Hey guys,
In my Touran from 10/2004 with a 77kW BKC engine, the turbocharger has just failed.
Which brands are recommended for aftermarket parts?
I came across the brand BorgWarner. Does anyone have experience with it, or other suggestions for brands that are worth considering?
The original is quite expensive.
Thank you in advance.
I would only install exactly what came with the original equipment; it's also possible to find a good used part, as the market is full of them thanks to vehicle scrapping programs.
In the spring, we got a complete BKC engine with all its attachments from the local recycling center for 300 euros. We installed it and tested its functionality first, then removed it again, and it still had a warranty!
