DPF Problems: Causes, Solutions & Repair
haithamina
Post25-11-2018, 20:48    Subject: DPF Problems: Causes, Solutions & Repair Quote
"viewtopic.php?p=244487#244487"
Comparing this with my data, as seen in post 14.11, the 0.13 L oil ash volume cannot correspond to either the calculated 8.33 grams or the measured -0.13 grams. There is definitely at least one sensor that is defective.
haithamina
Translated on 01-10-2026, 11:20.
TTaurus
Post25-11-2018, 20:57    Subject: DPF Problems: Causes, Solutions & Repair Quote
haithamina wrote:
When I compare this with my data, see posting 14.11, the 0.13 L oil ash volume neither corresponds to the calculated 8.33 grams nor the measured -0.13 grams. There is definitely at least one sensor that is defective.
haithamina
STOP.
That has nothing to do with each other!
Or am I misunderstanding something here?
I'm interested in the relationship between the calculated and measured soot values.
Is it an EU6 engine?
Translated on 01-10-2026, 11:22.
Post26-11-2018, 9:11    Subject: DPF Problems: Causes, Solutions & Repair Quote
The soot level can certainly be slightly negative after a regeneration process. Specifically, the measured value is determined based on the differential pressure.
Most likely, the soot level, which previously drops below zero, triggers the end of the regeneration process.
Translated on 01-10-2026, 11:23.
haithamina
Post26-11-2018, 10:25    Subject: DPF Problems: Causes, Solutions & Repair Quote
TTaurus wrote:
haithamina
STOP.
Yes, I was referring to the ratio of ash volume to ash mass. The values posted so far show a significantly different relationship.
Yes, the data I posted comes from a EU6 CR diesel engine with a storage catalytic converter (without SCR).
haithamina
Translated on 01-10-2026, 11:24.
No new posts Empty Weight Confusion: A Fresh Look Diesel Engine Technology
No new posts VW Oil Pump Part Number? Confusion Explained Diesel Engine Technology
No new posts Friendly Confusion: Advice and Help Needed Diesel Engine Technology
No new posts Passat 2.0 TDI: Driveshaft/Joint Part Numbers Explained Transmission, Chassis, Body & Interior
