Air Mass Sensor Error: Is it the AGR Valve?
jemoraw
Post21-06-2018, 10:09    Subject: Air Mass Sensor Error: Is it the AGR Valve? Quote
My Caddy received the software update two weeks ago, after a threat of being decommissioned. After driving 800 km, it suddenly started to jerk intermittently. Yesterday, the jerking was much more severe, and the engine check light started flashing.
Now the warning light often flashes, but not constantly, and the car jerks repeatedly.
Please provide an assessment...
VCDS says:
Address 01: Engine Control Module (J623-CAYD)
Label file: .DRV\03L-906-023-CAY.clb
Part number SW: 03L 906 023 TF, Part number HW: 03L 907 425 C.
Part: R4 1.6L TDI, H43 9979.
Revision: --H43--- Serial Number: 00000000000000
Encoding: 00114016030400080000
Operating number: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
ROD: EV_ECM16TDI02103L997557L_VW36.rod
VCID: 7D8311F763B619377D-8028
"One error found:"
7330 - Air mass meter (G70)
P0101 00 [096] - Implausible signal.
Sporadic - unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 2.
Mileage: 42,366 km
Date: 2018.06.20
Time: 11:51:22
Motor speed: 1289.50 rpm.
Normalized load value: 0.0%
Vehicle speed: 48 km/h
Coolant temperature: 95 °C
Intake air temperature: 24 °C
Atmospheric pressure: 990 mbar.
Voltage at terminal 30: 14.231 V.
Dynamic environmental data: 20 96.
Lost count after OBD: 39.
Air mass: Actual value (mg/stroke) - MAF_MEAS: 480.423 mg/stroke.
Air mass ratio, filtered - FAC_MAF_CYL_KGH_RATIO_FIL: 0.87616
Exhaust gas recirculation valve: Actual value - ANG_EGRV[0]: 0.000 %.
Throttle valve actuator: Actual value - ANG_THR[0]: 96.118 %
Boost pressure: Target value - MAP_SP_MMV: 1065.41 hPa.
Boost pressure: Actual value - MAP_MMV: 1065.41 hPa.
Motor torque - TQI_SP: 0.00 Nm
Readiness: 0 0 0 0 0
Could the error be related to the update?
Thank you!
Translated on 11-09-2026, 13:37.
Post21-06-2018, 11:22    Subject: Air Mass Sensor Error: Is it the AGR Valve? Quote
We cordially invite you to participate. The requirement for posting in diagnosis-related topics (everything for which a vehicle diagnostic system is needed) is...
Translated on 11-09-2026, 13:43.
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Mass Sensor: Readings for Gasoline Engines General Tips
No new posts Air Mass Sensor: Expensive Weakness in VW/Audi TDI Technical Articles
No new posts Intake manifold flap position: implausible signal Diesel Engine Technology
No new posts P0471 Error: Unlikely Signal - BLS Troubleshooting Diesel Engine Technology
No new posts Outdoor temperature signal, implausible reading Diesel Engine Technology
No new posts Button for interior locking - implausible signal? Electrical Systems, Vehicle Electronics, Multimedia
