Torque and tightening angles for CAGA camshaft sprocket
olli
Karma: +46 / -0   Thank you, like it!
Post03-10-2018, 21:28    Subject: Torque and tightening angles for CAGA camshaft sprocket Quote
I'm currently visiting Hungary and just happened to be there when our hosts were having their timing belt replaced. Does anyone happen to have the torque specifications and tightening angles for the screws on the camshaft sprocket?
Thank you and best regards,
olli
A6 CANA/JME /
Ex-A6 AEL
dieselschrauber likes this.
Post03-10-2018, 23:14    Subject: Torque and tightening angles for CAGA camshaft sprocket Quote
Hello.
At CJCD, it's 25 Nm. For the pump: 20 Nm (new!). For the tensioner pulley: 25 Nm + 45°. For the small idler pulleys: 20 Nm. For the large idler pulley: 50 Nm + 90° (new!).
Maybe this will help.
olli
Post04-10-2018, 9:58    Subject: Torque and tightening angles for CAGA camshaft sprocket Quote
Hi.
"Thank you." Now he can build on that...
olli
A6 CANA/JME /
Ex-A6 AEL
No new posts Camshaft Sprocket with Anti-Rotation Lock Diesel Engine Technology
No new posts Drehmomente für den Turbo (Garrett) Diesel Engine Technology
No new posts Frage zu zweigeteiltem PD-Nockenwellenrad Diesel Engine Technology
No new posts Power Steering Pump Bolt Torque Specs Transmission, Chassis, Body & Interior
