Engine Control Unit No Power: Intermittent Starts, Heat Issues
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
gtikasper
Post12-04-2018, 19:35    Subject: Engine Control Unit No Power: Intermittent Starts, Heat Issues Quote
The vehicle is a Skoda Octavia 2.0 TDI with DSG transmission from 2005.
He has driven it for 400,000 kilometers, and the engine has approximately 250,000 kilometers on it.
Problem: I drove it on Friday, parked it, and it was very hot on Saturday.
"Ignition on, DSG gear indicator blinking, fan started, ESP light is on, no preheating and fuel pump not engaging. Attempted to start the engine with the error message displayed, but it failed. It cranks, but that's all."
"Last night, I removed the engine control unit (ECU). According to the diagnostic tool, there was no power reaching it (error code 01314). However, when it got colder, it started again."
"The error only occurs sporadically when the temperature is below 10 degrees Celsius. When it's 20 degrees Celsius, you have to turn the ignition on and off for about 30 minutes before it works without errors. When it runs, it runs perfectly."
"All the fuses are okay, and so is the relay. I swapped them around to test. This weekend, I'll check the grounding points and measure if there's any voltage at the MSG (message) connector."
Do you have any other ideas for error checking, perhaps a guide, flowchart, or experiences to share?
Since it only happens with heat, that's strange.
Here's the error log if the MSG responds:
Thursday, April 12, 2018, 6:05:46:57079 PM.
VCDS - A VAG/VAS emulator based on Windows - runs on Windows Vista x86.
VCDS version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number (VIN): TMBGE61Z462179026. License plate number: [Insert license plate number here].
Mileage: 398,530 km. Repair order: [Leave blank or insert repair order number/details here].
Vehicle type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76 77
7D
Vehicle Identification Number (VIN): TMBGE61Z462179026. Mileage: 398,530 km.
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: Error 1010.
02-Gearbox -- Status: Error 0010.
03-Brake electronics -- Status: Error 0010.
08 - Climate Control/Heating Unit - Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system - Status: Error 0010.
37-Navigation -- Status: unreachable 1100.
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: Error 0010.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking Assist -- Status: Error 0010.
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 DS, HW: 028 101 195 3.
Part: R4 2.0L EDC G000AG 7000
Revision: 12345678 Serial Number: SKZ7Z0E3251577
Coding: 0000078
Operating number: WSC 73430 790 00000
VCID: 77D2B0470613B3864F-8022
"One error found:"
17057 - Spark plug, cylinder 3 (Q12)
P0673 - 000 - Electrical fault in the circuit.
Environmental conditions:
Speed: 0 RPM.
Torque: 160.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.78 V
Binary value: 00101111
Temperature: 6.3°C
Binary value: 00110000
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\02E-927-770.lbl
Part number SW: 02E 300 042 F, HW: 02E 927 770 AE.
Component: GSG DSG, part number 070 0924.
Revision: 04507000 Serial Number: 00000509290104
Encoding: 0000020
VCID: 160C9DC321596A8EB4-8042
"One error found:"
18258 - Data bus driver.
P1850 - 000 - Missing message from engine control unit - Intermittent - Warning light ON.
Error status: 10100000
Error priority: 0
Error frequency: 255
Lost Count: 40
Mileage: 398,491 km
Time: 0.
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Encoding: 0023170
VCID: 40A01B9B135D343E3E-8014
3 error codes found:
00778 - Steering angle sensor (G85).
000 - - - Sporadic
00668 - Voltage at terminal 30.
008 - implausible signal - sporadic.
01314 - Engine Control Unit (ECU)
004 - No signal/communication - Intermittent.
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 1Z0 907 044 J
Component: Climatronic PQ35 084 0305
Operating Number: WSC 00000 000 00000
VCID: 3D5E626F64AF59D655-8068
00819 - High-pressure sensor (G65)
009 - Intermittent short circuit to ground.
01316 - Brake control unit.
004 - No signal/communication.
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 E, HW: 3C0 937 049 E.
Component: Onboard network module H37 1002.
Revision: 00H37000 Serial Number: 00000003654079
Encoding: E1889E130004142300110D00000000000009BE0D5C
Operating number: WSC 12345 123 12345
VCID: 2B7A5C378ADBC766FB-807E
Subsystem 1 - Part number: 1Z1 955 119 A
Label file: DRV\1KX-955-119.CLB
Component: Wiper SK351 012 0401.
