vag-driver Profi-Schrauber
21-01-2019, 13:46 Subject: Door Seal: How to Install & Prevent Drafts |
The text describes a Polo 6N. Under the door panel, a foam insert is installed as a water and vapor barrier.
What type of adhesive, tape, or cartridge adhesive is recommended for mounting, allowing the component to be removed if necessary?
Andreas
Translated on 06-10-2026, 2:13.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1512 Karma: +646 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber likes this. |
21-01-2019, 14:26 Subject: Door Seal: How to Install & Prevent Drafts |
There's nothing that can adhere to metal and this type of material on one side and also be completely removable without causing any damage, so I use spray adhesive.
Profile PM Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
21-01-2019, 22:03 Subject: Door Seal: How to Install & Prevent Drafts |
Hello!
I recommend Butyl.
Hi brezelmann01,
Translated on 06-10-2026, 2:14.
22-01-2019, 13:17 Subject: Door Seal: How to Install & Prevent Drafts |
brezelmann01 wrote: |
I recommend Butyl.
Should it be in a tube or a cartridge? I found this one in a cartridge: Sika Lastomer 710.
Andreas
dieselschrauber and vag-driver likes this. |
22-01-2019, 13:36 Subject: Door Seal: How to Install & Prevent Drafts |
As a string. The cartridge might even need to be heated. The string is great to work with.
24-01-2019, 13:15 Subject: Door Seal: How to Install & Prevent Drafts |
Okay, thanks. I'm still waiting for the butyl cord to be delivered. I'll let you know when it arrives.
Andreas
Translated on 06-10-2026, 2:15.
brezelmann01 likes this. |
27-01-2019, 18:33 Subject: Door Seal: How to Install & Prevent Drafts |
It's really easy to do with the string. Thank you for the tip.
Andreas
