TDI Engine Noise: Troubleshooting & Repair
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post12-04-2018, 17:40    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
Hello forum,
I hope the link works.
If I had uploaded the video here right away, and if my web browser hadn't cached it prematurely, and if I weren't such an impatient person, I would have saved the administrator some work.
"This clicking sound sometimes occurs in my engine. So far, it has only happened very rarely. Has anyone else experienced this before?"
Last fall, I had this a few times, not at all during the winter, and now again on Tuesday. icon_question.gif icon_question.gif icon_question.gif
No lights are turning on, there's no error message, and the power supply is working correctly; the oil level is also fine.
Best regards, Jörg.
TDI Engine Noise: Troubleshooting & Repair - Motorgeräusch VW Diesel, hört sich an wie ein Trecker.mp4
 File size:  4.19 MB
 Viewed:  600 times
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
Translated on 25-07-2026, 17:39.
Karma: +807 / -0   Thank you, like it!
Post12-04-2018, 19:25    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
Have you checked the timing belt and its tensioner?
I would check to see if anything is getting stuck or catching somewhere during operation. It's also possible that the internal mechanism of the dual-mass flywheel is misaligned.
Does the noise disappear when you briefly rev the engine up to 4000 rpm?
Translated on 25-07-2026, 17:40.
jörg schmidt
Post12-04-2018, 20:11    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
Hi Rainer,
I only gave it short bursts of acceleration, definitely not up to 4000 RPM.
Right now, everything is back to normal. I have to wait until it happens again so that I can test it.
What could cause the ZMS (torque converter) to fail? In my 6L, it lasted almost 500,000 km. My driving style hasn't changed. Perhaps the quality icon_rolleyes.gif.
Jörg
By the way, that's true, I am an impatient person icon_wink.gif. Sorry if I caused any trouble, it was really not intentional.
>178000km
EZ 3.2011 >230000km
Translated on 25-07-2026, 17:42.
Post13-04-2018, 9:20    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
What could cause the ZMS to fail?
Translated on 25-07-2026, 17:43.
Karma: +649 / -0   Thank you, like it!
Post13-04-2018, 10:45    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
Hi neighbor.
What happens if the noise is still present after a direct restart?
jörg schmidt
Post13-04-2018, 16:30    Subject: TDI Engine Noise: Troubleshooting & Repair Quote
Hello there!
Last time, it reappeared immediately, even right after starting [the engine/machine]. This was the first time I had heard any clicking sounds this year.
"I had that clicking sound last year when it was still a bit warmer. I should have remembered it, especially during the summer and fall. I even tried to record it once, but the noise disappeared while the engine was running, so before I could position my smartphone."
Perhaps it's related to an injector or the control unit? If there's a noise, try spraying it with refrigerant spray. Should I read out any correction values? For a sporadic error, I suspect something electrical.
I spoke with a master technician from Seat today. He watched the video and also doesn't know what to do. They haven't seen anything like it before. I should try to reproduce the noise. Right now, there's no point in taking it to the workshop because the engine shows no abnormalities.
Jörg.
>178000km
EZ 3.2011 >230000km
Translated on 25-07-2026, 17:45.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI CR CFHD: Replace Pressure Sensor Diesel Engine Technology
No new posts Disable ESP: 2.0 TDI 143HP Seat Ibiza (2015) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Intermittent Engine Misfire: Causes & Fixes Diesel Engine Technology
No new posts TDI V6 Idle Tick: Causes & Fixes On-Board Diagnostics (OBD)