Encoding: 00065525
Subsystem 2 - Part number: 1K0 955 559 T
Label file: DRV\1K0-955-559-AF.CLB
Component: RainLightSensor 011 1110
Encoding: 00208933
5 error codes found:
02394 - Lamp for front left side marker light (M1).
012 - Electrical fault in the circuit.
Error status: 01101100
Error priority: 2
Error frequency: 1.
Lost Count: 140
Mileage: 398,395 km
Time: 0.
one
Voltage: 14.25 V
one
one
text
from
text
from
one
02395 - Lamp for front right side marker light (M3).
Error priority: 2
Error frequency: 1.
Lost Count: 140
Mileage: 398,395 km
Time: 0.
one
Voltage: 14.25 V
one
one
text
from
text
from
one
Error status: 00100100
Error priority: 2
Error frequency: 19.
Lost Count: 180
Mileage: 398,391 km
Time: 0.
one
Voltage: 12.20 V
one
one
text
from
text
from
text
from
00059 - Terminal 30 for interior lighting.
012 - Electrical fault in the circuit - Intermittent.
Error status: 00101100
Error priority: 5.
Error frequency: 2.
Lost Count: 180
Mileage: 398,454 km
Time: 0.
text
from
Voltage: 12.15 V
text
from
text
from
text
from
text
from
text
from
02390 - Controller for ambient lighting (E400)
009 - Short circuit to ground / Ground fault.
Error status: 01101001
Error priority: 5.
Error frequency: 1.
Lost Count: 140
Mileage: 398,391 km
Time: 0.
one
Voltage: 12.20 V
one
one
text
from
text
from
text
from
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 M, HW: 1K0 909 605 M.
Part number: Q2 AIRBAG VW8, 024 0700.
Revision: 07024000 Serial Number: 0038DD0SW3X4
Encoding: 0020786
VCID: 364C7D4341998A8E94-8062
Subsystem 1 - Serial number: 6332MSME4D607F0B.
Subsystem 2 - Serial number: 6342MSME22067E0B
Subsystem 3 - Serial number: 6351HSME6B091400.
Subsystem 4 - Serial number: 6361HSME03515408
No error codes found.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AG, Hardware part number: 1K0 953 549 AG.
Component: J0527 034 0070
Encoding: 0012042
Subsystem 1 - Part number: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number SW: 1Z0 920 842 D, HW: 1Z0 920 842 D.
Component: COMBINATION INSTRUMENT VD1 1612
Revision: V1612038 Serial Number: SKZ7Z0E3251577
Encoding: 0003101
Operating number: WSC 80093 222 69422
VCID: 3850737B4B8D7CFE86-806C
Two error codes found:
Error priority: 2
Error frequency: 254
Lost Count: 180
Mileage: 398,005 km
Time: 0.
Date: 2000.00.00
Time: 21:54:25
01309 - Steering assist control unit (J500)
Error priority: 2
Error frequency: 13
Lost Count: 174
Mileage: 398,005 km
Time: 0.
Date: 2000.00.00
Time: 22:05:06
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530-V1.clb
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120
Revision: H10 Serial Number: 2800105A0583A0
Encoding: 3F3F0FC8072302
VCID: 2A7459338521DE6E00-807E
01300 - Control unit for navigation system with CD drive (J401).
Error status: 01100100
Error priority: 2
Lost Count: 140
Mileage: 397,991 km
Time: 0.
Date: 2000.00.00
Time: 01:52:28
Error priority: 2
Error frequency: 61.
Lost Count: 180
Mileage: 398,005 km
Time: 0.
Date: 2000.00.00
Time: 21:54:25
01312 - Data bus for drive system.
014 - defective - intermittent.
Error status: 00101110
Error priority: 1.
Error frequency: 10.
Lost Count: 174
Mileage: 398,005 km
Time: 0.
Date: 2000.00.00
Time: 22:05:00
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO Part Number: VD1 1612
Operating number: WSC 58122 175 92733
"One error found:"
02241 - Engine control unit; Immobilizer data not adapted.
000 - - - Sporadic
Error status: 00100000
Error priority: 2
Error frequency: 1.
Lost Count: 255
Mileage: 0 km
Time: 0.
Address 37: Navigation.
unavailable
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MAX2.lbl
Part number: 1T0 959 701 C.
Component: Door seal 024 2437
Encoding: 0000246
VCID: 37527047469373868F-8062
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 J
Component: EPS_ZFLS, Size 5, D04 1606.
