Golf 4 Xenon Headlights, Generation 2
dr.zikzak
Post22-10-2018, 14:29    Subject: Golf 4 Xenon Headlights, Generation 2 Quote
Hello, dear forum community!
I have a Golf 4, manufactured in 2002, with halogen headlights. I would now like to install the xenon headlights from a Golf 2, despite already having SWRA. "We want to re-evaluate the generation, including ALWR."
My question now: Is there only one control unit mounted at the rear of the headlights in the new generation? The starting device and ignition part are in the headlight?
I was offered new-condition headlights, one of which has a control unit mounted at the rear... However, not high-voltage modules, like those used in older models?
Are they completely finished?
Thank you and best regards,
Alex
Post22-10-2018, 17:02    Subject: Golf 4 Xenon Headlights, Generation 2 Quote
So, mein 2002er I-V hatte an jedem Scheinwerfer hinten eine Vorschaltlampe montiert. Early versions had the charging units located in the wheel wells.
dr.zikzak
Post22-10-2018, 17:36    Subject: Golf 4 Xenon Headlights, Generation 2 Quote
Hello Matthias!
Thank you for your response! That is. Should each individual headlight have its own control unit or high-voltage module?
LG
lampenmann
Post25-10-2018, 23:32    Subject: Golf 4 Xenon Headlights, Generation 2 Quote
Each headlight has its own control unit, high-voltage modules, etc. As far as I know, in the Golf 4, each headlight has its own control unit and a high-voltage module.
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts XENON...2 Bulbs, 2 Days, One Headlight General Tips
No new posts Documentary about foggy headlights and odors inside Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Xenon Scheinwerfer On-Board Diagnostics (OBD)
No new posts Problem with basic settings, headlights, PA06 bi-xenon Electrical Systems, Vehicle Electronics, Multimedia
No new posts Andere Scheinwerfer für den Golf IV Transmission, Chassis, Body & Interior
No new posts Headlights Vento/Golf III: Common Problems Transmission, Chassis, Body & Interior
