Injector Nozzles: Can You Repair the "Tips"?
zimpel64
Post02-03-2018, 8:42    Subject: Injector Nozzles: Can You Repair the "Tips"? Quote
Hello everyone,
I thought I would post here with my question, as I often hear that everyone here has a real plan! icon_smile.gif
Can I screw different nozzles onto a pump injector and use larger ones? The purpose is to increase performance. I'm currently getting 150 horsepower with the stock injectors in my 1.9 TDI (ATD engine). Which ones would be suitable, and where can I get such nozzles (if it's even possible)?
Best regards and thank you.
Translated on 04-09-2026, 3:13.
Benni
Post09-03-2018, 6:21    Subject: Injector Nozzles: Can You Repair the "Tips"? Quote
No.
Translated on 04-09-2026, 3:14.
chli1976
Post09-03-2018, 11:20    Subject: Injector Nozzles: Can You Repair the "Tips"? Quote
Okay, so you can replace the injector nozzles, but I'm not sure if the pump piston will work with larger ones.
And then, we would also need to monitor the opening pressure.
I've replaced a nozzle insert before, but with one of the same size.
VCDS
Post09-03-2018, 11:34    Subject: Injector Nozzles: Can You Repair the "Tips"? Quote
The question was:
Can I screw the tips onto a pump nozzle element and install larger ones?
The answer is, in my opinion, completely correct. Because when trying to find information on the topic, he has already failed.
Translated on 04-09-2026, 3:15.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Diesel Injector Failure? Diesel Engine Technology
No new posts T4: Can individual control units be "linked" via software? On-Board Diagnostics (OBD)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts A3: Error code 01367 "Central locking pump shut-off" Diesel Engine Technology
