Richtung, sh. Ross Tech Wiki.
Aber erst mal den Autoscan, damit wir die Fehler entsprechend VCDS haben.
Insoric
Post27-01-2018, 15:57    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Dieser Fehler kommt immer sobald Vollast, auch schon wenn der Motor noch kalt ist. Danach im Prinzip Notlauf. Wenn gelöscht, während der Fahrt wieder volle Leistung bis zum nächsten mal durchstarten.
Samstag,27,Januar,2018,11:06:30:06515
VCDS Version: DRV 17.8.1 läuft auf Windows 7 x86
shop.dieselschrauber.org
Adresse 01: Motorelektronik Labeldatei: DRV\059-907-401-V2.clb
Steuergerät-Teilenummer: 4G0 907 401 F HW: 4G0 907 401
Bauteil und/oder Version: 3.0TDI EDC17 H37 0005
Codierung: 12254012057601020000
Betriebsnummer: WSC 28061 142 88759
ASAM Datensatz: EV_ECM30TDI0114G0907401F 001005 (AU57)
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 26443F5B59FE7E76CB-8072
1 Fehler gefunden:
5060 - Versorgung Einspritzventil(e) A
P2146 00 [096] - Unterbrechung
Sporadisch - unbestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Kilometerstand: 258145 km
Datum: 2018.01.26
Zeit: 11:30:29
Motordrehzahl: 2295.50 /min
Normierter Lastwert: 16.9 %
Fahrzeuggeschwindigkeit: 0 km/h
Kühlmitteltemperatur: 79 °C
Ansauglufttemperatur: 20 °C
Umgebungsluftdruck: 960 mbar
Spannung Klemme 30: 14.380 V
Verlernzähler nach OBD: 40
Erlaubte Anzahl an Einspritzungen-Bit 0: 3
Einspritzfreigabestatus-Bit 0: 56
Wunscheinspritzverlauf-Bit 0: 56
Mittlere Einspritzmenge: 4.99 mg/stroke
Raildruckregelung: Status-Bit 0: 5
Kraftstoffhochdruck: Istwert: 615000 hPa
Steuergerätetemperatur: 34.6 °C
Readiness: 0 0 0 0 1
Autoscan und Logfile habe ich als csv beigefügt.
 File size:  117.85 KB
 Viewed:  1191 times
Autoscan.pdf
 File name:  Autoscan.pdf
 File size:  91.79 KB
 Downloaded:  990 times
Mike Hanke
Post27-01-2018, 17:24    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
ok, das hat aber nun gar nichts mit dem Raildruck zu tun, sondern betrifft die Verkabelung zwischen Motorsteuergerät und Injektor...
Wenn mit dem Raildruck nun kein Fehler mehr auftritt, würde ich mich auf obigen Fehler konzentrieren und Verkabelung und Stecker prüfen.
Dein Log habe ich leider löschen müssen, es war durch Konvertierungen/Speichern im falschen Format vollkommen verhunzt.
Tipp: Als Kunde kannst Du doch KDataScope nutzen (Download im Kundenkonto vom Dieselschrauber Shop). Da muss man keine Bullshits-Konvertierungen durchführen die dann zu so einem Schrott führen. Log doppelklicken und ansehen, fertig:
/viewtopic.php?t=16947&start=24#232335
Hast Du die Logdatei nicht noch irgendwo unvermurkst, so wie VCDS sie gespeichert hat?
Insoric
Post27-01-2018, 18:16    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Danke für Deinen Tipp Rainer. Verkabelung und Stecker alles i.O. vielleicht das Motor STG?
Vielleicht kannst mit der Anlage was anfangen. Wenig Material, wir haben den Fehler in quasi 5 Minuten 5x reproduzieren können.
Mike Hanke
Post27-01-2018, 20:11    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Hi Mike,
die Datei war wiederum Schrott, ausserdem war es nicht die .csv Datei sondern ein Excel File.
Nochmal: Die VCDS Logdatei (.csv) nehmen. Nix damit machen, einfach nehmen, ist gar nicht so schwer. Eigentlich. icon_idea.gif
chli1976
Karma: +185 / -0   Thank you, like it!
dieselschrauber likes this.
Post27-01-2018, 20:36    Subject: A6 C7 MKB CDUC - Error Code: 5211 (P008700) and 5060 (214600) Translating...
[Translating...]
Den Versorgung Einspritzventil Fehler hast erst seit dem du einen neuen Injektor verbaut hast? Zum Fahrzeug passender Injektor?
Hat diesen Fehler mal bei einem A5, da war das Motorsteuergerät defekt. Allerdings ist dieser gar nicht mehr angesprungen.
VCDS
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel rail/system pressure too low Diesel Engine Technology
No new posts TDI Engine Software: Label File Error? On-Board Diagnostics (OBD)
No new posts Audi 3.0 TDI CDUC Piston Endoscopic Inspection Diesel Engine Technology
No new posts Error code Diesel Engine Technology