VCID: 32444153ADF196AEB8-8066
"One error found:"
Mileage: 8000 km
Temperature: 24.0°C
Voltage: 12.50 V
Voltage: 12.20 V
Address 46: Comfort System
Label file: DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AK
Component: KSG 0401
Encoding: 18D002007F2D8505080F010004CC
Operating number: WSC 73430 790 12345
VCID: 79D6B67F3007A5F639-802C
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE (not mounted)
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MAX2.lbl
Part number: 1T0 959 702 C
Encoding: 0000246
Address 56: Radio.
unavailable
Address 62: Door electrics, left/right. Label file: DRV\1K0-959-703-GEN2.lbl
Part number: 1K0 959 703 E
Component: Door seal 021 2435
Encoding: 0000144
Address 72: Door electric strike, right side.
Label file: DRV\1K0-959-704-GEN2.lbl
Part number: 1K0 959 704 E
Encoding: 0000144
VCID: 334A445752EB9FA6B3-8066
Address 76: Parking Assist
Label file: DRV\1Z0-919-283.lbl
Part number SW: 1Z0 919 283 B, HW: 1Z0 919 283 B.
Component: Parking assist system, 4-channel, part number H04 0020.
Encoding: 0001001
"One error found:"
00576 - Terminal 15.
Error status: 00101000
Error priority: 3
Error frequency: 6.
Lost Count: 175
Mileage: 398,005 km
Time: 0.
Date: 2000.00.00
Time: 00:42:00
Address 77: Telephone Label file: DRV\5P0-862-335.lbl
Part number SW: 5P0 862 335 A, HW: 5P0 862 335 A.
Component: FSE_2P5x H18 0050
Revision: 00000001 Serial Number: 00000000325132
Encoding: 0000411
VCID: 31464E5FA8F7ADB6C1-8064
Address 7D: Auxiliary Heater
Label file: DRV\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware part number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial Number:
VCID: 2D7E522FB4CFC956E5-8078
End----------------------------(Duration: 01:45)-----------------------------
Translated on 20-08-2026, 14:23.
gtikasper
dieselschrauber likes this.
Post14-04-2018, 20:13    Subject: Engine Control Unit No Power: Intermittent Starts, Heat Issues Quote
Okay, everything seems to be fine with the wiring harness. Today I heated up the MSG (Message Unit) and the error was consistently present. However, after it cooled down below 10 degrees Celsius, the error disappeared.
I'll have someone take a look at that message.
Does anyone have a good recommendation for someone who can do this and is reasonably priced?
best regards, melli
Translated on 20-08-2026, 14:24.
Post15-04-2018, 12:14    Subject: Engine Control Unit No Power: Intermittent Starts, Heat Issues Quote
Does anyone have a good contact for someone who can do this and is reasonably priced?
If the engine control unit (ECU) has never been opened before, it would be more sensible to obtain a used ECU and have the Waste Fuel System (WFS) either adjusted or deactivated.
Translated on 20-08-2026, 14:25.
gtikasper
Post16-04-2018, 18:10    Subject: Engine Control Unit No Power: Intermittent Starts, Heat Issues Quote
The MSG was already showing this issue back in 2013, where the old engine was shaking so much. I also opened it again over the weekend and hoped to see a defect.
Is there an instruction manual for self-repair? Which component(s) and solder joints are defective?
The companies that have been contacted so far are asking for prices between €3 and €400.
Unfortunately, there are few messages online where the numbers and letters match exactly, and I'm afraid of experiencing similar defects. icon_sad.gif
Translated on 20-08-2026, 14:26.
gnasch
Karma: +23 / -0   Thank you, like it!
Post17-04-2018, 22:17    Subject: How to Guide: Step-by-Step Instructions Quote
Search Google for "cracked solder joint," using image search. Research the topic.
Examine the print closely with a magnifying glass and compare the images.
If necessary, re-solder any suspicious areas with a fine tip and lead-containing solder. Don't overheat it!
https://de.wikibooks.org/wiki/Fehlersuche_in_Elektronik-Schaltungen
Best regards, Gnasch.
Translated on 20-08-2026, 14:27.
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intermittent lack of boost pressure, 1.8T AUM Gasoline Engine Technology
No new posts 1.9 TDI: Intermittent Engine Misfire - Causes & Fixes On-Board Diagnostics (OBD)
No new posts 2.0 TDI CRLB engine occasionally fails to start Diesel Engine Technology
No new posts MFA: Darkening in Heat - Explained Transmission, Chassis, Body & Interior
