Golf 3: Location of the pressure relief valve.
Varianti
Post06-06-2003, 15:29    Subject: Golf 3: Location of the pressure relief valve. Quote
Yesterday, I was able to read an error code in the diagnostic memory of my climate control system (even though it seems to be working perfectly): 'Defective servo motor for the airflow control flap, V71.'
Where is this located? I thought it might be the recirculation flap, but that's not driven by a motor and actually seems to be working fine.
Can someone help me with this?
Translated on 17-10-2026, 9:43.
Andy
Post07-06-2003, 19:28    Subject: Golf 3: Location of the pressure relief valve. Quote
The pressure relief valve is the uppermost valve located directly below the pollen filter.
According to the SSP208, the air recirculation flap and the back pressure valve are moved by an actuator. In the G3, this is achieved using vacuum, as I observed today.
Best regards, Andy.
Translated on 17-10-2026, 9:44.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Location of Distance Sensor Diesel Engine Technology
No new posts Wastegate Valve Golf 4: Malfunctioning? Transmission, Chassis, Body & Interior
No new posts BKC Motor: LLK Location & Installation Guide Diesel Engine Technology
No new posts Coolant sensor location ARL: Find it here! Diesel Engine Technology
