Switchboard Breaker Fault: Troubleshooting Guide
kinig
Post25-08-2018, 17:30    Subject: Switchboard Breaker Fault: Troubleshooting Guide Quote
Hello VCDS users,
I'm Arthur from South Tyrol, and I'm a complete beginner in the VCDS area.
After buying my new Golf last year, I also purchased the HEX-V2, mainly to make some smaller programming adjustments. However, nothing too complex, so as not to mess anything up on my new car.
Last weekend, however, I was surprised to find an error code when I accessed the car's diagnostic system (I hope the file uploads correctly).
Okay, I wanted to quickly ask what "BAP_TEL_0x28 No Communication" refers to. Is it simply a connection error between the phone and the "radio," or is it something more serious?
Thank you in advance for your tips.
Log-FL672LB-WVWZZZAUZJW089950-9319km.txt
 File name:  Log-FL672LB-WVWZZZAUZJW089950-9319km.txt
 File size:  14.38 KB
 Downloaded:  612 times
Translated on 28-10-2026, 7:47.
Post25-08-2018, 18:03    Subject: Switchboard Breaker Fault: Troubleshooting Guide Quote
1 error found:
16777020 - Functionality restriction due to communication error.
U1110 00 [008] - -
[BAP_TEL_0x28 No communication]
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6
Error frequency: 2.
Lost Count: 241
Mileage: 8832 km
Date: 2018.07.15
Time: 15:45:00
It could be a software bug, a hardware failure, or a faulty cable connection. I wouldn't necessarily overreact to that.
It's a shame that "BAP_TEL" doesn't convey much meaning; perhaps it has something to do with the telephone?
Translated on 28-10-2026, 7:49.
kinig
Post25-08-2018, 18:42    Subject: Switchboard Breaker Fault: Troubleshooting Guide Quote
Hello Rainer,
Thank you for your quick response.
So, I also thought that it was probably just a connection issue between the two devices. However, I'll check it again in the next few weeks.
Unfortunately, I haven't been able to find any more specific information online about what "BAP_TEL" refers to, so I thought I would ask here. Maybe someone else has encountered the same problem.
Maybe it was just a Bluetooth connection issue or something. Let's see... I'll check it again after I've done a few more trips and I'll report back if I find anything out.
Best regards.
Arthur.
Translated on 28-10-2026, 7:52.
Post25-08-2018, 19:18    Subject: Switchboard Breaker Fault: Troubleshooting Guide Quote
Since the error appeared, 4000 km have been driven. I would just let it be and observe. Sometimes, modern vehicles display error messages without any apparent cause. I've seen this happen with an Audi A4 8K (year 2014) and a Golf VII (year 2018).
Translated on 28-10-2026, 7:53.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnosis of relay box using VAG-COM Diesel Engine Technology
No new posts Service Interval Display Panel Insert On-Board Diagnostics (OBD)
No new posts Defective control panel insert? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 B5, ABS/Dashboard insert electrical connection Electrical Systems, Vehicle Electronics, Multimedia
