Air Filter Hose: What is its purpose?
Go to page: 1, 2  Next
Micha007
Post21-03-2012, 11:33    Subject: Air Filter Hose: What is its purpose? Quote
I've always wondered what the purpose of this hose is and where it leads.
This is a 2.0 TDI BKD engine.
The image is just an example and was quickly grabbed from the internet!
Thank you in advance.
Micha
 Luftfilterkasten Golf V
 File size:  88.66 KB
 Viewed:  63234 times
Translated on 03-10-2026, 15:03.
Post21-03-2012, 11:47    Subject: Air Filter Hose: What is its purpose? Quote
This is the ATM connector of the N75.
"zu Deutsch" bedeutet "in German".
In this case, the valve that controls the turbocharger is drawing in "normal air."
The other connection on the valve is labeled "vacuum".
It "mixes" the vacuum pressure, which then directs the VTG, resulting in varying amounts of pressure at times.
Translated on 03-10-2026, 15:04.
Micha007
Post21-03-2012, 11:58    Subject: Air Filter Hose: What is its purpose? Quote
Okay, thank you very much!!
It was worn out on my car because it was torn at the end, but I didn't notice any difference in the way it handled... which, as I now know, is how it was supposed to be.
He's probably put it there so that the N75 only receives filtered air!
Thank you again.
Micha
Translated on 03-10-2026, 15:05.
Post21-03-2012, 12:10    Subject: Air Filter Hose: What is its purpose? Quote
HI,
Yes, exactly.
Some valves have their own built-in microfilters.
Some people even add an additional restrictor.
[img]/download.php?id=3799[/img]
It's implemented differently on each engine.
The hose seems to be considered a delicacy by martens.
It is also attractively arranged and cut into bite-sized pieces icon_wink.gif.
Translated on 03-10-2026, 15:06.
Micha007
Post21-03-2012, 12:54    Subject: Air Filter Hose: What is its purpose? Quote
Thank you again for the suggestion, but I'm ruling out a weasel bite, as the car is always parked in the garage.
Translated on 03-10-2026, 15:07.
Rüdi likes this.
Post21-03-2012, 19:27    Subject: Air Filter Hose: What is its purpose? Quote
It might be worth noting that hoses that have been chewed on or damaged should be repaired, even if they are only leaking air.
Because the air filter draws in relatively clean air. If the hose is simply hanging loose in the engine compartment, dirt can be sucked into the magnetic valves for turbocharger control, swirl flap switching, or for the EGR system. This can cause the magnetic valves to jam and fail. -> Replacing damaged hoses is a preventative measure that costs very little.
Translated on 03-10-2026, 15:08.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post21-03-2012, 21:15    Subject: Air Filter Hose: What is its purpose? Quote
In the first picture, there's a really cool hose connecting the mass airflow sensor (MAF) to the intake manifold and to the air filter!
reflexsilber met.
Translated on 03-10-2026, 15:09.
vagtuning
Post21-03-2012, 22:37    Subject: Air Filter Hose: What is its purpose? Quote
That's probably some kind of ion exchanger icon_wink.gif.
Unfortunately, because it's a PD (presumably referring to a product or service), the quality is quite poor.
the magnetic field aligners are installed on the fuel lines icon_wink.gif.
http://www.hagans.de/27-0-ausfuehrliche-informationen.html
Micha007
Post22-03-2012, 10:10    Subject: Air Filter Hose: What is its purpose? Quote
Perhaps it's worth mentioning that hoses that have been chewed on or damaged should be repaired, even if they are only leaking air.
'Because the air filter draws in relatively clean air. If the hose is simply hanging loose in the engine compartment, dirt can be sucked into components like the magnetic valves for turbocharger control, swirl flap switching, or the EGR system. This can cause the magnetic valves to become stuck and fail. -> Replacing damaged hoses is a preventative measure that costs very little.'
Best regards, Rainer
Yes, of course, I shortened the end of the hose just before the crack and reattached it. Otherwise, the engine would also be drawing air through the open end in front of the air filter, and in the end, it would be getting its own polluted air... icon_eek.gif icon_biggrin.gif
Micha
Translated on 03-10-2026, 15:10.
Post22-03-2012, 12:22    Subject: Air Filter Hose: What is its purpose? Quote
and in the end, to breathe the very air he has polluted.
Ah, now you are describing the AGR icon_idea.gif.
Translated on 03-10-2026, 15:12.
Micha007
Post22-03-2012, 12:38    Subject: Air Filter Hose: What is its purpose? Quote
Yes, that's correct, but that would be the large AGR, exiting at the rear after the exhaust and re-entering before the air filter... icon_biggrin.gif and without any regulation!!
RedR32
Avatar-RedR32
Post22-03-2012, 13:08    Subject: Air Filter Hose: What is its purpose? Quote
RedR32 wrote:
In the first picture, there's a nice hose between the MAF sensor and the charger, and in front of the air filter!
Why only?
The rear suspension mounting and the splash guard suggest a Polo platform rather than a Golf platform, which means it looks like a Deus Violentias custom build?
reflexsilber met.
Translated on 03-10-2026, 15:13.
dieselschrauber likes this.
Post22-03-2012, 15:03    Subject: Air Filter Hose: What is its purpose? Quote
The reference to Polo9N.info in the photo significantly reinforces this impression...icon_smile.gif
samoht
Karma: +1 / -1   Thank you, like it!
Post03-02-2020, 12:32    Subject: Air Filter Hose: What is its purpose? Quote
icon_rolleyes.gif I'm not exactly sure how it happened, but in my Sharan 7n, the plastic tube on the air filter housing, where the N75 hose is connected, has broken off.
I've temporarily patched the hole in the air filter housing with a screw and covered the hose with a breathable cloth secured with a cable tie.
Gibts eine günstige Reparaturmöglichkeit oder muss tatsächlich einen neuer Luftfilterkasten her?? IdWelcome.
VG Thomas.
Translated on 03-10-2026, 15:14.
vag-driver
Post04-02-2020, 9:05    Subject: Air Filter Hose: What is its purpose? Quote
I would first inquire about the price of the spare part from VW. Some parts are actually not as expensive as one might initially fear icon_cool.gif.
Otherwise, I see possibilities for sourcing used replacement parts or gluing the broken area, provided the individual components are still available.
Andreas
Translated on 03-10-2026, 15:15.
Post04-02-2020, 15:59    Subject: Air Filter Hose: What is its purpose? Quote
Often, simply shortening it is enough.
No new posts Wohin kommt dieser Schlauch beim AMF? Diesel Engine Technology
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts Upgrading MFL Caddy box 2018 - Error 31 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vacuum Pneumatic Connection LuFi Upload
